Old 07-17-2021, 07:59 PM #1
Gstick Gstick is offline
Gstick will become famous soon enough
wheel ?
If I were to use a 17" x 7" OEM SR5 wheel vs a 17" x 7" OEM TRD Pro wheel with 255/75/17 pizza cutters would I have rubbing issues with stock suspension ?
Correct me if I'm wrong but the TRD Pro wheel has more offset which pushes the wheel away from the vehicle.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 09:37 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
The TRD Pro wheel has 8mm LESS offset (4mm) than the 7” wide SR5 wheel (12mm), which pushes the wheel away from the vehicle. (In 2014, the SR5 wheel width increased to 7.5”.)
I don’t have a 5th gen, but you won’t have rubbing issues with either wheel. The 7” wide SR5 wheel doesn’t rub with a 265/70r17 tire, and the TRD Pro wheel will be 8mm farther out than the SR5 wheel. The 255/75r17 tire is only 1/2” taller than the 265/70r17, or only 1/4” taller on each side. The 255 tire is narrower than the 265 tire, so the 255 tire won’t rub on the suspension if the 265 doesn’t.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 11:17 PM #3
Thank You for correcting me on the offset.
I assumed that since the SR5 wheels were tucked in a little, that the pizza cutters (1/2" taller) might rub the mudflaps.
I think that I will pick up a set of used SR5 OEM wheels & run the BFG KO2 255/75/17 on my TRD OR for the winter.
oem , pro , trd , wheel , wrong
Stock wheel & suspension with wheel spacer: 275/60R18 or 265/65R18 tire? skywalker1020 4th Gen T4Rs 5 12-13-2023 08:35 PM
WTT: 2019 SR5 wheel+tires (250 miles) for Black wheel-AT Tire combo ToyoRuski Want to Buy/Trade 0 11-10-2018 11:23 AM
WTT: 2019 SR5 wheel-tires (250 miles) for Black wheel-AT Tire combo ToyoRuski For Sale: Suspension/Wheels/Tires 0 11-09-2018 07:54 PM
FS: 5th Gen N-FAB Wheel-to-Wheel Nerf Bars $300 Michigan (Metro Detroit / Boyne Area) Boyne4R For Sale: T4R Items 0 08-22-2017 01:13 PM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
