Old 06-01-2022, 03:30 PM #136
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
A few more photos from today. The rear wheels finally getting boxed in with sheet metal welded to the body.
Also looking to remove the arb front bumper as it's showing to be a weak point for what I'm doing. It's a fabulous bumper for most people just not working for me. I will list it for sale soon.
Will build a tube bumper starting with a hidden hidden winch mount. The bumper will tie into the mild exo cage which will complement my internal cage. All exterior tube will be 1.75" .188 wall.
Sent from my Pixel 5 using Tapatalk
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 06:05 PM #137
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
It will look better with a tube bumper IMO.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 06-04-2022, 04:52 PM #138
I did not dislike the ARB at all with the larger tires and trimming that we did it looked great, it's just not built for what I'm doing now with the truck.
Here's the start of the new tube bumper. Maybe one more small tube and then weld everything. This solution has moved my winch back a good 5-6".
Old 06-09-2022, 04:38 AM #139
Here is the final bumper. It will be sand blasted today and powder coated on Monday.
My lp9's have been frenched back into my remaining upper bumper.
Added the small skid if you will under the winch to protect the radiator. It's gusseted underneath. Also put a gusset on the fairlead.
Next week I'm off to AOAA in PA.
Old 06-09-2022, 04:39 AM #140
Correct photo
Old 06-10-2022, 03:38 AM #141
Budbuilt now has their new plasma cutter up and running and started using it today. What not quickly design, cut, and weld in some new frame stiffeners.
Naturally, the program was saved and can be run for anyone.
Old 06-14-2022, 03:09 PM #142
The new tube bumper is done. Just need to clean up some old wiring from the ARB bumper. It was powder coated matte cobalt just like my wheels. Probably have shortened the front at least 5".
Old 06-20-2022, 09:10 PM #143
Video of Tube bumper
here's a quick video I made of the tube bumper.
Old 06-20-2022, 10:15 PM #144
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Every time I go to Lenior I think about stopping at Budbuilt to see this for myself. Awesome build.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 07-01-2022, 06:08 AM #145
You should, it will not be there much longer. We are finishing up and tweaking some things.
Yesterday we decided that since I had a winch lying around from my LC200 we should do something with it. Therefore a new rear tube bumper with winch mount. It's tucked back as far as possible. The tube will only come out as far as the rear most point on the hatch.
My ARB front and LFD bumpers will be cleaned up and listed for sale very soon. someone can have a very good deal on them.
Old 07-06-2022, 07:04 PM #146
The new rear tube bumper is just about done. When it was started we cut out the second to last stock crossmember and only have one stock crossmember left. The rest are all overbuilt very stout cross members and a combination of tube and plate.
The new bumper has 3/8" plate 3.5" x 3.5" gussets across both sides. Then .188 and .120 wall tubing just like the front. A 3/8" plate across the frame chop and 8" gussets beside the winch. Finally 6 tubular supports to the frame of the truck as well.
The winch is removable when the hatch is open and is tucked back in as far as possible.
Between the new front tube and rear tube bumpers we have removed around 11.5 to 12" in total length. Naturally my approach and departure angle are even better now.
Old 07-17-2022, 06:29 AM #147
Here's a video of my new rear tube bumper. As luck would have it, I was out at Black Mountain in Harlan KY yesterday and used the rear winch twice; once for myself and once to pull another person up a big rock ledge. Hopefully I can acquire some videos of the big walls I climbed and share them here.
Old 07-17-2022, 07:47 AM #148
osugsxr osugsxr is offline
Old 11-07-2022, 05:41 PM #149
Well it's been a while and fun summer and fall of wheeling this beast.
Thinking of selling it or maybe a few more changes....
Old 11-07-2022, 05:48 PM #150
A few random photos from the past few months
axle , front , parts , rear , steering
2019 Supercharged 4Runner Complete Overland Build Narbeh For Sale: Vehicles 3 03-03-2022 01:22 AM
The MillerPKA 3.0 build - 2019 TRD ORP MillerPKA 5th gen T4Rs 45 04-18-2021 03:14 PM
Drobs' 2019 Off Road build Drobs 5th gen T4Rs 52 04-12-2021 08:25 PM
2019 ORP build and story thread ahtoxa11 5th gen T4Rs 0 03-31-2021 01:04 PM
My 2019 SR5 4Runner 4x4 Build to Date power818 5th gen T4Rs 0 01-07-2020 12:30 AM
