Old 07-19-2021, 03:44 PM #1
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
Total Chaos +2 “ LT for KDSS
All I can tell you is this kit is the sh#t. Rides so nice perfect for daily driving as well. Stock travel is just so bad. Extended travel is just ok. This is sooo perfect and depending on the wheels and tires you don’t need glass.
With that said I’m moving up to 35s and will be customizing the whole inner fender area to gain maximum full bump travel.
3.0 triple bypass custom valving , stainless shafts finned resis for the secondary shocks. She boogies
dom42 is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 04:38 PM #2
sexual
Old 07-20-2021, 10:57 PM #3
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
@Whippersnapper02
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 11:33 AM #4
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
hey which part were 3.0s? the secondaries? what about the coil overs?
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 11:37 AM #5
usdmej usdmej is offline
usdmej will become famous soon enough
is it up travel or down travel (or both?) that you gain by going LT for this platform?
also, how is KDSS affected by all of this? i read max lift height recommended was +2.5" for KDSS 4runners until someone could figure out a pivoting sway bar mount solution?
usdmej is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 01:19 AM #6
Secondary
Old 07-24-2021, 01:23 AM #7
Yeah that was me who came up with some drop blocks for the rear at the same time some one else was already working on the idea I just kinda made it happen first with out knowing Kyle from treatyoak was actually doing it too.
You gain travel from the arms being slightly longer. You gain both up and down travel. I’m running 34s so I have to do some major work to have full compression. Which it’s going under soon. Then you want limit straps to prevent the shocks from topping out. The kit comes with adjustable setup so as the straps stretch over time you can adjust.
Kdss mounts are exactly the same distance as the stock mounts from the pivot points.
Old 11-03-2021, 08:35 AM #8
Cutting up the fenders so I can get full bump on 35s.
Old 11-03-2021, 10:40 AM #9
so since the kdss sway bar attaches farther in on the new LT LCA's, does that mean it has less leverage and is less noticeable even when running with the switch turned "on". i'm sure its spring rate is less now that the arms are wider but the sway is the same. just curious.
Old 11-03-2021, 01:42 PM #10
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
So what is your set-up in the rear?
Old 11-03-2021, 04:19 PM #11
custom spec bypass shocks from king i believe.
i believe his next goal is to do the califab 3 link.
Old 11-06-2021, 12:27 AM #12
It’s mounted exactly same distance from the lower arms pivots. It’s still affective.
Old 11-06-2021, 12:28 AM #13
Yea some 2.5 3 bypass’ and will be getting 12” stroke 3.0 3 bypass and 3 link. And yes keeping the kdss.
Old 11-06-2021, 12:36 PM #14
yea i got that, but the tire is farther away creating more leverage. just curious
Old 11-06-2021, 04:46 PM #15
SoCalDriver SoCalDriver is offline
SoCalDriver is on a distinguished road
Please post pics when it’s all done
SoCalDriver is offline   Reply With QuoteReply With Quote
i’m , maximum , moving , perfect , travel
Total Chaos UCA Chilow 5th gen T4Rs 4 09-20-2017 08:29 PM
Total Chaos UCA help SouthAl 4th Gen T4Rs 4 10-02-2016 03:59 PM
Help - Total Chaos UCA tdsmither 4th Gen T4Rs 7 02-04-2015 08:44 AM
total chaos uca kjeisner 3rd gen T4Rs 1 03-13-2012 12:13 AM
Total Chaos ric Off-Roading 7 10-29-2009 12:28 AM
