Old 07-22-2021, 02:38 AM #1
Sully888 Sully888 is offline
Sully888 is on a distinguished road
sway bar creaking noise?
So i just installed a OME lift up front with Toytec rear springs and 5100s on the rear. Everything worked fine and it has been about a month. Today i noticed a creaking sound coming from the rear. I think it is coming from the rear sway bar rubber bracket. Do you know if the sway bar rotates within this bracket as the suspension moves up and down and is this something i should be worried about? this is a 19 runner with no kdss.
Sully888 is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 08:56 AM #2
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
It does rotate, yes.
The only way to know for sure is to remove the bar and see if the noise goes away.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 06:18 PM #3
aweaver65 aweaver65 is offline
aweaver65 will become famous soon enough
Check your Front Sway Bar where it is close to or touching the Skid Plate Bracket
Check two things:
  1. 1. The Sway Bar at the front where it may be rubbing on the driver's side Skid Plate Bracket. I have an ICON Stage 3 and it was binding up there. I had to drop the driver's side bracket with two fender washers at both ends.
  2. 2. Check where the E-Brake Cable routes through an eye loop that is bolted to the rear lower trailing arm. You can bend that bracket a bit and/or spray some silicone in there.
I had BOTH of these issues on mine.
Good Luck!
2020 Army Green TRD Pro, RSG Flat Sliders. SV.4 LED's from Headlilght Revolution, RAM Mount for Cell Phone (got my cup holder back!), Deleted Roof Rack (sold). Canvas Back full Cargo Liner (for my Dog "Donkey")...
Icon Stage 2, Body Mount Chop, Method MR305's and BFG KO2 285/75/17's (No rubbing at all)
aweaver65 is offline   Reply With QuoteReply With Quote
bar , bracket , coming , rear , sway
LCA creaking noise jonb2 4th Gen T4Rs 4 12-31-2018 08:30 PM
Help, creaking noise front end Rwm514 3rd gen T4Rs 5 12-12-2018 09:30 PM
Creaking Noise Gesekee19 5th gen T4Rs 15 09-17-2017 03:31 AM
4th gen Creaking Noise hufflite Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-06-2014 11:21 AM
Creaking noise from the undercarriage Spnix77 4th Gen T4Rs 3 01-18-2007 01:53 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
