Old 07-04-2021, 04:08 PM #1
Unicorn's Avatar
Unicorn Unicorn is offline
Unicorn is on a distinguished road
Unicorn's Avatar
OME BP-51 FL Coil over noise
Installed new Bp-51s with new SPC UCA on weds. Took for an alignment on thurs and since then I have an awful click/clunk noise only from the front left coil over.
I rechecked all the bolts and they are torqued to spec. I’ve read if a few places this may be a valve issue with the BP51s.
Kinda lost and from searching there are a lot of post but no posted resolutions.
Any help would be appreciated, trying to gear up for a trip to Yellowstone and don’t want to have issues.
Trying to upload the video. May have to link it to a YouTube upload.
Unicorn is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 11:00 AM #2
Tieyota Tieyota is offline
Tieyota is on a distinguished road
When I lifted mine, the KDSS sway bar was tapping the skid plate. Ended up taking it off to notch it a little. Of course, this only applies if you have KDSS and you’d see the bare metal on the sway bar where it hits the skid plate.
Tieyota is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 01:20 PM #3
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Tip to help diagnose.
You can get some pretty good suspension movement without driving the vehicle by...
Stand on your slider, step or open door and stand on sill.
Grab the roof rack and rock the vehicle side to side...you can rock as hard as you want depending on the strength of your roof rack.
Have you pr someone under the truck while they rock...if u don't see it right away, ......placing you bare hand on different components will allow you to feel the noise and focus in on it. You can also use an automotive type stethoscope.
This is how I found my fox shock clunk.
Good luck
..let us know what it is.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:13 PM #4
hazards280 hazards280 is offline
hazards280 is on a distinguished road
FYI - early production BP-51s had an issue with clunking in colder climates. My first set of BP-51s were replaced under warranty as I experienced the issue here in Michigan. It was a very hollow clunk, almost as if I were hitting a bump stop and present whenever I hit even the slightest bump.
I see you're in Colorado and it's July, so you're not seeing the temps just yet, but it would be something to check into. ARB just asked for my serial number on the box and informed me mine were included in the range of affected units and exchanged them. Their customer service was spot on, so give them a shout and see what they say. Even if yours are not included, they may be able to help you out.
2015 4Runner TRD Pro - Inferno
2022 Wrangler 392 - Sarge Green
1964 Shelby Cobra 289 FIA
hazards280 is offline   Reply With QuoteReply With Quote
coil , lot , noise , post , upload
Question about coil over noise on street ahtoxa11 5th gen T4Rs 10 12-14-2020 09:07 PM
What is this bare wire on the coil igniter, and fluid in coil.? CCDave Classic T4Rs 2 12-08-2019 06:18 PM
Radflo / OW coil over noise thebwlife 5th gen T4Rs 38 01-11-2014 09:30 AM
Strange engine noise under load - bad coil pack??? jksmyers 3rd gen T4Rs 2 07-16-2011 09:09 PM
Squeaking noise by coil springs/sway bars? laureena23 3rd gen T4Rs 8 02-17-2010 02:33 PM
