Old 07-06-2021, 02:35 PM #1
jlficken jlficken is offline
jlficken is on a distinguished road
Suspension upgrade w/ KDSS but without a lift?
I'm waiting for my '22 ORP to come in and was thinking that I'd like to upgrade the suspension a little bit for a better ride and even less nosedive than KDSS provides, however, I really don't want a lift.
I need the factory rake as I tow fairly often and plan on staying with the factory tire size.
At most I think I will put on a RSG Skid Plate:
2014 - 2021 5th Gen Toyota 4Runner Front Skid Plate W/ RSG Attached Lo
– RSG METALWORKS
Would this Bilstein 5100 Kit work? If so would I want to set it at the .85 setting for the added weight of the skid plate?
2010-2021 4Runner 4WD Bilstein 5100 Adjustable Leveling Shock Kit 10204RUN4WD
Does anyone sell a 5100 kit with the springs already installed?
jlficken is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 05:57 PM #2
– RSG METALWORKS
Wheelers and Offroad Warehouse will sell them pre assembled.
Old 07-07-2021, 09:04 AM #3
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
The factory TRD skid plate goes higher, almost to the bottom of the front bumper, than the one you are considering.
I find my stock SR5 has a good ride, certainly better than my Jeep Wrangler. Some say it is a bit wallowey, but that is a big blessing when going off road where there are a lot of rocks and holes. I suggest you try your new ORP off road before you change the suspension. You may find that you like it as I did with my SR5.
fkheath is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 09:08 AM #4
Thanks! I hadn't stumbled across them in my searches.
Old 07-07-2021, 09:11 AM #5
Yeah I had a '16 SR5 until about 2 weeks ago when I sold it to CarMax for a crazy price. I didn't dislike the ride, however, I didn't care for the nosedive.
I know KDSS is supposed to help with that but I kind of want to try a new basic suspension as well just because. I never did anything to the '16 so I want to tinker just a small bit.
I also just want a skid plate that allows me to change the oil without taking it off.
Old 07-07-2021, 09:23 AM #6
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
With a slight lift / upgraded coils (you could look at Dobinsons with a 1" front lift and 0-0.5" rear lift, or similar from someone else), you'll get less squat when towing as the coil rates are higher than the OEM coils.
The 5100's will work just fine, if you're looking for a slight level. Another combo is 5100's and aftermarket coils, but that does void the 5100 warranty.
I've got KDSS with 3" up front, 2.3" in the rear. RSG skid. The skid is great, has room for a diff drop if needed, with minimal clearance loss. I can load 400+ lbs in the rear of the truck and get about 0.5" squat (similar for tongue weight I'd assume). Drivability doesn't change with that weight in the rear.
If you're really towing a lot, I would look at adding airbags for towing needs to minimize squat.
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 11:00 AM #7
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Check out the Eibach Pro Truck lifts. Very similar to Bilstein 5100's and the the stage 1 comes with coils too I think. I've heard good things from them and availability is much better than Bilsteins. You can probably get the Eibachs within a few weeks where the wait time on Bilsteins is probably months.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 11:23 AM #8
I took a look at this kit - PRO-TRUCK LIFT SYSTEM (Stage 1) - TOYOTA 4Runner Base
From what I'm seeing though according to this PDF (https://eibach.com/us/pdf/327952) the lowest lift with the Eibach coils in that kit is 2.75" so wouldn't I actually skip the coils and use the OEM ones instead according to this PDF (https://eibach.com/us/pdf/327954)?
Old 07-07-2021, 11:56 AM #9
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Based on your original post, drive the new 4Runner for a while before you do anything. KDSS 4Runners definitely have different driving characteristics. They still have nose dive but not quite as bad but they handle better for sure. If nose dive bothers you, a simple shock upgrade is all you need and looks like all you want. The Eibachs I’ve read on some threads indicate they may have a slightly softer ride than the 5100 which may be a good fit for you? I have neither so I don’t know.
Definitely measure your stock hub to fender measurement to see where it’s at. My 16 Trail with KDSS has alway had more rake than most. 2.5” hub to fender difference rear to front. I don’t know if KDSS affects that or not…?
Here is the Eibach front shock only. In stock…
PRO-TRUCK SPORT SHOCK (Ride Height Adjustable Single Front) - TOYOTA 4Runner Base
Rears. Not in stock but you’re waiting anyway…
PRO-TRUCK SPORT SHOCK (Single Rear for Lifted Suspensions 0-1") - TOYOTA 4Runner Base
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 12:04 PM #10
Good to know...thanks!
Old 07-07-2021, 12:04 PM #11
Has anyone used these before? I kind of like the idea of being able to adjust for towing and then set it back to normal when not towing.
Falcon Shocks Suspension Lift Kit for 5th Gen Toyota 4Runner - Overview
ETA: Falcon says no KDSS with the above kit just an FYI.
factory , kit , plate , skid , upgrade
Digressive or Progressive? KDSS Suspension Upgrade Help Please Teephud 5th gen T4Rs 9 06-19-2018 02:18 PM
Questions:Suspension upgrade for KDSS turbohardtop 5th gen T4Rs 2 06-15-2018 03:10 PM
What is the best suspension/lift with KDSS 4High4Low Off-Roading 0 06-11-2018 12:13 AM
2014 Trail edition kdss suspension upgrade Nerves 5th gen T4Rs 34 11-12-2017 12:55 AM
TRD Off Road with kdss or upgrade suspension later voland 5th gen T4Rs 19 02-05-2017 07:06 PM
