Old 07-12-2021, 11:45 AM #1
jlficken jlficken is offline
jlficken is on a distinguished road
Falcon Tow/Haul suspension w/ KDSS?
Has anyone installed this kit on their KDSS equipped 4Runner?
2010+ Toyota 4Runner: Falcon 2” Sport Tow/Haul Shock & Spacer Lift System - TeraFlex
I've been in touch with Teraflex and they seem confused about what their kit actually works on. They said that the bushings weren't sized right for KDSS (which is actually only an X-REAS issue) and couldn't tell me if it'd work with KDSS.
I don't see why it wouldn't but I'm leery to spend money on their product when they don't even know what it fits.
jlficken is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 02:50 PM #2
streetsyndicate streetsyndicate is offline
streetsyndicate is on a distinguished road
This kit will work fine with KDSS. It's the same concept as bilstein 5100 but a much higher quality product. Installed about a month ago on mine with KDSS and it really is a great set up.
streetsyndicate is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 09:54 PM #3
CITYRNR's Avatar
CITYRNR CITYRNR is offline
Real Name: Ben
CITYRNR will become famous soon enough
CITYRNR's Avatar
Real Name: Ben
I wonder how much it prevents sag. I’m basically level right now and when I tow the back end always is lower. Pisses me off.
2019 TRD ORP w/ KDSS (Silver) - 6112/5160 w/ SPC UCA, Full+Fuel RCI Skids, SSO Sliders, C4 Lo Pro w/ X20
CITYRNR is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 11:47 PM #4
4Reak Show's Avatar
4Reak Show's Avatar
I could be seeing something wrong here but the kit listed is just spacers and shocks? Yeah if that’s the case, a shock’s purpose is NOT to raise a vehicle. It’s to control the speed at which the suspension travels... so it looks like you’re getting fancy shocks and some poly spring spacers for $1600? Seems a little high but inflation has been outrageous.
We tow a 3500 lb trailer often and we not only use a weight distribution hitch (which places weight back on front wheels) but also added the firestone airbag kit. I only inflate to like 15 psi (max kit spec is 30) and my set up is just about perfectly level when fully loaded, maybe a touch low in back.
Then when not towing, just deflate the airbags a bit and the ride is back to stock. And I’m fairly certain the airbags will work with a lift, and you just cut out less of the stock bump stops to accommodate?
issue , kdss , kit , work , x-reas
TerraFlex Falcon suspension? Joelicious 5th gen T4Rs 24 07-07-2021 04:26 PM
TRD Pro Fox suspension on KDSS? bigbadpoppa 5th gen T4Rs 2 09-14-2020 04:32 PM
TRD Pro Suspension on ORP w/ KDSS mlnhtrang 5th gen T4Rs 8 10-13-2018 03:29 AM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
F & R Suspension for 5th gen w/ KDSS NZDZRT Want to Buy/Trade 0 01-13-2016 12:32 AM
