Old 07-21-2021, 11:55 PM #1
bzettler83 bzettler83 is offline
bzettler83 is on a distinguished road
Heavy Vibration From Rear Of Vehicle
05 T4R - 185k miles - V8 -
My 4runner has had a fairly noticeable vibration from the rear of the vehicle for sometime now and I am finally to a point where I want to correct it. It is noticeable above 60MPH and is to the point where the passenger seat shakes fairly bad. Much MUCH more than you would consider normal.
-Removed the rear drive shaft and drove it. Vibration still there.
-Balanced tires, and rotated as well, no change. In fact rear tires are NEW.
-Removed wheel spacers, no change.
What else should I be looking at? Could it be a bearing, bad shock / shocks? I have Bilstein's and they are fairly new so I am ruling that out at least for now.
Trying to ID this myself where possible. Worst case I will bring it to a mechanic.
2005 Toyota 4Runner Sport 4WD - V8 - Toy Tech Boss 3" Lift - 1.25 body lift - 40 inch LED Light bar mounted to roof rack - HID Lights - K&N CAI - Cat Back Exhaust - 285/70/17 BFG KM2 - Air Lift 1000 Rear Air Bag Set Up - Diff Drop Kit - Total Choas UCA's, Total Chaos Spindle Gussets, Zip Locker with ARB Compressor, Pioneer AVIC Z150bh w/ back up camera, More to come.
bzettler83 is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 12:38 AM #2
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Is your rear axle off center?
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front, IMS59-50705 & C59-325 rear; Dobinsons diff drop; Ironman UCAs; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 12:40 AM #3
I suppose anything is possible. What would cause that? Worn bushings or something. Would there be an easy way to check this?
Old 07-22-2021, 08:33 AM #4
mo_mo mo_mo is offline
mo_mo will become famous soon enough mo_mo will become famous soon enough
You might have better luck posting in the 4th gen section of the forum.
Have you checked your body lift and suspension?
Does the vibration change above 60? Does it change depending upon engine rpm / transmission gear selection?
What tire pressure and load range (P, LT C, LT E...) are you running?
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4í Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers | 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 10:03 AM #5
CutthroatSlam CutthroatSlam is online now
CutthroatSlam is a jewel in the rough CutthroatSlam is a jewel in the rough CutthroatSlam is a jewel in the rough
I stopped at "removed rear drive shaft and drove it."
CutthroatSlam is online now   Reply With QuoteReply With Quote
Old 07-22-2021, 10:27 AM #6
I agree 100%... I posted here by accident, but left it considering the 4th and 5th gen are extremely similar when it comes to the under carriage.
- no change in gear selection or neutral at speed. Seems to get slightly better as you approach 75-80 but still present
- Running 275/70/17 BFG KM3 LT - 40 PSI I believe
- I will run through and check all body mount points to ensure they are secure.
Old 07-22-2021, 10:29 AM #7
I get the initial reply however this is a fairly common DIY diagnostic method. You simply lock the center diff and you are good to go. Obviously I would never do this long term, and would not drive under any heady load / acceleration.
Beats paying a shop to pull the drive shaft and check the balance.
Old 07-22-2021, 10:57 AM #8
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
How old is your lift? It could potentially be a worn-out shock and that one side is bouncing all over the place.
2005 Sport Edition Build Page
2017 TRD Off Road Premium
PSA: Stop Quoting Pictures
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 10:59 AM #9
dezertbomber dezertbomber is offline
dezertbomber will become famous soon enough
He said his rear Bilsteins were new'ish.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 11:02 AM #10
Real Name: Doug
Real Name: Doug
Missed that.
Old 07-22-2021, 01:57 PM #11
Tuco S.'s Avatar
Tuco S.'s Avatar
It's quick and easy. Take a tape measure and measure from the frame rail to the shoulder block on your rear tires, both sides. Since yours is lifted that much it may cause the rear end to be off center unless you have an adjustable panhard rod.
I'm at 2.7" rear lift and mine was about a 1/4 inch off center after I installed the lift. Didn't measure it on the stock suspension though, unfortunately. It would have been nice to have a before measurement.
You may also have some worn out links. Worth checking them all.
Old 07-22-2021, 02:39 PM #12
Lift up the rear so the susp droops then push hard forward and aft one side at a time, see if the linkage has any looseness.
Check torque on body lift mounts.
Is it vibration or oscillation? If oscillation, can you tell if it's side to side or up and down?
Old 07-23-2021, 02:44 PM #13
mrblah mrblah is online now
mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of
Had that problem once...was driving to the desert
Dropped off my ex-wife and her new boyfriend in the middle of the desert, didn't have any more vibrations driving home. Problem solved.
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
mrblah is online now   Reply With QuoteReply With Quote
Old 07-23-2021, 02:56 PM #14
GCT4R GCT4R is offline
Real Name: Jeff
GCT4R is on a distinguished road
Real Name: Jeff
I would also check if your wheel bearings are bad, usually you can hear it.
GCT4R is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 05:42 AM #15
Wacky Wick Wacky Wick is offline
Wacky Wick is on a distinguished road
Did you road force balance those sneakers ?
Wacky Wick is offline   Reply With QuoteReply With Quote
change , fairly , point , rear , vibration
HEAVY vibration in 4x4. cccolin 3rd gen T4Rs 1 10-10-2019 01:26 PM
Toytec Boss - Vibration Diagnosis - Pic Heavy sport05 3rd gen T4Rs 42 08-27-2015 10:55 PM
Bad vibration under heavy acceleration? akbass907 3rd gen T4Rs 3 01-27-2014 06:31 PM
Heavy vibration at idle fluffeh 3rd gen T4Rs 7 10-23-2012 12:49 PM
steering shimmy and whole vehicle vibration Tina Champion 3rd gen T4Rs 1 07-21-2007 11:48 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
