Old 06-27-2021, 10:09 PM #1
Frasher4Runner's Avatar
Frasher4Runner Frasher4Runner is offline
Frasher4Runner is on a distinguished road
What PSI For 275/55R20 Tires?
Got new tires put on yesterday and realized I don’t know what pressure to run them at. Went up from the factory size to 275/55R20, which is common. I believe factory spec is 32 PSI but what should these be? Still 32 or something else? I checked all 4 and they’re at 42 right now from the tire shop.
Sent from my iPhone using Tapatalk Pro
Frasher4Runner is offline   Reply With QuoteReply With Quote
Old 06-27-2021, 11:04 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
42 is way to high. Keep them at 32. With slightly larger tires, you can run a bit lower.
Just be sure you use a good/accurate tire gauge. The stick kind is junk.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 02:30 AM #3
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
If your new tires are also P-metric SL loads, they should also be 32 psi.
Tire Pressure Calculator
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 07:41 AM #4
That calculates out to 27 PSI. Is that really correct?!
Old 06-28-2021, 08:32 AM #5
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
10% rise in psi from cold to warmed up.
(random starting number) Cold tire 30psi. Warm ideally would be 33psi. If warm is too high (35 or morel, increase cold psi. Under inflated warms more.
If warm psi is less than 10% then cold psi too high. Tire doesn't warm up enough to develop traction.
This is all dependant upon ambient temperature, load, type of driving, etc. Monitor daily for a week or so and find your average.
I learned to do this road racing motorcycles (track, not public streets).
So for MY tires where I live, I run 30psi in winter (temps down to the 20°`s) and 37psi in summer (up to 120°+).
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 09:23 AM #6
lewis26 lewis26 is offline
lewis26 is on a distinguished road
Do the Chalk test.
Using The Chalk Method for Determining PSI | Interco Tire
lewis26 is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 11:06 AM #7
Based on this, I reduced the PSI to 30 before I drove to work this morning. On the drive in, the truck was pulling to the left and I had a small bit of wobble/shake in the steering wheel. Prior to letting the air out, when at 42 PSI as from the tire shop, no pulling or wobble, just a smooth ride.
Old 06-28-2021, 12:25 PM #8
Jivewalker's Avatar
Jivewalker Jivewalker is online now
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Did you change from "P" to "LT"? What was your factory tire?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is online now   Reply With QuoteReply With Quote
Old 06-28-2021, 01:17 PM #9
I’m not sure what it said on the old tire itself but I believe they were still factory tires. The door jamb sticker says P245/60R20. What I have now is 275/55R20, no P or LT.
Old 06-28-2021, 01:30 PM #10
meltdown meltdown is offline
meltdown will become famous soon enough
I think what he’s getting at is your psi should be based on the load index of the tire, not the size. A P rated tire and an E rated tire of the same size would have different recommended pressures.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 01:38 PM #11
That’s fine and dandy but I need to figure out what that pressure is! LOL
Old 06-28-2021, 01:50 PM #12
Tuco S.'s Avatar
Tuco S.'s Avatar
Post the manufacturer link to your new tire. The specs will show the load rating. Enter the load rating in the tire pressure calculator, and it will kick out a psi.
Old 06-28-2021, 02:02 PM #13
Jivewalker's Avatar
Jivewalker's Avatar
What everyone is saying is correct. You need to find out if your new tire is "P" or "LT", then you can figure out what pressure you should run based on the weight of your vehicle, or, in this case, the weight rating of your stock "P" tires. You will cross reference that to a similar or greater weight rating to your new tire and that will tell you the pressure. The calculator posted above makes it easy if you know the correct tire info.
For instance, my stock P tires were at 32 psi. I went to an LT in the same exact size and I run them at 44psi.
I am fragile.
Not like a flower.
But like a bomb.
Old 06-28-2021, 02:03 PM #14
Tuco S.'s Avatar
Tuco S.'s Avatar
The tire pressure calculator shows 3 different options for that tire size:
Metric 27 psi (SL or XL load)
P Metric 26 psi (SL load)
LT Metric 37 psi (D or E load)
Old 06-28-2021, 02:08 PM #15
COOPER DISCOVERER® AT3 4S™
275/55r20 , factory , psi , they’re , tires
275/55r20 Tire pressure? 17Jetta 5th gen T4Rs 9 11-01-2022 10:10 PM
Nokian WR G3 SUV 275/55R20 ? rblt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-27-2020 12:06 AM
2010 OEM 4Runner Limited wheels with 275/55r20 tires - Mapleton, Utah - $275 jffgrdnr For Sale: Suspension/Wheels/Tires 4 04-29-2019 10:19 AM
285 55r20 on 20x9 wheels TRD_SR5 5th gen T4Rs 11 10-02-2017 04:36 PM
Calgary Alberta 2012 limited 20 inch wheels and 275/55r20 Cooper tires FJ Cruiser Matt For Sale: Suspension/Wheels/Tires 0 11-20-2015 02:49 AM
