03-04-2012, 06:01 PM
Estimated Front Brake Pad Life?
Does anyone have any input to how long the front pads should last? I know it will depend on how you drive and other factors, but I am looking for a rough estimate. I currently have 25,000 miles on my 2010 SR5.
2010 SR5
03-04-2012, 06:41 PM
What was the last mm's they gave you at the dealer when you were in for service?
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
03-04-2012, 08:17 PM
I will have to check the paperwork, I am not even sure if they checked the brakes when they did the service.
2010 SR5
03-04-2012, 08:38 PM
If the dealership did your service I would be shocked if they did not! I get a 'form' when I walk out showing their 'inspection' of the 4R, including the mm's left on each pad (now whether what they write here is true is another argument).
03-04-2012, 09:52 PM
On the Taco I would get 50-60 thousand miles, would expect similar or slightly less on the T4R. If you don't know to downshift on grades when driving in the mountains, you can probably cut that number in half.
03-04-2012, 10:24 PM
on my last service at 32,000 km (20,000 miles) dealer report shows that front pads is 9.2 mm (0.36 inches) and rear pads are 7.4 mm (0.29 nches). They said it's a little bit less than half of pads life, I hope that won't have to change pads at least for next 20,000 miles.
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
06-14-2012, 05:46 AM
My truck has about 32000 miles on it now and I finally had time to check the front pads, they still have a lot of material left. I tow a camper and drive in the mountains frequently and the pads still look like they have at least another 15-20K miles left.
2010 SR5
06-14-2012, 06:53 AM
Real Name: Patrick
Real Name: Patrick
I'm currently at 52,000 and my brakes were in the 7's.....and that was 5000 miles ago.
I think I may get to 60-65 before they need it.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
06-14-2012, 09:06 AM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
I currently have 35K miles on mine with the pads 1/2 gone. I will get 55-60K before changing. Driving conditions matter...a lot. Mine is mostly interstate.
06-14-2012, 09:10 AM
just had the 30k service done and they said my pads still looked new
06-14-2012, 11:46 AM
Real Name: Ken
Real Name: Ken
Yeah, me too. I also just hit 30k on my 2010. The pads are still very good, and I expect another 20-30k more miles. I'm amazed about how long brake's last these days. My 4th gen never needed brakes the entire time I owned it, in fact, I traded it in on my 5th with 60k (or so) miles on it.
2010 Limited Magnetic Gray Metallic
with Navigation system
11-03-2012, 09:28 PM
Per the dealer I have 8-9 mm left at 15k.
Does anyone know how many mm a brand new pad has?
[SIGPIC][/SIGPIC]
2011 4R TE | Shrockworks Rock Sliders | WeatherTech floor liners | Doors side molding | Exhaust tip | Door edge guards | Wet Okole seat covers | Hood protector | Canvasback cargo liners
11-03-2012, 09:33 PM
Mine went for over 40k including over 5k pulling a 3000# camper. I did not measure them before trade in, but I would expect most to get more than I did.
2017 Crewmax / 1794 / TRD Off-Road / 4x4 / 5.7 / 5100's / AAL / TRD Pro Duals / 275-70 Duratracs
Hampshire, Yorkshire, and Duroc Hogs / Rockwood 2280BH / and Kioti CK2610 in tow
Rest in Peace SeattleMike
11-03-2012, 10:12 PM
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
27175 miles on my 2011 LTD, went in for dealer services Wednesday pass, brake-pads were 8mm fronts, 7mm rear, tires were 10/32nds all around with 35psi. Everything's green on the inspection form.
2011 LTD, Magnetic Gray Metallic, Solid Black Interior, LB22, NAV, Slide Out Cargo. Door Vent Visors, Hood BugflectorII, Sunroof Visor, full window tint, including moon roof. 3M Paint Protection Film, full front, side mirrors, A-Pillars. Remote Start. Every option available on a Limited, 20x9 KMC Chrome Wheels, 275/55/20 Goodyear Eagle LS2s, drilled, zinc-dipped, rotors. Owned a T2-SR5, T3-LTD, and now my T5-LTD.
11-04-2012, 09:02 PM
At 60,000 mine were 6mm front and 8 mm rear. I've put on more than 10000 miles since then and the brakes are still fine, no squealling yet.
I'm planning on replacing my rotors along with my pads when the time comes. I'm getting some pulsing when heavy braking. I'm checking the brakes when I rotate my tires and they still look like they have plenty of life.
2011 Blizzard Pearl SR5 - 4x4
