Old 07-04-2021, 10:37 PM #1
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
DIY: Cheap Mud Flaps for 2021 Limited Nightshade
The factory rear mud flaps do not fit the Nightshade editions. The front mud flaps fit fine.
I purchased these from Advance Auto Parts (pn: 4322). They come as a pair. They are almost an exact match in plastic texture to the factory mud flaps so it doesn't bother my OCD that much.
For the holes I simply matched the factory mud flap holes, marked, and drilled. No pics of that process.
I used the the hardware that came with the factory mud flaps to attach the mud flaps. No new holes have to be drilled. You will need a longer screw for the inner most hole location. I used a long bolt and nut instead.
I also cut small washers out of the factory mudflaps to put under each screw so that the mudflap wasn't rubbing the Nightshade bottom trim.
Final results. A good fit. The good thing about making your own holes is that you can position the mudflaps higher, lower, canted, etc. by just drilling new holes. My "cant" was off a little so I had to redrill new holes. I simply left the middle bolt in, pivoted the mudflap out and drilled new holes. You may be able to see the old holes in one of the pictures. If I'd have known it was this easy I would have skipped the factory mudflaps all together and use these for front and rear.
DIY: Nightshade Mud Flaps
https://www.toyota-4runner.org/5th-g...ml#post3652762
Coat Hook Fishing Rod Holder
https://www.toyota-4runner.org/5th-g...od-holder.html
CharlesNellis is offline   Reply With QuoteReply With Quote
drilled , factory , flaps , holes , mud
2021 Limited Nightshade: Looking to do a leveling kit and some larger tires BarberJoeJr 5th gen T4Rs 63 12-29-2021 08:01 PM
2020 Limited nightshade help laqualo 5th gen T4Rs 21 08-22-2021 03:01 PM
Mud guards for 2021 Nightshade with running boards? Tedward 6th gen T4Rs 4 06-03-2021 09:20 PM
TRD OR or ORP wheels on Nightshade or Limited? CLTatenza 5th gen T4Rs 2 02-17-2021 03:24 PM
Purchase Complete - 2019 Limited Nightshade SCTrojans 5th gen T4Rs 42 12-11-2018 06:23 AM
