08-03-2021, 03:52 PM
#31
Originally Posted by ahtoxa11
KO2s are not as quiet as people seem to say, at least not once they get down to 50% tread or so. That's how mine are getting.
Overall, the larger the treadblocks, the louder the tire is likely to be. Larger treadblocks are also more prone to cupping and feathering, which will contribute to the noise.
Every tire gets noisier as they wear, especially a more aggressive AT like a KO2, Ridge Grappler, etc... From my experience they are relatively quiet compared to others. I've had terra grapplers twice on my previous Jeeps and they both sounded like mud tires after 10k miles. I have multiple friends with Ridge Grapplers and they are quiet too. Not sure how the TG went so wrong for basically a road tire.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
08-03-2021, 04:08 PM
#32
Originally Posted by 02SE
I've driven/ridden on all the tires mentioned so far, and several more.
When looking for tires for the TRD ORP, I wanted tougher than the stock Dunlops/Bridgestones, great wet and snow traction, decent on trails, and quiet.
They are quieter than the tires mentioned so far, and have been great in every situation I've tried them in so far.
Yokohama A/T G015 in LT 265/70R17
Have any more pics of these? Curious to see how they look on the truck.
2021 TRDORP/KDSS
OEM Pro Grille, Fifteen52 Turbomac HD Graphite (17x8.5 ET 0), Falken Wildpeak AT3W 265/70 SL.
08-03-2021, 04:36 PM
#33
I don't have many pics, but here's one from the side. They aren't mud terrains, but they are definitely more aggressive looking than the stock Dunlops.
08-03-2021, 05:50 PM
#34
I recently upgraded to a ‘21 GX460 from a ‘20 ORP. Had Wildpeaks on the 4Runner, and decided to try Continental TerrainContact A/T’s on the GX. Amazing tires, incredibly smooth and quiet yet off road capable. I much prefer them to the Falken’s. I think they would be a great fit for your intended use.
08-03-2021, 09:03 PM
#35
The Cooper ST Maxx I had were somewhat noisy. Not annoying by any stretch but it was there.
I switched to Yokohama Geolandar AT's and they're the quietest tire I've ever driven on. Very nice on road. And great off-road so far, I've used them on more then just dirt roads... They don't look as agressive as some AT's, but they certainly perform well as an all terrain.
08-03-2021, 10:09 PM
#36
I thought the set of conti tc’s I had did great in everything except snow/ice, where they basically turned into ice skates.
08-04-2021, 01:15 AM
#37
Originally Posted by WannaBe77
I’m planning to level my ‘21 Venture (maybe 1” up front) but will likely stick with 265s (maybe 275s). I’m going to keep the stock TRD Pro wheels. And I will be on pavement 98% of the time.
But I like the look of AT tires. With that said, which are the quietest AT tires out there?
Noise and aggressive looks often go hand in hand. The small tread blocks and narrow voids on highway tires are a big reason they're so quiet and modest in appearance. At the opposite extreme, Mud Terrain tires have large tread blocks and wide voids between them that make them both aggressive and loud. What you probably want is the most aggressive sidewall you can find on a set of tires with the most highway-tire-like tread pattern.
Originally Posted by Tuco S.
Toyo AT3's are quiet when new. I think any AT tire is going to get noisier as they wear, it's kind of unavoidable.
For minimal offroad use, I would look long and hard at those Yokohama G015. Great value too.
From that shot of the tread by
@ O2SE
I too believe those Yokohama's are worth a look (though I have no experience with them).
That said, I recently chose Toyo Open Country AT3 tires. I do about 90% highway driving and was willing to put up with a bit of noise for the performance gains when I am offroad. But I have been pleasantly surprised by just how quiet they've been so far. Currently they make no more noise than highway tires I've run. I have a thread with my thoughts on them here. These tires have only been on the market since March 2020 and I've yet to reach five-digit mileage with them. But my research leads me to believe all the manufacturers are making strides forward in noise reduction with their most recent tire releases. So you may want to consider that as well.
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
08-04-2021, 01:57 AM
#38
I just got the new Cooper Discoverer Rugged Treks in 285/70r17. They are a tiny bit
louder than stock size Terra Grapplers but can’t really tell unless you are paying attention to it. On the highway, the TRD exhaust drone and my radio drown out any road noise anyway. They are more of a hybrid AT/ MT with pretty
aggressive tread and sidewalls. I took them through some 1-2ft deep mud the other day and they handled it easily. Drive great so far on highway with good traction on rain/wet roads. Had to remove my front mud flaps due to rubbing though- even with the Westcott Designs TRD Pro lift installed.
08-05-2021, 09:01 PM
#39
Many thanks all! I really appreciate you all chiming in with your thoughts and experiences!
08-07-2021, 01:22 PM
#40
Pretty happy with my Cooper Discoverer AT3-4s. I put them on at about 500mi. 20K on them now. Almost as quiet as the butter soft stock tires. They've been great in the winter and they commute like a boss! Hahaha! Just leveled with Eibach Pro Truck Sport shocks, front set at 0.85, the ride is SOOOO much better now!
2019 SR5 Prem, Nautical Blue, 3rd row, TRD wheels, 255/75/17 Cooper Discoverer AT3 4S (SL), Leveled with Eibach shocks, Rav4 mirrors
08-07-2021, 07:19 PM
#41
Michelin LTX AT2
08-08-2021, 01:13 PM
#42
The stock Nitto Terra Grapplers on my 2021 are much quieter than the K02's that were on my 2016 that I traded in for the new one. Over 10,000 miles on it and no complaints at all with them. Can't say the same for the K02's that never seemed to be in balance over the 60,000 miles I put on them. And yes they got progressively louder with the mileage.
2021 SR5 Premium 4x4 stock, Nitto Terra Grapplers
08-11-2021, 01:30 PM
#43
louder than stock size Terra Grapplers......
Are you getting phantom "Cooper pull" to the right? I recently put some stock size Rugged Treks (XL load) and at certain speeds/certain type of road they pull to the right. I've heard that is an issue with STT max and such, but since this has the same outer tread blocks, I'm wondering if that is the cause (tire pressures and alignment are dead nuts).
Definitely have some road hum to them, but I think I'll get used to it. Either that or obsess over it until I talk myself into something else.
2021 TRD Off Road
2008 GX470 (sold!)
2018 TRD Off Road (sold!)
08-11-2021, 03:54 PM
#44
I've only used 2 AT tires and just can compared only both of them.
Goodyear Duratracs are loud on the highway
BFG KO2s are extremely quiet on the highway
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
08-11-2021, 04:31 PM
#45
Originally Posted by Cheers!
Michelin LTX AT2
Expound, please. What is your experience? I’m wondering about Michelin LTX A/T2 tires myself. For mostly on-road, but wanting to be ready for a bit more than that, plus snow, they seem like a good fit to me.
