Originally Posted by Jakeepoo3
Thank you that will be helpful! In the meanwhile all I care about is recalibrating my zero point data. So the abs functions that already work won't be disabled. The vsc speed sensor codes are preventing me from doing that. So can you tell me how your cleaned yours and cleared the codes??
I didn't clear the codes they go away on their own when you drive straight for a few hundred yards at like 25mph after the issue is resolved but you can clear the codes also Follow the fsm trouble shooting guide. it is pretty thorough. you've already tested the sensors and the circuit. Look through the abs opening' using a flash light and rotate the the wheel slowly while lifted to see if there is any debris on the reluctor.
I can post the fsm pages for you if you don't have access to the fsm.
or you can download it but do not repost it on any other site
TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
Code 13 is C0273 causes: Open in abs motor relay circuit.
Brake actuator assambly.
IGI terminal voltage is below 9.5
The relay contact remains open, when relay is on.
Code 39 you already know..
AFAIK , You cannot do a zero point calibration until you resolve the abs codes.
