Old 11-01-2023, 10:02 AM #166
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
TH400 with Reid case. It was built by Maximum off-road transmissions in Southern California.
Sent from my Pixel 8 Pro using Tapatalk
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 11-17-2023, 08:38 PM #167
Change is in the Air - YouTube
Old 11-17-2023, 09:34 PM #168
osugsxr osugsxr is offline
new rear driver side passenger door coming soon
Old 11-18-2023, 06:25 AM #169
2019 SAS 5th gen Build. No need, it still opens and closes just fine. The window also operates just fine.
Old 01-06-2024, 04:13 PM #170
Everything is out of my vehicle and we are ready for what is next.
Old 01-07-2024, 07:54 AM #171
is next ??? is this a complete part out ? definitely one of the more interesting builds on this forum
Old 01-07-2024, 09:45 AM #172
Kind of like a complete part out of the stupid wiring harness, which all weighs at least 30 lb. Just for fun we're going to weigh it tomorrow. I may or may not put the stock seats back in as well. I actually listed them for sale this morning here.
My entire dash was removed and we are going to build our own aluminum dash. It will have my Holley pro dash, vintage Air AC and heat. Most likely a large GPS screen and camera monitor and who knows what else this point. Think of a full ultra-4 or trophy truck dash. It should be something much less than what Morgan Clark does and closer wide open designs fj40 build.
I sold my Atlas and have purchased a new transfer case which I will detail later and of course, I have the new engine and transmission going in. My entire stock drivetrain and engine has been sold.
May also cut some of the front tube work, and rebuild it to get the full up travel my truck is capable of.
Of course we'll be rewiring the entire truck again and it will be far more simple than the stock wiring system and multiple computers.
Installing new steering, transmission and oil coolers, and a new 32 gallon fuel tank.
I will give much more detail moving forward as we are about to start putting it all back together. The remaining parts are starting to arrive.
Old 01-07-2024, 10:46 PM #173
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I think you should have bought a Trophy Truck and started from there.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
rdruss is online now   Reply With QuoteReply With Quote
Old 02-05-2024, 05:38 PM #174
Sure, I could have started with Armada Engineering, Brenthel, etc, but that is well beyond even what i've spent and it's a purpose built vehicle different from what I do here on the east coast. would it work, probably but it would not be at home in SoCal bombing through the desert. I could have purchased a rock bouncer from BKOR or WOD, but I sure like my windshield and door windows on the snotty trails I typically ride.
Old 03-22-2024, 07:26 PM #175
Things are finally starting to come together. The new engine will arrive in a few days.
Can't wait to put this all back together.
Wegner Automotive NA 441CI LSX makes over 650HP on dyno! - YouTube
Old 03-23-2024, 08:00 AM #176
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Seems like a bit of overkill for the east coast off roading you do, but, hey whatever!
Old 05-08-2024, 08:55 PM #177
We needed to make a little more room for everything.
Actually the LS7 is smaller than the stock motor as is the th400. We had it all in and it required no cutting of the tunnel for the trans but maybe the transfer case.
Old 05-10-2024, 06:14 PM #178
Started the new frame today.
Old 05-18-2024, 10:39 AM #179
Stronger than stock.
Tube extends into stock frame plate welded to frame and then plated 5 sides2019 SAS 5th gen Build
axle , front , parts , rear , steering
2019 Supercharged 4Runner Complete Overland Build Narbeh For Sale: Vehicles 3 03-03-2022 01:22 AM
The MillerPKA 3.0 build - 2019 TRD ORP MillerPKA 5th gen T4Rs 45 04-18-2021 03:14 PM
Drobs' 2019 Off Road build Drobs 5th gen T4Rs 52 04-12-2021 08:25 PM
2019 ORP build and story thread ahtoxa11 5th gen T4Rs 0 03-31-2021 01:04 PM
My 2019 SR5 4Runner 4x4 Build to Date power818 5th gen T4Rs 0 01-07-2020 12:30 AM
