Old 08-07-2021, 03:55 PM #1
seattle_kurt seattle_kurt is offline
seattle_kurt is on a distinguished road
Cost Of New Shocks and Struts
Hi there. I have 2011 5th Gen 4runner Trail Edition. My mechanic recently quoted me ~ $3,000 for a Bilstein Replacement Kit. This includes parts and installation labor. This is an independent mechanic with a good reputation that I've used for many years. However, this price seemed excessive to me. I'm wondering what others think and if you have any suggestions. I have no problem paying it. I just want to make sure I'm not being taken. Thanks in advance for any help.
Update: I should have mentioned that this quote included new control arms.
seattle_kurt is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 03:59 PM #2
biratley biratley is offline
biratley will become famous soon enough biratley will become famous soon enough
He trying to get in you with no lube .
Look on line at the kit you want
(or he quoted )then add $400 to $700 for installation and Youll see about what you should be paying.
Sent from my iPhone using Tapatalk Pro
biratley is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 04:03 PM #3
smokingtoysupra smokingtoysupra is offline
Real Name: Andy
smokingtoysupra is on a distinguished road
Real Name: Andy
can u get a breakdown of parts and labor? labor should be around 5-6 hours maybe a alignment even tho its not really needed.
smokingtoysupra is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 04:04 PM #4
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Whoa, seems a little steep to me considering the new hardware is way less than a $1000 (with new springs already installed).
I mean seriously, the job is front shocks 3 bolts on the top hat and 1 bolt on the LCA and 1 and 1 on the rears. KDSS is easy, you can do it on the floor and only unbolt one side at a time, another two bolts (you don't even have to unbolt the rear kdss). I have swapped/replaced/worked on mine a dozen times and $2000 labors seems steep.
I recently changed out my fronts by myself in my carport in >3 hours taking my time and cleaning as I went and I would say I am inclined but not a mechanic.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 04:38 PM #5
lbostons lbostons is offline
lbostons is on a distinguished road
I was quoted ~$3,500 just yesterday for bilstein 6112s in the front with bilstein 5100s in the rear with rear lift coil springs and 4 new Toyo AT3 in 285/70. I thought that seemed right.
lbostons is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 05:07 PM #6
Ok, your quote included 4 new tires (~$1,000). My quote included new control arms. So, we're in the same ball park.
Old 08-07-2021, 06:23 PM #7
osugsxr osugsxr is offline
TRD pro clearance sale for the 5100s a few years ago $400-450 , I paid $500 for labor with alignment. Quote one hour per a shock etc and negotiated for free alignment.
Old 08-07-2021, 06:45 PM #8
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
For reference, I bought a full set of Bilstein 5100's and Cornfed 1/2" rear spring spacers and had my local Toyota dealer install them including alignment. Total cost for everything was ~$1400.
Is that both upper and lower control arms on both sides using OEM parts? If so then that's at least $1100 for OEM control arms.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 07:26 PM #9
Thanks for the reference. Yep, both upper and lower control arms.
Old 08-07-2021, 07:37 PM #10
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Bilstein 5100 is under 500$, 6112+5100 would be under 900$, 8112/8100 would be 4,000+.
Stock LCA are about 330 each. Stock UCA can be purchased second hand for peanuts.
All work required is easy and frankly more pleasant than dealing with sliders or some of the skid plates.
The rear coils and shocks are like a 30 min job assuming non-resi shocks.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 08-07-2021, 08:54 PM #11
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I also have a 2011 Trail. It has ~116,000 miles mostly city and highway miles. It rides great with KDSS and Bilstein shocks installed 5 months ago. I'm a bit surprised that you already need upper and lower control arms. Do you have a lot of miles on the vehicle? Are the front springs still close to original height? My OEM front springs sagged, so I installed a pair of Dobinson's.
DougR is offline   Reply With QuoteReply With Quote
Old 08-08-2021, 12:45 AM #12
MAST4R's Avatar
MAST4R's Avatar
Good points. I won't be surprised if the shop made it up, at least when it comes to the UCAs.
It is crazy what I have heard from random mechanics over the years.
Old 08-08-2021, 01:10 AM #13
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
I usually start with Rockauto to check pricing.
Looks like the Bilstein strut is cheaper than some upper or lower control arms.
Bilstein 5100 adjustable single strut is $100. Control arms vary from cheap to $250.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 08-08-2021, 02:04 AM #14
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I got my kings for ~ $2500. Just install yourself :-)
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 08-08-2021, 09:52 AM #15
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I replaced mine myself in my driveway for around $150 (OEM Tokico) plus an alignment afterwards.
Depending on what you are looking to do, Wheelers has a kit with springs and 5100's for like 750 and for a little extra they will assemble the coilovers. Then It's simply install which is not very hard if they are already assembled.
Wheeler's 2010-Present Toyota 4Runner Suspension Lift Kit | Low Range Off-Road
Edit: I believe Wheelers springs might be made by Eibach??
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
good , mechanic , price , reputation , years
Cost for 5th gen limited front struts? dclark2171 5th gen T4Rs 4 06-27-2020 02:44 PM
Cost of Bilstein 5100 struts and shocks with alignment koalaballa 4th Gen T4Rs 1 06-25-2014 11:05 PM
Average cost to install shocks/struts on 2006 2WD T4R cgl4au 4th Gen T4Rs 13 05-30-2013 04:48 PM
Cost to replace front struts on 2002 SR5?? swampy_swimmer 3rd gen T4Rs 3 06-23-2012 12:04 PM
So when the shocks are shot, what's it going to cost? MLB 4th Gen T4Rs 2 03-17-2008 07:38 PM
