Old 07-30-2021, 02:13 PM #1
Mastr_chief's Avatar
Mastr_chief Mastr_chief is offline
Mastr_chief is on a distinguished road
Rubbing still after BMC and 285's
Hello guys -
Finally jumped up to 285s after running my stock duelers. I'm still getting some rubbing by the body mount after doing a BMC. I'm running the current:
JBA UCAs
Bilstein 5100s
Dobinson springs
2" front, 1" back
285/70/17 Falken Wildpeak AT3W
See attached for where I'm rubbing. Any ideas on how to trim this? Or should I look at my alignment again?
[IMG][/IMG]
Rubbing still after BMC and 285's-img_7204-2-jpg
Mastr_chief is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 02:34 PM #2
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
I think your tires are too big.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 02:36 PM #3
No such thing.
Old 07-30-2021, 02:39 PM #4
streetsyndicate streetsyndicate is offline
streetsyndicate is on a distinguished road
What is your caster set at and what is your wheel width and offset?
With JBA's and a 2.5" lift I was able to get 5.1 and 5.5 degrees of caster and my k02 285s on 7.5 (-)16 offset wheels don't rub even with mud flaps still installed.
Unless you have an extremely low offset, wide wheel that's causing the issues, I would focus on getting an alignment from a shop that specializes in lifted vehicles and aligning for clearance. You should be able to get over 5 degrees with your set up which will give clearance (trim bumper of course) and also really improve the way it handles on road with regard to steering feel and overall tracking and stability.
I know this doesn't answer your question, just suggesting that perhaps there is a better way to approach this.
streetsyndicate is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 02:39 PM #5
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
Pretty common. It's just plastic, so dremel or small reciprocating saw would work. Just keep cutting until it stops rubbing.
Edit: the plastic fender end cap also comes off. Behind it is part of the lower fender mounting bracket, if you're rubbing on that you can lightly bend it out the way or cut it off.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 04:20 PM #6
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Stock TuRD rims?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 04:36 PM #7
Luv4R Luv4R is offline
Luv4R has a little shameless behaviour in the past
I have an 06 Icon lifted running KO2 285x75x16 and they rubbed as expected.
Once I took it to the guys in my area ( I dont know if I can mention company names so I'll refrain) who work ONLY on off-road rigs, they did the BMC and the rub was gone.
Adding to what streetsyndicate said,
My question would be.
- Who did your BMC.? If they are Off Road Rig pros with 4R experiece in BMC's, then I'm sure they did a good job, but if you did the cut yourself, or didnt take it to a shop that specializes in Off Road Rigs and have 4R experiance, there may be a chance whoever did the cut didnt cut enough of an angle off.?
Find a Off Road shop and have them check it out
Good luck.
Luv4R is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 04:47 PM #8
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by Mastr_chief View Post
Hello guys -
JBA UCAs
Bilstein 5100s
Dobinson springs
2" front, 1" back
[IMG][/IMG]
you need to cut that plastic fender cap, and sometimes the metal tab behind it (or bend it back).
Its pretty normal.
Old 07-30-2021, 05:00 PM #9
Ok, cut some of the plastic off and might have to bend the metal if it keeps rubbing with some flex.
Oh, and to answer a previous question, the wheels are SCS SR8, -10 offset.
Old 07-30-2021, 05:01 PM #10
Snowtrooper Snowtrooper is offline
Snowtrooper will become famous soon enough Snowtrooper will become famous soon enough
As many have mentioned here, looks like the BMC was done correctly.
You might be able to just trim away that fender cap with a heavy duty box cutter. After that would be the pinched metal tab that can be bent in if necessary.
Snowtrooper is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 05:12 PM #11
Not my photo, but pretty clean cut for someone else who’s search brings them here…
Rubbing still after BMC and 285's-fb1c61d8-905f-4390-a659-e6cf92535e22-jpeg
Old 07-30-2021, 05:45 PM #12
Perfect pic. That's pretty much what I ended up doing as well.
Old 07-30-2021, 06:04 PM #13
mlnhtrang's Avatar
mlnhtrang mlnhtrang is offline
mlnhtrang is on a distinguished road
mlnhtrang's Avatar
every vehicle is different. im running ray 10 -10 with spc uca caster all the way forward and no bmc.. no rubbing and im still have the stock flaps on.
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
mlnhtrang is offline   Reply With QuoteReply With Quote
Old 02-22-2023, 02:02 PM #14
Mooseknuckle Mooseknuckle is offline
Mooseknuckle is on a distinguished road
Still Rubbing with BMC
Still rubbing on my body mount after bmc. 2014 SR5
2.5” lift
JBA UCA
285/70 R17 Falken Wildpeak
Wheels : 17x8.5 0mm offset, 4.75 backspacing
Caster 3.7
Beyond frustrated that I’m still dealing with this…just about want to get rid of the 4Runner for good.
Mooseknuckle is offline   Reply With QuoteReply With Quote
Old 02-22-2023, 02:04 PM #15
2.5” lift
JBA UCA
Caster 3.7
"i created a problem and now i'm mad!" lol.
285s , back , bmc , rubbing , running
Rubbing on top of BMC TheMagicMan5280 5th gen T4Rs 10 06-17-2019 05:59 PM
Rubbing lonkelm 4th Gen T4Rs 3 11-30-2015 04:04 PM
"Rubbing" sound... But not rubbing? A.Wilson013 3rd gen T4Rs 24 10-13-2015 10:38 PM
Rubbing after 285's yukonrider 3rd gen T4Rs 11 10-17-2012 10:34 PM
Rubbing... The97Runner 3rd gen T4Rs 6 11-10-2011 09:42 PM
