Old 07-25-2021, 09:01 PM #1
Jake1222 Jake1222 is offline
Jake1222 is on a distinguished road
Strange noise, help diagnose?
2019 4runner, less than 20,000 miles. Alright so here’s the details:
I had a Toytec suspension kit and BFG Ko2 285/70/17 tires installed on my truck the other day, and I noticed this strange sound after driving off. I would describe the sound as sounding somewhat like an airplane, or perhaps a humming sound. It only begins above roughly 25mph and you can also hear it when decelerating. No change in the noise when turning, and I highly doubt the wheel bearings are an issue whatsoever. So this leads me to believe it’s just tire noise.
Has anyone ever experienced anything similar? Is this normal tire noise or perhaps a balancing issue? Any other ideas?
Jake1222 is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 10:18 PM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
If it is constant after 25 it is probably the tires. I use to have KO2’s before and they made very little noise. I switched to Falken Wildpeaks AT3W’s and they have more of a constant light swoosh sound after 20mph plus.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 11:16 PM #3
Thanks! It’s hard for me to know for sure, as I have no frame of reference to confirm if it really is just normal tire noise.
Old 07-26-2021, 12:12 AM #4
meltdown meltdown is offline
meltdown will become famous soon enough
One way to confirm it’s the tires is to drive on different surface types. Where I’m at, the intestate has stretches that are concrete and some that are asphalt. The noise from the tires is noticeably different on each surface.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 09:22 AM #5
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Does the sound go away if you put it in 4WD while going straight at those speeds? if so, it's front diff needle bearings.
My '19 had that and it was the needle bearings of the front diff assembly and I also thought it was the tires for some time. Super common for the needle bearing to make noise, particularly after a lift. Some get noisy right away and others take a while.
ECGS sells a bushing that replaces the bearing. I had a local shop install it for a couple hundred bucks and I never have to worry about another needle bearing making noise.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 05:05 PM #6
I’ll have to give that a try! I put it in 4wd to check the CVs previously, but didn’t get it up to speed. I took it back to the shop today and the owner seems to think it just needs alignment, which sounds decently probable. I’m going to get the alignment done tomorrow and will report back.
Old 07-26-2021, 05:32 PM #7
lbro23's Avatar
lbro23 lbro23 is offline
lbro23 is on a distinguished road
lbro23's Avatar
Did you get the truck aligned after installing the lift? Perhaps the alignment is off, or just different than before and you're getting additional tire noise as a result.
I notice my tires are slightly louder right after I rotate them before they "wear" into their new place (100ish miles).
2014 Barcelona Red TE w/ KDSS | 285 BFG K02 | Toytec Boss Suspension | CBI Rear Bumper w/ Swingout | RCI Alu Skids | RCI Sliders | SSO Slimline w/ Warn Winch
lbro23 is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 09:47 PM #8
I actually did not, and that’s what the shop owner recommended today. I’ll be getting them aligned tomorrow morning and hopefully that fixes it! I sure hope it does, it’s hard to believe it’s really just tire noise, seeing as how it only starts above a certain speed, but we’ll see.
issue , noise , sound , strange , tire
Strange confluence of electrical issues in '99 4runner. Can anyone help diagnose? howsthewater Problems & Warranty Issues 2 09-12-2023 10:25 AM
Help me diagnose this noise, please jsindorf 3rd gen T4Rs 11 04-21-2016 12:43 PM
Strange throttle tip-in acceleration issue - can't diagnose fullboogie 4th Gen T4Rs 11 09-08-2015 12:13 AM
strange rattling that i cannot diagnose rebelbowtie 4th Gen T4Rs 26 08-10-2012 09:46 AM
