Old 10-27-2022, 01:12 AM #76
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Originally Posted by Rushthezeppelin View Post
I double checked and they are definitely SL
Your trail leaders were doing you a service by limiting your air-down pressure due to SL sidewall limitations.
5thToy is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 01:48 AM #77
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
I think they were more doing it out of caution on the sidewall height and them personally having no experience with these tires (I had some previous experience using them on my Nissan Rogue for winter driving, obviously smaller size and not airing them down). Is this an issue of (IIRC) these tires having only 2 ply sidewalls? What is probably the lowest you would dare to go in a rocky trail scenario?
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 01:52 AM #78
I think they were more doing it out of caution on the sidewall height and them personally having no experience with these tires (I had some previous experience using them on my Nissan Rogue for winter driving, obviously smaller size). Is this an issue of (IIRC) these tires having only 2 ply sidewalls? What is probably the lowest you would dare to go in a rocky trail scenario?
Yes, it is an issue of 2-ply sidewalls. They are generally not designed to be aired down for off-road applications.
Old 11-05-2022, 08:05 PM #79
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
Originally Posted by johnnygraphic View Post
I recall quite a few posts ago that some concern about the origin of manufacture came up. I checked this morning and they’re all made in the Far East country of Japan. FTW!!!
These are for the Falken Wildpeak AT3W in 265/70/17 LT E Load.
FWIW my Falkens (same same) purchased 7/22 were also made in Japan.
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 12:18 PM #80
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Just put these tires on (stock size, SL rating) from KO2 (stock size, C load). The Falken's are way better in the rain. A good thing living in rainy Vancouver Canada. Glad I made the switch!
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 12:29 PM #81
Ahab_BK Ahab_BK is offline
Ahab_BK is on a distinguished road
Finally replaced the terrifying stock tires after 35k with a set of these (including the spare). Stock size, SL rating. Standard mount and balance. No shake, shimmy, or shudder.
Ahab_BK is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 04:07 PM #82
mainerunr mainerunr is offline
mainerunr is on a distinguished road
Downside to the Falkens is they are heavy. I didn't worry about it with my F150 because it's pushing over 380hp and only weighs 5200# (plus all the crap I have in it).
Trading the F150 on a 4Runner though and at 100hp less and nearly the same weight, I am more concerned about weight. Still want an LT so I'm probably going with Toyo AT3's. I've run Toyo AT2's and Falken AT3W's and felt they were comparable. I've got General Grabber ATx now (because someone forgot to order the Falken's when I made an appt for tires) and they're ok on dry roads, ok in snow and not great in rain (the Falkens and Toyos were better all around).
(edit: and yeah, while I'm concerned about weight, not so much that I don't plan on going up to 275's before I drive it home...)
mainerunr is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 06:38 PM #83
Will_4R's Avatar
Will_4R Will_4R is offline
Will_4R is on a distinguished road
Will_4R's Avatar
Anyone run these in the Load Range C (285/70/17) which is made specifically to Jeeps OE specs? Heavy, like all Wildpeaks, but that added weight is added durability - especially in this specific size. The same size Duratrac in a load range D is 10 lbs lighter, but presumably a much weaker tire for off-roading. The Wildpeaks not only have a great reputation for a variety of on road/all terrain handling and traction, but also off road durability. Just wondering if the weight trade off is worth it over something like the Duratracs.
2003, Sport, V6, 4WD
Overland Warehouse/Radflo 2.0 suspension, SPC upper control arms
2016 Trail Edition w/KDSS
Icon Stage 2 suspension, BFG T/A KO2 285/70/17, C4Fab sliders
Will_4R is offline   Reply With QuoteReply With Quote
Old 11-09-2022, 07:30 PM #84
Mine are made in Japan as well.
Falken's Wildpeak 265/70R17 is the way to go-20221105_201533_resized-jpg
Old 11-09-2022, 08:24 PM #85
MrSmartypants MrSmartypants is offline
MrSmartypants is on a distinguished road
I run them 15 to 18 psi at the beach and 18 to 20 psi on the trail. Zero issues in either scenario. That includes running fully loaded on the White Rim Road and some trails on the east coast. Been a great tire so far.
Last edited by MrSmartypants; 11-11-2022 at 08:47 PM. Reason: Removed wrong info about sidewalls.
MrSmartypants is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 11:12 AM #86
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by MrSmartypants View Post
The 265/70-17 Wildpeaks in SL are a 4 ply sidewall, they don't make this tire in a 2ply sidewall.
No. It's 4 tread plies and 2 sidewall plies. Most passenger truck tires are 2 or 3 ply sidewalls. The tread plies are what go up as you go from SL, C, D, and E load ratings, usually 2 per rating.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 11-10-2022, 10:31 PM #87
Got it. Guess I misunderstood the spec sheet.
fit , stock , tires , venture , wise
FS: Brand New Set (4) Falken Wildpeak A/T3W 265/70R17 115T- $600 OC CA socal73 For Sale: Suspension/Wheels/Tires 1 06-03-2021 06:07 PM
Falken Wildpeak 265/70R17 Scaiza 4th Gen T4Rs 2 03-20-2019 08:34 PM
FS: Falken WILDPEAK A/T3W 265/70R17 115T - $600 (Los Angeles, CA) JTeam For Sale: Suspension/Wheels/Tires 1 12-07-2018 06:50 PM
FS: Socal (4) Falken Wildpeak AT3W 265/70r17 - $400 ayeyothisiskyle For Sale: Suspension/Wheels/Tires 0 07-23-2018 02:32 PM
