Old 07-31-2021, 07:49 PM #1
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Differential Mod using OEM breather valve
Not sure if this has been posted before, but I realized today that you can reuse the breather valve off of the differential. You can thread the valve into a 5/16 ID fuel line for a nice tight fit.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 08:06 PM #2
aabottom aabottom is offline
aabottom is on a distinguished road
Cool
2016 Toyota 4Runner SR5 Premium 4WD Sliver
R.I.P.: 1999 Toyota 4Runner SR5 4WD V6 5Speed_Manual Red
aabottom is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 08:27 PM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Yes sir, been posted numerous times in other threads.
Best Regards,
Saker
Old 07-31-2021, 08:48 PM #4
Well crap... missed that! I could have saved a few bucks because I figured that out while I was cleaning up.
Old 07-31-2021, 08:59 PM #5
Saker's Avatar
Saker's Avatar
I hear you.
If you put a filter on it where the diff stays at ambient pressure, your diff will not suck in water like when that valve is closed.
Best Regards,
Saker
Old 07-31-2021, 09:27 PM #6
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
From what I understand, the factory piece acts more like a check valve than a true bidirectional breather. For that reason, I upgraded up a breather that's mounted high up under my hood, all of the lines (front & rear diff, transfer case, and E-locker breathers) are all tied in. I used some heat shrink, a couple of hose barb connectors, and a few shark bite fittings to make it all work... in addition to the $40 Amazon knock off version of the ARB breather kit.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 10-22-2021, 01:14 PM #7
jerbrun0515's Avatar
jerbrun0515 jerbrun0515 is offline
jerbrun0515 will become famous soon enough
For the barbed union fittings did you use 8mm for size? Link to it?
Sent from my SM-G965U1 using Tapatalk
jerbrun0515 is offline   Reply With QuoteReply With Quote
Old 10-26-2021, 10:00 AM #8
CajunMikeR's Avatar
CajunMikeR's Avatar
Just now seeing this, sorry.
I just took a small piece of the tubing to Lowe's and found what fit tightly. Then when I installed I heated the tubing, forced it on, allowed it to cool, then put heat shrink over it to give another layer of protection against water intrusion.
2019 MGM TRD ORP
shootn4runner on IG
breather , differential , fuel , line , valve
Rear differential breather valve and pressure buildup NOT ME OR SOMEBODY 3rd gen T4Rs 10 12-25-2015 07:36 PM
02 T4R SR5 Differential Breather?? Deputy73 3rd gen T4Rs 3 08-07-2013 11:03 PM
'03 differential breather zig Off-Roading 6 04-29-2005 08:14 AM
Rear Differential Breather Scofco Maintenance/Detailing 9 02-20-2004 09:15 PM
