Old 08-11-2021, 04:41 PM #1
dclark2171 dclark2171 is offline
dclark2171 is on a distinguished road
2013 Limited 4X4 suspension replacement options
I have 215,000 miles on my 2013 4R limited 4x4. All suspension is original and starting to leak. To replace the Xreas system, basically 6-7K at dealership. I'm thinking of just going standard replacement (non Xreas) parts. What options are available that will give me close to OEM ride/handling? I do not go off road. What kind of repair place should I contact about having installed? I'm not going to do myself. If anyone else had their 5th Gen suspension replaced, what kind of cost am I looking at?
dclark2171 is offline   Reply With QuoteReply With Quote
Old 08-11-2021, 05:28 PM #2
Humble Leader's Avatar
that is a lot of money to replace XREAS. I replaced mine for $3.3K Canadian $ at a toyota dealer. I didn't need to replace the lines though, just the 4 corners. I happened to spot a slight weep right when it started happening so I didn't have the issue of fluid loss. I replaced all 4 corners because they were 152k miles old and original. I don't believe it should cost that much even with the lines. usually folks are saying $3-4K on here.
many go with bilstein 5100s and are happy with them. although you will have a hard time finding aftermarket right now
if you want to replace them with anything non XREAS make sure you pull the lines and actuators as well if you don't go to toyota to do the work. you can't reuse them with fluid loss so might as well get rid of them while you are replacing. you could also put OEM suspension on it as well, same as what's on the sr5 and other trims except for TRD pro I believe. if you aren't going to toyota to do the work you should go to a 4x4 shop that has experience installing lifts and with whatever brand you choose
Old 08-11-2021, 10:18 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I replaced my limited with kings for half that price
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 12:42 AM #4
clin9383's Avatar
clin9383 clin9383 is offline
clin9383 is on a distinguished road
clin9383's Avatar
I'm similarly in the same position but I'd rather not have to deal with rebuilding every few years.
1996 Limited - OME 881/906 w/comfort shox | Deckplate | Hayden 1678 | 265/75R16 Revos | Koyo A1998 bypassed | Husky liners | Optima R34 Red Top | '99 Cupholders | Rear diff breather mod | (Totaled)
2012 Limited - Husky liners | OPOR sliders | 30% Ceramic Huper Optik | AVS seamless | Odyssey 34R-1500T
clin9383 is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 10:01 AM #5
sntryplt's Avatar
sntryplt sntryplt is offline
Real Name: Dave
sntryplt is on a distinguished road
sntryplt's Avatar
Real Name: Dave
I've got a 2014 Limited-had a slight leak on the XREAS 3 yrs ago, roughly 110K. Pulled everything, and had Bilstein 5100s installed. Very happy with the result--now crossing about 155K miles.
No significant changes in ride or handling.
2019 GX460, Nebula Pearl. 2014 LE, Mag Gray (sold).
Stable mates: 2020 Subi Ascent Limited, 2021 TRD O/R Premium Black
sntryplt is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 02:28 AM #6
808_702_4Runner's Avatar
808_702_4Runner 808_702_4Runner is offline
808_702_4Runner is on a distinguished road
808_702_4Runner is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 02:30 AM #7
Originally Posted by 808_702_4Runner View Post
2013 Limited w/Fabtech 6” Kit, Dirt Logic Coil-overs
kind , limited , options , replacement , suspension
03 Limited with XREAS and RAS - need advice on replacement options Neumonic 4th Gen T4Rs 15 07-15-2018 10:21 PM
Front Headlight Replacement Options for 3rd Gen - 98 Limited NEKExplorer 3rd gen T4Rs 12 06-18-2018 02:20 PM
Rear Driveshaft Replacement Options 99 Limited Mac_Gyver 3rd gen T4Rs 11 02-28-2017 04:26 PM
2013 Limited- Oil pump and timing chain idler replacement xrayd8 Problems & Warranty Issues 2 10-31-2015 04:37 PM
1999 Limited Suspension Options skier46er Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-21-2015 03:46 PM
