11-01-2023, 10:02 AM
#166
TH400 with Reid case. It was built by Maximum off-road transmissions in Southern California.
Sent from my Pixel 8 Pro using Tapatalk
11-17-2023, 09:34 PM
#168
Originally Posted by 4rNCMTNs
new rear driver side passenger door coming soon
11-18-2023, 06:25 AM
#169
. No need, it still opens and closes just fine. The window also operates just fine.
01-06-2024, 04:13 PM
#170
Everything is out of my vehicle and we are ready for what is next.
01-07-2024, 07:54 AM
#171
is next ??? is this a complete part out ? definitely one of the more interesting builds on this forum
01-07-2024, 09:45 AM
#172
Kind of like a complete part out of the stupid wiring harness, which all weighs at least 30 lb. Just for fun we're going to weigh it tomorrow. I may or may not put the stock seats back in as well. I actually listed them for sale this morning here.
My entire dash was removed and we are going to build our own aluminum dash. It will have my Holley pro dash, vintage Air AC and heat. Most likely a large GPS screen and camera monitor and who knows what else this point. Think of a full ultra-4 or trophy truck dash. It should be something much less than what Morgan Clark does and closer wide open designs fj40 build.
I sold my Atlas and have purchased a new transfer case which I will detail later and of course, I have the new engine and transmission going in. My entire stock drivetrain and engine has been sold.
May also cut some of the front tube work, and rebuild it to get the full up travel my truck is capable of.
Of course we'll be rewiring the entire truck again and it will be far more simple than the stock wiring system and multiple computers.
Installing new steering, transmission and oil coolers, and a new 32 gallon fuel tank.
I will give much more detail moving forward as we are about to start putting it all back together. The remaining parts are starting to arrive.
01-07-2024, 10:46 PM
#173
Real Name: Ron
Real Name: Ron
I think you should have bought a Trophy Truck and started from there.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
02-05-2024, 05:38 PM
#174
Sure, I could have started with Armada Engineering, Brenthel, etc, but that is well beyond even what i've spent and it's a purpose built vehicle different from what I do here on the east coast. would it work, probably but it would not be at home in SoCal bombing through the desert. I could have purchased a rock bouncer from BKOR or WOD, but I sure like my windshield and door windows on the snotty trails I typically ride.
03-23-2024, 08:00 AM
#176
Real Name: Ron
Real Name: Ron
Seems like a bit of overkill for the east coast off roading you do, but, hey whatever!
05-08-2024, 08:55 PM
#177
We needed to make a little more room for everything.
Actually the LS7 is smaller than the stock motor as is the th400. We had it all in and it required no cutting of the tunnel for the trans but maybe the transfer case.
05-10-2024, 06:14 PM
#178
Started the new frame today.
05-18-2024, 10:39 AM
#179
Stronger than stock.
Tube extends into stock frame plate welded to frame and then plated 5 sides
05-30-2024, 07:35 PM
#180
This week's update
A few photos from last week's work.
Motor mounts are fabbed up and we have the dry sump above the top of the new front frame rails.
The flex is crazy now and maybe my next set of tires will be the 46" USD's.
Rear windows are out and available. Replaced with aluminum and new things coming later this week or next.
Front a pillar bars in along with dash bar for new dash. Will add one more door bar to follow the top of the seat this week.
The trans, oil, and steering coolers should all be mounted this week.
My Howe steering pump mocked up and fits fine. My t/c pump should also be completed this week and mounted just off the ac compressor. This will run my hydro brakes.
Front motor cage should be completed this week and new adapter for the transfer case. Sometimes it sure is fun doing something others have not done yet.
