Old 08-11-2021, 07:29 PM #1
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
Elka suspension! [in stock]
Battle Born Offroad is proud to annouce we now carry Elka!
The 2.5 DC RESERVOIR model allows precise fine-tuning of the high-& low-speed compression damping so you can adapt the suspension for your specific driving style and terrain conditions without compromise. It also features an external reservoir with increased oil volume for cooler operating temperature, providing better performance and consistency.
Increase the off-road capabilities while improving the comfort and handling of your 4Runner
ADJUSTMENTS
Spring Preload
High-Speed Compression
Low-Speed Compression
BENEFITS
Wide range of highly effective compression adjustment
Precise fine-tuning of high-& low-speed compression, no need to compromise with your settings
High-performance off-road capabilities
Improved handling and comfort for casual driving
Better traction
Provides leveling capabilities for better weight distribution
Increased protection against bottoming-out
Better attenuation of vibration, leading to major noise reduction in the cabin (much less squeak and rattle)
TECHNICAL FEATURES
Massive 2.5 in. (56mm) hard-anodized aluminum body for cooler operation
Big bore design with less restricted oil flow for increased responsiveness and less fading
Internal hydraulic valving optimized for each vehicle platform
Built from CNC-machined and forged aluminum parts, aluminum bodies and premium-quality internal components
External remote reservoir with low-friction floating piston (1:1 ratio vs. main piston) providing additional cooling
DOT high-flow reservoir hose
Heavy-duty 3/4 in. (19mm) induction-hardened shaft
Triple sealing system with dust wiper, high-pressure step-seal and premium quality o-ring
Direct, bolt-on replacement that uses stock shocks location
Proprietary ultra-low friction, light viscosity semi-synthetic oil blend, ultra-resistant to high operating temperature
Coilover models use Elka‚€™s durable high-tensile alloy springs or Eibach springs (depending on model & configuration)
Fully rebuildable using affordable replacements parts and springs, multiple replacement valving shim stacks available
We currently have 2 full kits in stock and more on the way! these are hard to beat especially at the introductory price we are including,
Elka has been producing high quality shocks for over 20 years we find it surprising that not more people running it, we believe these will be a major contender over the next couple years in the toyota world, Be the first to run this awesome set up!
We are offering 10% off!
Use code ELKA10 at checkout
2010-21 toyota 4 runner Elka DC 2.5 coilover:
PURCHASE 90142 - ELKA Toyota & Lexus - Battle Born Offroad - The #1 Las Vegas Offroad Parts Store!HERE
If you would like to pair this with control arms or any other components feel free to send us a message direct or you can email me direct at alex@battlebornoffroad.net
BATTLE BORN OFFROAD
Las Vegas, NV | 702.333.0868
The Offroad Part Source
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 08-11-2021, 10:22 PM #2
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid has a spectacular aura about blksubykid has a spectacular aura about blksubykid has a spectacular aura about
blksubykid's Avatar
Donít carry the KDSS specific set?
blksubykid is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 01:00 PM #3
Official Vendor
Official Vendor
We do! ill be adding it to the list today
BATTLE BORN OFFROAD
capabilities , compression , elka , reservoir , springs
The Elka suspension thread MrGainzz 5th gen T4Rs 45 10-11-2021 11:07 AM
Spring rate: King 550lb vs Elka 700lb nimby 5th gen T4Rs 38 06-26-2021 03:53 PM
Yet another IFP vs Remote Resi thread (Elka suspension) angerbot 5th gen T4Rs 6 03-12-2021 01:41 PM
Elka?? Mikes3rdgen 4th Gen T4Rs 3 07-01-2020 01:53 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
