08-03-2021, 03:12 PM
silly Q, buying 4pc and only plugging in 3 raptor lights
was looking at this kit but was not sure if there is a controller that regulates power to each light or if each is a 12v in so I can just tape off the fourth plug and run three or choose to run four etc.
4Runner Raptor Lights — Overland Depot
TIA!
Check out my Build here
2014 Trail Premium - 285Dura - 5100/5160 2.5"F/2"R
08-03-2021, 04:13 PM
orrrrrr buy 0 raptor lights for the toyota
08-03-2021, 04:22 PM
The best mod.
08-03-2021, 04:52 PM
This all the way
08-03-2021, 04:57 PM
TIA!
doesn't look like anything other than normal 12V wiring from an add a fuse, you can do whatever you want with it
08-03-2021, 06:11 PM
If you're getting "raptor lights", get it straight from CarTrimHome for cheaper.
Free Shipping LED Light For 2014-2021 Toyota 4Runner
Literally the same thing, cheaper.
You can run 0, 1, 2, 3, or 4. Doesn't matter.
08-15-2021, 01:42 PM
08-15-2021, 01:48 PM
Heavy plus, to each their own but I don't get the trend of trying to dress up vehicles that don't require DOT lights. Is it a race to make your truck look like a UFO? People are even putting them on Rav4s and Broncos now.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
08-15-2021, 02:58 PM
Real Name: Jonathan
Real Name: Jonathan
Agreed, to each their own, and does anyone aside from commercial drivers and some car nuts really even know what the marker lights are for? At this point with all the 4Runners, Tacomas, Tundras, etc. running them, they're the boy that cried wolf.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
08-15-2021, 06:57 PM
Very true....commercial operators knew that the least amount of marker lights the better. At least in the old days, you could have as many extra yellow lights as you wanted, but they better work. If you had one burned out (even if it was a added on light for bling) it was an infraction on a dot inspection.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
08-16-2021, 07:28 AM
Go for a deuce
