Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Old 04-08-2016, 04:38 PM #1
scanny's Avatar
scanny scanny is offline
scanny will become famous soon enough
scanny's Avatar
First issue with my truck, any ideas what's wrong?
Today I had my first issue with my truck. 2010 SR5 had no single glitch for 5.5 years and 123,000km, so I was really surprised when I saw "VSC OFF"
and "Check Engine" lights when I was going back home from work today. Just those two lights, nothing unusual in truck behaviour, today is dry though and VSC
wouldn't be active anyway.
At home first thing I had restarted the engine, but light were still on. So I got my OBD scanner and code was P0705. I deleted the code, shut down engine,
wait a little bit and started truck again. Both lights were gone. I moved back and forth on drivay, no lights.
I did quick search on the Internet and P0705 code is refering to Transmission Range Sensor Circuit Malfunction. Which is confusing because why then VSC Off light
came on and I didn't feel anything wrong with transmission.
So guys, any ideas what I can check and possibe try to fix before I give up and and surrended to a mechanic?
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
scanny is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 05:49 PM #2
mickeyblue mickeyblue is offline
mickeyblue is on a distinguished road
Did you check your gas cap? Mine did this when I got the plastic tab caught in the cap and it didn't tighten down correctly.
If it is loose, tighten it and then clear the code and drive it a bit.
mickeyblue is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 05:49 PM #3
SalsaRed's Avatar
SalsaRed SalsaRed is offline
SalsaRed is on a distinguished road
SalsaRed's Avatar
I can't answer your question as to what to check, but I do know about the VSC off light. That usually comes on along with the check engine light. I believe it's due to the fact that the computer doesn't have the complete control of the vehicle that it needs to control the VSC.
The same light came on for me when I got a CEL saying that I had O2 sensor problems. All it was was a leak from not tightening my Y Pipe down enough. Tightened it down, unhooked the battery for 5 minutes, and no more lights.
Brad
2010 SR5 Premium - 305/70/17 Nitto Ridge Grappler, WKO sliders, FN f(x) Pro, 5100's with Toytec coils, Camburg BJ UCA's and Toytec Superflex rear coils, Morimoto FX-R HID's, TRD CAI, 14” Magnaflow, URD competition Y-pipe
SalsaRed is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 06:41 PM #4
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
on toyota this is the neutral / park switch . check the connector at the side of the transmission on the assy . my have to change the switch assy.
catrains is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 06:48 PM #5
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
Rather than guessing as to what the problem is, why not pull the codes from the ecu to find out what it actually is?
Seems pretty straightforward to me, and free if you just go to your nearest parts store. Most all of them will read it for you while you wait, no charge, no hassle, get the code then come back here and search to see what solutions were to that specific code.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 07:00 PM #6
Blitzkrieg Blitzkrieg is offline
Real Name: Bob/Buckwheat
Blitzkrieg is on a distinguished road
I think he said he pulled P0705.
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL input)
"I speak three languages and liberal ain't one of them."
Blitzkrieg is offline   Reply With QuoteReply With Quote
Old 04-08-2016, 07:03 PM #7
Real Name: Chris
Real Name: Chris
Ahh, my bad then, missed that part of him finding code p0705.
Old 04-08-2016, 07:09 PM #8
I think Catrains nailed it. Pretty limited code as to issue thankfully. They aren't all that way.
I had an evaporative system fault on my 2002 T4R and it was a ***** to track down. Turned out to be a cracked charcoal canister above the fuel tank. Kudos to the unknown tech at Toyota that figured it out as I was stumped.
Old 04-08-2016, 07:16 PM #9
scanny's Avatar
scanny's Avatar
Yes, code is P0705 and if it transmission sensor I guess there's nothing I can do myself. I still have slight hope that since I didn't get any symptoms except lights it might be something simple. And VSC OFF light seems to be out of place if it's sensor dying...
Old 04-09-2016, 03:12 PM #10
Bonnies4runner2010 Bonnies4runner2010 is offline
Bonnies4runner2010 is on a distinguished road
Weird same thing just happened yesterday with the wifes 2010 87k. Same code. Hoping it's just some type of weird glitch and not a $1200 dollar repair.
Bonnies4runner2010 is offline   Reply With QuoteReply With Quote
Old 04-09-2016, 04:14 PM #11
scanny's Avatar
scanny's Avatar
I reset the code, it didn't pop up again, but I guess I'll have to take truck in shop if it happens again. Unless some knowledgeable folks give me any idea what I can check, like electrical connections or I don't know what. Let us know how your issue fixed..
Old 04-09-2016, 05:15 PM #12
I don't think this one will be difficult to track down.
Do you have an alldatadiy.com account?
Old 04-09-2016, 08:31 PM #13
scanny's Avatar
scanny's Avatar
Nope, don't have an account there. And I hope of course it something easy, but 4Runners are not common vehicles here and they don't break often so I would expect mechanics don't have much knowledge about T4Rs : )
Old 04-09-2016, 09:48 PM #14
Are you mechanically inclined or not so much? I really don't think this is much more than your shift selector switch (educated guess) but you'll have to know how to trouble shoot a bit. I can help you with that, but its tough long distance.
What I suspect is your switch is either dirty or wearing and its getting confused thinking you are in 2 gears at once. Again, should not be a huge deal to track down.
Old 04-09-2016, 09:55 PM #15
scanny's Avatar
scanny's Avatar
I'm not really mechanically inclined but I think I knew where the switch is I probably can try to clean it up. If it's deep in the engine and requires to remove bunch of stuff to get to it, I would probably take it to a mechanic...
Waiting for a tow truck. What's wrong with my 4runner? DanielW 4th Gen T4Rs 9 12-08-2015 10:30 PM
Valet, wrong truck LandCruiser Off Topic 9 06-21-2015 12:35 AM
Find what is wrong with this truck nissanh 3rd gen T4Rs 14 01-18-2014 07:29 PM
MPG Display Issue Any Ideas???? russthechamp 4th Gen T4Rs 9 03-18-2012 09:36 AM
Whats wrong with this truck? Sean7187 Classic T4Rs 10 10-13-2011 03:55 PM
