Old 07-31-2021, 11:11 AM #16
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
Originally Posted by Spungus View Post
I know your pain, I went through and chased this thing on my 17 runner for 2 years before figuring out what it was.
Intermediate shaft replaced by toyota - no change
Swapped out cv axles - no change
New tie rod ends - no change
New steering rack from toyota - no change
New coilovers and upper control arms - no change
I was going to drive my truck off a cliff, until I decided to check out my lower control arms. I wanted to pull them off to inspect the bushings, but ran into a seized cam bolt. Out comes the sawzall and after a dozen blades I cut out the seized bolt. What I found out is the rust had filled in the thread grooves on the cam bolt. It was so bad because it never got tightened to spec after alignments and as a result there was slop in the lower control arm which caused the bushings to fail.
So, thousands of dollars in toyota warranty bucks, hours of my time, and new gray hairs all for a $30 cam bolt essentially. The torque spec for those are 129 ft/lb, most shops only do 100 ft/lbs. See where this is heading? Have someone look at those lower control arm bolts and bushings. But be prepared to spend $320ish an arm if that is the case. A seized bolt or even a bad bushing is a death sentence and the whole thing will need to be replaced.
Good luck!
Thanks for the input! I was so focused on the ball joints I didn't put a lot of time into the bushings. Will definitely be checking this out. Thanks a bunch!
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 10:46 PM #17
BR4R87 BR4R87 is offline
BR4R87 is on a distinguished road
Any luck finding the problem? Mine makes tiny clunk going 18-25 mph over pavement. Everything is tightened properly.
BR4R87 is offline   Reply With QuoteReply With Quote
start , steering , tight , vehicle , wheel
Meso Customs steering wheel Toyota overlay "review" Scowling Tuna 5th gen T4Rs 30 09-13-2020 01:28 AM
Stumped: New brakes now odd "clunk" at wheel? Bftfan 4th Gen T4Rs 22 12-07-2017 09:39 AM
Allignment. Steering wheel off. "You need a new rack" MuddyButt 3rd gen T4Rs 11 01-02-2016 09:24 PM
Front End "Clunk" and (separate) Steering Noise thirstyturtle 3rd gen T4Rs 10 06-01-2014 06:28 PM
