Old 07-05-2021, 05:14 PM #1
Sully888 Sully888 is offline
Sully888 is on a distinguished road
space between Diff Drop Kit and skid plate
So I lifted my '19 runner 3 inches a couple weeks ago. (OME up front and Toytec springs and 5100s in the rear). It came with a 1 inch front diff drop kit. I installed it today but the instructions were vague and probably wrong. They said I needed to install the skid plate spacers on the rear skid? (i am assuming the transfer case skid?) well, I did that and it seems like it didn't need it. However, the front skid appeared to need the spacers instead. So i installed the spacers on the back two bolts of the front skid and the front two bolts of the transfer case skid. However, even with that, the front skid still barely butts up against the front diff mount.
my question is, do you think having the skid plate up against the differential mount will cause any long term problems or rattling?
Sully888 is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:37 PM #2
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
I actually installed the Toytec diff drop on my SR5 and had the same issue. their instructions were terrible and I couldn't get a response through their email contact. Posted a message on FB group and got someone from Toytec to talk to me and they said the kit works but it obviously needs another set of bolts and spacers for the rear of the front skid like you mention. Mine touches the bottom of the diff "bars" but they are stationary so I assume it's ok since they don't move. I just went to the hardware store and got some longer bolts for the rear of the front skid. So far so good but I'm not happy with Toytec or their service.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 09:05 PM #3
bayaz bayaz is offline
bayaz will become famous soon enough
I have the diff drop kit under RCI skids. No rattling. They are close, but fit just fine. Held up great on trail too. And, correct, you only need spacers at the front bracket of the diff. Maybe middle too, but smaller ones.
bayaz is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 10:14 PM #4
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
you guys should just be happy I think I have the Dirt king Dif drop kit it has no instruction its just a small box of bolts and hardware. I have no clue where anything goes.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 11:13 PM #5
no instructions might be better than wrong instructions.
diff , front , plate , skid , spacers
Center Jack point on Skid plate after Diff Drop gigajoe 4th Gen T4Rs 2 09-02-2020 09:10 PM
Diff Drop and skid plate Ogre75 5th gen T4Rs 6 04-22-2020 03:08 PM
Diff drop installed, now front skid plate wont go back on RDOOGZ89 4th Gen T4Rs 9 02-05-2018 06:40 PM
Man-a-fre/4Plus skid plate with diff drop? pearlj10 4th Gen T4Rs 2 06-01-2013 12:59 PM
Diff drop bolt question - Skid plate issue 5280nrg 3rd gen T4Rs 7 10-13-2012 05:25 PM
