Old 07-26-2021, 05:03 PM #1
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
2015 4Runner TRD - Access to Center Jack Point on Front End?
I have a 2015 4Runner TRD- Do I need to remove the skid plate to place my hydraulic jack in order to lift both front end wheels to place jack stands?
I looked at the factory lift points , and the skid plate appears to cover the front center jack point ( the frame crossmember) .
GNB is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 05:34 PM #2
GNB GNB is offline
GNB GNB is offline
Originally Posted by Kennethz101 View Post
Jack up at that point on the black skid plate, not the gray TRD front skid. It should be fine. If you start to see the skid plate bend as oppose to going up, you didn't line up with the front center jack point.
Thanks. I was under my vehicle , and thought the black plate might be OK (not the gray skid plate).
I need to replace my front disk brake pads , but may just wait to also do an oil change which will require the gray skid plate to be removed ( not difficult, just a bit of a PITA).
Old 07-26-2021, 06:04 PM #3
meltdown meltdown is offline
meltdown will become famous soon enough
Now I’m going to have to go take my skip plate off. I thought for sure that the TRD skid had a spacer on it so that you could use the center jack point without removing it.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
front , jack , lift , plate , skid
Aftermarket Skid Plates and Front Jack Point assassin 5th gen T4Rs 8 09-15-2020 09:44 PM
Center Jack point on Skid plate after Diff Drop gigajoe 4th Gen T4Rs 2 09-02-2020 09:10 PM
Is this the front jack point wingzerom31996 Maintenance/Detailing 5 08-14-2018 12:41 PM
Front jack point with aftermarket skids boyguan 5th gen T4Rs 2 11-14-2017 11:23 PM
Best Front Jack Point? RC57 3rd gen T4Rs 16 05-15-2013 10:40 AM
