Old 07-14-2021, 12:34 AM #1
nx80000 nx80000 is offline
nx80000 is on a distinguished road
Steering Correction After Lift Install
I recently installed a lift on my 2017 TRD Off Road with KDSS. The lift is 2in front, 1in rear. It is a dobinsins kit. I also installed JBA UCAs to add caster. I have noticed that after installing the lift and getting an alignment (Caster at 4.5) while turning right close to full lock, the wheel will pull hard right into the lock rather that pulling back towards center. Some tire scrubbing can be heard as well. I'm wondering if anyone has seen this and whether there are any options for steering geometry corrections with a lift?
nx80000 is offline   Reply With QuoteReply With Quote
Old 07-14-2021, 06:41 AM #2
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
How do the toe and camber settings look on the alignment print-out? I would start there and make sure they are close to factory specs.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 07-14-2021, 10:49 AM #3
Camber is -0.1 and 0.3, Toe is 0.08 and 0.09.
Old 07-14-2021, 01:48 PM #4
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
TO OP: I am not an alignment specialist by any means… so IMHO: I would recheck all suspension points (bolts\nuts) and make sure nothing is loose and torqued to spec. If it is and alignment numbers are true (nothing moved after alignment reading was taken), then I would try to reduce caster to be under 4... (make it 3.5)
Just FYI: I have very similar lift (2.1 front, 1.5 rear with KDSS) with OEM UCAs and I have no issues at all.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 07-14-2021, 02:07 PM #5
biratley biratley is offline
biratley will become famous soon enough biratley will become famous soon enough
What ever the tire is scrubbing on is pulling the wheel
Sent from my iPhone using Tapatalk Pro
biratley is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 01:08 AM #6
The tire is not making contacting with anything. They are still stock size. The tire scrubbing I'm referring to is across the pavement.
Old 07-15-2021, 03:24 AM #7
Sully888 Sully888 is offline
Sully888 is on a distinguished road
just fyi I lifted my 4runner 3in in the front and 2in inches in the rear with jba UCAs a couple weeks ago. At first (driving to brake masters for an alignment), it drove perfectly (but i still believed i needed an alignment). I went to brake masters and they set the caster to 4.1ish. now it pulls to the left a little. I always had intentions to take it to a real 4wd alignment shop and that is tomorrow. I will tell you how it goes.
Sully888 is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 10:49 PM #8
I don't have a 4wd shop locally. It can take a couple tries. The shop I went too suggested letting the suspension settle a little then returning. It did settle noticeably over a couple weeks. The second time around I got a more experienced tech who got the alignment dead on. Now though I'm wondering if I had them push the caster too high based on the the weird characteristics I described. I will probably have them set it to 3.5 caster when I get new tires soon.
Old 07-15-2021, 11:21 PM #9
yea I'm not sure what they did, they said they made some adjustments as it was still slightly off. Either way, it runs smooth now.
Old 07-29-2021, 02:28 AM #10
NorCal4run NorCal4run is offline
NorCal4run is on a distinguished road
I do my own alignments at home and I prefer to set my Camber at 0.0 on left front and 0.0 on right front. Caster between 3.0-3.5. Good luck
NorCal4run is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 03:02 AM #11
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I'm curious how you do them at home. I'd love to attempt my own alignment and find what best suits me. Paid for too many alignments over the years.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 02:16 PM #12
You can buy all the tools needed on Amazon and there is a lot of how to videos on YOUTUBE. Its not black magic but it can be very time consuming. I can say no wheel alignment shop has done a good job on my cars over the years so I started doing them. Very happy with my results.
DG
caster , installed , lift , lock , steering
Panhard Correction Kit install - Shout Out to @eimkeith DaMonkey 3rd gen T4Rs 4 07-18-2018 12:29 AM
Panhard correction kit install Dezerts10 3rd gen T4Rs 22 05-24-2018 08:59 PM
Panhard correction bracket or bar to fix bumpsteer with mild lift? JohnOfTheJungle 3rd gen T4Rs 38 02-13-2018 01:17 AM
2.5/1.5 lift lean correction HCWatson997 4th Gen T4Rs 12 02-08-2018 04:43 PM
Best Driver's Side Lean Correction Spacer for use with Toytec Ultimate Lift? EdmundGTP 4th Gen T4Rs 11 06-25-2013 09:22 PM
