Old 07-31-2021, 09:07 PM #1
Jon4RSD Jon4RSD is offline
Jon4RSD is on a distinguished road
GFC Superlite RTT on a Sherpa Crestone
Has anyone mounted a GFC Superlite RTT on a Sherpa Crestone rack on a 5th gen? Wondering about access and bolt length, thinking the sunroof and rear of the rack might allow access..
Jon4RSD is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 11:22 PM #2
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
Not sure how the prinsu compares to your racks cross bars. I mounted my superlite with 5/16-18 x 1-1/2 from Home Depot. they fit perfectly.
4:08 talks about how I mounted it.
GFC Superlite Initial thoughts (5th gen 4runner) - YouTube
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 07:11 PM #3
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I think the hard part is finding the GFC tent!
rageandlove is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 08:29 PM #4
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
My GFC Superlite on the Sherpa rack:
GFC Superlite RTT on a Sherpa Crestone-120210702_103449-jpg
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 12:13 AM #5
Did you use the hardware that GC provided?
Old 08-02-2021, 06:53 AM #6
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
That's a lot of weight on a crossbar held on by four 1/4" bolts. The bolts go through a long slot, not holes, in the side panels. Under heavy load, the slot will expand and the head of the bolt will pull into the slot. This happened to me with an OVS awning - I thought I had a good setup distributing the weight through three mounts and six crossbars, but the middle mount overstressed the Sherpa side panel.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 02:16 PM #7
Real Name: Nick
Real Name: Nick
No I did not. I used the Sherpa tent riser brackets and hardware. I wanted it as low as possible.
Old 08-02-2021, 02:19 PM #8
Real Name: Nick
Real Name: Nick
I walked on the cross bars when I'm cleaning the roof. No issues. Also no issues either when I had my ARB awning mounted at 3 points on the Sherpa but then again I didn't mount to the side panel. I mounted it to the cross bars using the sherpa awning mounts.
Old 08-02-2021, 05:12 PM #9
...I I had my ARB awning mounted at 3 points on the Sherpa but then again I didn't mount to the side panel...
Each of my three awning brackets is secured to six carriage bolts - three on one crossbar, and three on the adjacent crossbar. The awning weight is therefore spread across six different crossbars. I was shocked to see that the center bracket had caused the two crossbars to pull into the side panel.
There must have been some twisting force applied while the awning was extended - poles down, with side wall attached and guy lines in place. I moved the awning to the opposite side, and reset the bars on what is now the weak side of the roof rack. I also added 1 inch fender washers to better distribute the force of the end bolts and keep them from pulling into the side panel.
Sherpa pros - flexibility, light weight, non-corrosion. But maybe not strong enough. I'm contemplating putting a Gobi rack on order.
access , crestone , gfc , rack , superlite
FS: 5th Gen - Sherpa Co. Crestone Roof Rack - Full Shield - Phoenix, AZ $1000 SparrowExam For Sale: T4R Items 2 07-01-2021 02:18 PM
FS: 5th Gen Sherpa Crestone Rack - Assembled - Phoenix, AZ SparrowExam For Sale: T4R Items 1 06-09-2021 04:03 PM
Sherpa Crestone Rack Install/Review bjs0131 5th gen T4Rs 31 04-06-2021 12:06 AM
Sherpa Equipment CO. - The Sherpa Edge (What makes us the best) SherpaEquipmentCo Sherpa Equipment Co 0 11-28-2020 10:50 PM
