Old 07-17-2021, 09:18 AM #1
apache67 apache67 is offline
apache67 is on a distinguished road
5th Gen Front-end Components
Guys,
Through our collective experience here, what front-end components tend to wear out with time first? (excluding shocks).
Through normal everyday; no hardcore offroading use.
Cheers,
Greg
apache67 is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 11:41 AM #2
Ascole Ascole is offline
Ascole will become famous soon enough
2011 SR5 w/ 165000 miles
I’ve replaced inner/outer tie rods, sway bar bushings and endlinks, and obviously tires/brake pads/rotors from standard wear and tear. I need to replace the outer tie rods again as well as my lower control arms
Ascole is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 11:44 AM #3
Did you do all this work on your own or did the dealership do the work?
Old 07-17-2021, 01:06 PM #4
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Replace outer tie rods again? I had a wheel alignment on my 2011 two months ago at 118,000 miles. The only suspension parts that have been replaced are the shocks and front springs for a 1 inch lift.
DougR is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 04:32 PM #5
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
262K miles with a decent amount of off-roading and no need to replace tie rod ends, lower or upper control arms and ball joints.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 01:33 AM #6
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
My outer tie rod ends are showing a bit more grease every time I look. Is there front end maintenance I should be doing besides looking for wear?
1000MPH is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 08:35 AM #7
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I'm on my 17th Toyota 4x4 and I don't think I have ever replaced a ball joint or tie rod on any of them that wasn't over 20 years old. Unless I was modifying them of course. On my 11 I did urethane lower control arm bushings about six months ago because the stock ones were way too soft in my opinion. And they looked all cracked. But they were actually fine. I've done urethane sway bar bushings too and of course 5100's and Eibach springs, JBA uppers... All that fun stuff. But stock lower ball joints and tie rod assemblies as well as sway bar links at 92k doing just fine.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 12:08 PM #8
I replaced the tie rods initially because of some creaking and popping noise up front. Both outer tie rod boots were worn out and not holding any grease. Since I was replacing the outer rods I figured I’d just replace the inners too…did everything myself.
I now have to replace one of the outer tie rods because something tore one of the boots and is leaking grease.
Was actually the same with my endlinks. Initially replaced them because my lift but turns out the grease boot on both endlinks were torn in half.
Never had to replace any joints on my 2005 Tacoma, maybe just unlucky with my 4runner. Or maybe it’s the countless miles on corrugated FS roads…who knows. My 4runner also sits outside for at least 4 months a year in the fall and winter in Seattle so that probably doesn’t help? Good thing tie rods are cheap and take 10 minutes to install.
Old 07-19-2021, 01:51 AM #9
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Bushings will wear out first if we're talking about only daily driving. LCA bushings, sway bar bushings, etc.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 01:06 PM #10
1000MPH's Avatar
1000MPH's Avatar
Is there a better thread on replacing KDSS sway bar bushings?
I’ve seen a couple with this one giving some instructions.
how hard is it to replace sway bar bushing kdss?
Looks like the only thing to be careful with is the KDSS piston.
As long as the bar doesn’t go boing when I remove the bolts I think I’ll be comfortable.
KDSS Front Sway Bar Bushings
FRONT STABILIZER BAR, LEFT; FRONT STABILIZER BAR, RIGHT.
4881560320 MSRP $ 21.58 qty: 2
FRONT STABILIZER LINK, LEFT; FRONT STABILIZER LINK, RIGHT.
4884960041 MSRP $19.16 qty: 2
Old 09-03-2021, 06:42 PM #11
all it will do is fully extend at a slow predicable rate. you can hold it up with a jack or a strap. its just hydraulic pressure
Old 09-04-2021, 01:16 AM #12
1000MPH's Avatar
1000MPH's Avatar
Thanks. I had developed an occasional creak in my front end on my last road trip. I looked around and everything looked good, felt solid. Last week I did a quick trip up Deadman’s Pass in Mammoth before they closed the forests. No more squeak. Turns out my truck just missed the dirt.
Old 09-05-2021, 09:44 PM #13
L1011's Avatar
L1011 L1011 is offline
L1011 is on a distinguished road
L1011's Avatar
My steering rack leaked and had to be replaced ~70k miles. Needless to say, I wasn't too happy about that. My 4R is a mall crawler/commuter and never abused.
L1011 is offline   Reply With QuoteReply With Quote
5th , cheers , components , front-end , time
Bushings recommended for front end components? cognus 4th Gen T4Rs 1 09-07-2019 02:14 PM
Front Bumper Components mstpn2 5th gen T4Rs 0 07-06-2018 08:23 PM
FS: 3rd Gen Front bumper components (new $250); OEM jack kit (used $100) - NE MS pendragon For Sale: T4R Items 0 07-11-2016 10:29 PM
WTB: 4th gen front end suspension lift components 03 T4R Limited Want to Buy/Trade 0 07-24-2013 01:26 PM
