Old 07-29-2021, 03:17 PM #1
Blackdog99 Blackdog99 is offline
Blackdog99 is on a distinguished road
Brakes issue on my 2014 SR5
Hi all,
I could really use some help/advice.
I have a great mechanic who I trust, and when I can't do something myself that's where I go.
I have brakes that have too much pedal travel, and don't stop worth a dime...BUT if I quick double press the brake pedal, the pedal is WAY firmer, and stopping is improved. (only 8K miles on pads, and it's been like this since, I did new pads, rotors, and calipers) I have taken it back twice, and had them check it out, and had them bleed brakes 3 times total now, and nothing is changed. I know I could put on aggressive pads, but that won't change the brake pedal issue.
Thoughts anyone?
Thanks
Blackdog99 is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 03:44 PM #2
nowittynamehere nowittynamehere is offline
nowittynamehere is on a distinguished road
Originally Posted by Blackdog99 View Post
Hi all,
Thoughts anyone?
Thanks
I'm not a mechanic, so I could be wrong. But, it sounds to me like there's air in the line.
nowittynamehere is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 04:05 PM #3
Thanks for the reply! I agree with that thought, but it's hard to say it is, when mechanic has bled system 3 times....doesn't mean there isn't, but it just seems like it acts like air in lines.
Old 07-29-2021, 06:12 PM #4
Relentlesskaizen Relentlesskaizen is offline
Relentlesskaizen is on a distinguished road
So the thing I see commonly is when someone bleeds the brakes on the GX/4Runner is after the initial bleeding the rears still have some air trapped. Pump the brakes then crack the rears individually with no pedal depressed (otherwise the actuator does it’s job and fluid blows out) wait about 15-20 seconds while watching for bubbles from the bleeder screw. Not 100% sure this is the solution but this is what I see a lot after someone flushes brake lines.
Relentlesskaizen is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 06:19 PM #5
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
I know on the Tacoma you can get the abs to push out all the air. But it does suck brake fluid quick so be careful.
Forgetful is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 07:22 PM #6
NorCal4run NorCal4run is offline
NorCal4run is on a distinguished road
Hi all,
Thoughts anyone?
Thanks
Sounds like there is air in the lines. Take it somewhere else
NorCal4run is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 08:35 AM #7
that's something new to me...haven't heard of doing it that way prior. Thanks for the advice
Old 07-31-2021, 10:35 AM #8
smokingtoysupra smokingtoysupra is offline
Real Name: Andy
smokingtoysupra is on a distinguished road
Real Name: Andy
Hi all,
Thoughts anyone?
Thanks
does it have hydro boost?
smokingtoysupra is offline   Reply With QuoteReply With Quote
brake , brakes , issue , pads , pedal
Brakes Issue! Help! danpholden 3rd gen T4Rs 2 11-05-2016 03:00 PM
Newly Installed Brakes Issue joesrcool 5th gen T4Rs 5 01-31-2016 12:03 AM
Wiring issue with brakes lambskin931 Classic T4Rs 2 11-13-2011 08:15 PM
Help! issue with new front brakes nitrostang 3rd gen T4Rs 0 11-04-2010 05:43 PM
07 4Runner Limited - Brakes/ABS issue? spc337 Problems & Warranty Issues 1 04-19-2010 11:07 PM
