Old 06-28-2021, 11:24 AM #1
samobius samobius is offline
samobius is on a distinguished road
[Solved] Limited with No Lights
Hey everyone! Hoping someone can help
My wife was driving her 2014 Limited home from hockey practice the other evening and she said her headlights flipped over to night mode, then flipped back to daylight mode, but since then her headlights do not work at all.
No DRLs, no low beams, no high beams unless we pull back on the stalk.
Going from Auto to headlights on has no effect, except the parking lights do turn on.
Here's what I've checked so far
  • Battery voltage good.
  • No CEL.
  • Covering the light sensor has no effect. No dimming of instrument cluster, no lights coming on.
  • Checked all fuses for continuity with multimeter; all good.
  • Checked low beam bulbs direct to 12v; both good;
  • Swapped low beam relay with heater relay since they're the same; no change.
  • Checked relay input for 12v; 12v showing on both hot legs.
  • Jumped the low beam relay with a wire and lows turn on then
  • Unplugged battery for a couple of hours to reset ECU; no change.
  • Pulled the stalk out and tested all pins against this page (everything is good here too): Toyota 4Runner: Headlight Dimmer Switch Circuit - Lighting System - Service Manual
At this point, I'm running out of ideas. I'm wondering if it's the light sensor somehow but not ruling out the main body ECU either.
Anyone have any ideas where I can look next?
Thanks!
samobius is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 11:56 AM #2
Double_M's Avatar
Double_M Double_M is offline
Double_M is on a distinguished road
Double_M's Avatar
Did you check to see if you're parking brake is on? Some vehicles have headlights/DRL disabled if parking brake is on, even a little. Might be the case here?
__________________________________________________ _____
2016 Limited - Blizzard Pearl
Double_M is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 12:06 PM #3
The parking brake is not engaged (this happened while she was driving), but I won't rule out a grounded parking brake wire. I'll chase it down in the schematics!
Old 06-28-2021, 01:11 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Jumping the low beam relay and then having low beams turn on may indicate a bad socket or pushed pin.
Old 06-29-2021, 12:48 PM #5
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
If its the emergency brake related. Had a 2013 F150 where the emergency brake lever didn't retract far enough to fully push the plunger switch.
I think it was Toyota that at least used to have a plastic knob pressed into the brake lever to push the switch. Not uncommon for that plastic piece to fall out or get off kilter.
3kushn is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 01:43 PM #6
flyrv9's Avatar
flyrv9's Avatar
So what's the reason for even involving lights with parking brake function?
Old 06-29-2021, 06:35 PM #7
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Helps when camping. If you are car camping and get cold at night, push your emergency brake and turn the car on and lights stay off.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 06:56 PM #8
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Do parking lights still work?
I've never heard of the parking brake thing either, but definitely worth checking for continuity across the switch when there shouldn't be, at minimum.
If you don't have the FSM already you should download that, lights start around page 5848. You've got the fault down to signal side rather than supply by jumping the relay. The new FSM wiring diagrams are so piecemeal (or does someone know where there's an overall that gives colors and all that, like they used to?) but it seems like the main body ECU provides ground across the headlight relay. So I'd check for continuity to ground from that ECU terminal, with switch on, then voltage to ground just to be safe. If neither, repeat the test at the pin for your headlight switch input at body ECU (although probably not in that order, I haven't checked the diagram though).
A Techstream dongle would probably be a big help too.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 08:04 PM #9
Apogee.TRD's Avatar
Apogee.TRD Apogee.TRD is offline
Apogee.TRD is on a distinguished road
Apogee.TRD's Avatar
I wouldn't think that the photocell would be the problem since manually turning the lights on should override the photocell. Depending on how Toyota engineers the lighting circuit, I'd look into the headlight switch and photocell.
'21 TRD ORP
IG: @apogee.t4r
Apogee.TRD is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 09:31 PM #10
Parking lights do turn on
That's my next step us to start looking for grounds from the ECU for the relay. But I'm camping for a bit so this will have to wait till I get back.
I've seen a lot of references to Techstream in the FSM but do you have a good source on where I can get this? Seems like an expensive dealer software suite.
Old 07-01-2021, 09:35 PM #11
I'm not convinced on the photocell either but there doesn't seem to be a way to test it without an oscilloscope. I ordered one for $20 off ebay so it's not a big loss if that doesn't resolve it.
Only reason I an leary of the photocell is that I don't even get dash lights dimming when I cover it. Totally agree that the switch should override it but who knows what the computer is actually doing.
The switch itself tests out fine so I'm suspecting something in the main body ECU.
Old 07-01-2021, 09:47 PM #12
jbtvt's Avatar
jbtvt's Avatar
You can get a knockoff on Aliexpress, or you can pay several hundred for something that's less of a PITA to setup, but I forget the names of those. The genuine is thousands
The question on parking lights was for @A10MileHusker since you mentioned before that yours turn on, and he was familiar with what the parking brake did when depressed, from camping.
Old 07-02-2021, 11:17 AM #13
ShakyDog's Avatar
ShakyDog ShakyDog is offline
ShakyDog is on a distinguished road
ShakyDog's Avatar
Sounds like the low beam relay, but you swapped that out...
Unplug one head light and test the power at the plug with head lights on. Is there power? How much power?
Steve
ShakyDog is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 01:08 AM #14
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
When you jumped the low beam relay, was there a voltage going to pin 85 when you toggle from park to headlight mode ?
If no, I would trace back why pin 85 is not going high. This needs to go high for the relay to switch. setting the stalk to light on mode should drive this.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 11:05 AM #15
Real Name: Doug
Real Name: Doug
Yes, parking lights will still work. It is designed to only keep your DRLs off but the moment the stock is switched to parking light or low beams, those will still turn on.
checked , good , lights , low , relay
99 Limited OEM fog lights judoant For Sale: T4R Items 8 01-03-2017 03:27 PM
FS: 5th Gen Limited Tail Lights esto70 For Sale: T4R Items 3 05-15-2015 10:00 AM
06 4.0 limited Gas cap - Warning lights Metalmantr 4th Gen T4Rs 9 04-14-2015 08:00 PM
FS: 5TH gen tail lights SR5/Limited diverscale For Sale: T4R Items 1 10-21-2014 12:33 AM
99 Limited Fog Lights nworbrolyat 3rd gen T4Rs 1 03-04-2005 06:36 PM
