Old 03-23-2022, 04:14 PM #1
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
Unhappy Metallic rattle sound
Ever since a snow storm this past winter (may not be related but just a coincidence), there is a rattle that comes when I am braking around 15 - 10mph sort of like a heat shield / brake shield.. it lasts for a split second and then goes away when I reach 0. I can feel a slight vibration (i think) and hear it even with the windows closed.
I have gotten the car and all those skid plates looks secure, I tried to shake the brake heat shields, but they seem secure too. Any ideas?
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 03-23-2022, 06:00 PM #2
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
rotate your tires . inspect the calipers and brake pads ..miles on your runner and did your brakes new or how many miles on the old ones ..
catrains is offline   Reply With QuoteReply With Quote
Old 03-23-2022, 06:09 PM #3
thank you so much, sorry for the little details.
it has 33,500 miles, rotated tires every 5k miles, still original brakes. have original tires.
Old 03-23-2022, 06:39 PM #4
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Yeah rotate the tires and see if there are pebbles stuck in the dust shield and inspect the pads/shims, caliper pin. If it was exhaust it would do it when you accelerate not brake I think. Could try taking off the skids and see if there something rattling around on top of it.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 05:29 PM #5
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
I had something similar on mine. It was the loudest when reversing slowly out of my driveway.
It was the dust shield on the front brakes, can’t remember which side.
Crawled underneath and gave it a tiny push out and problem solved. This may help…
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 03-24-2022, 08:23 PM #6
bleed the brake calipers .. a brake pad will click if it has a pad holder ...
Old 03-25-2022, 07:00 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
rocks on your skid plates or lower radiator shield is my bet.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 02:06 PM #8
the plastic fender shields around the tires probably rattle .. Toyota used plastic fasteners to hold the shields ..I setup s/steel fasteners to lock up those plastic shields .. because the plastic shields fastener will wear the paint fender under the plastic shields ...moves ...
but the brakes do not rattle the plastic shields under the fenders..
brake , heat , rattle , secure , shield
Clank / metallic rattle suspension noise??? JabzSA 4th Gen T4Rs 8 08-17-2020 10:04 PM
Intermittent metallic rattle sound from engine -JD- 5th gen T4Rs 9 04-17-2018 10:14 PM
metallic sound with using brakes vonguido 4th Gen T4Rs 6 09-15-2017 08:25 PM
Metallic grinding sound under acceleration WallyWest 3rd gen T4Rs 10 07-06-2015 03:12 PM
thunder cloud metallic rattle can? SilverBullet01 3rd gen T4Rs 6 04-10-2011 11:11 PM
