Old 08-14-2021, 01:42 PM #1
tahoekarl tahoekarl is offline
tahoekarl is on a distinguished road
Angry Front Suspension Squeaking
Had a set of Icon Stage II shocks installed about a year ago.
Lately, the front end developed a squeak and I hear it at varying noise levels -- going over speed bumps. Slowly backing out of the driveway. Slowly turning the wheel backing out of the drive way. I can even induce a squeak just by lightly touching the brakes as the vehicle moves slowly forward, or backward. Even the most minor move can force a squeak.
Yesterday, I greased the UCAs each at all 3 points. Glad I did this, but the squeaks continue.
Seems odd with the vehicle just 4 years old -- but are there any other bushings I need to consider replacing?
Anyone else experience this problem and find a fix?
tahoekarl is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 02:23 PM #2
spray some lithium grease on the spherical bearings for the coilover bottom mounts.
Old 08-14-2021, 10:50 PM #3
Jeremy556's Avatar
Jeremy556's Avatar
This.
Those lower bearings will make quite a racket when they wear out. 4 years is amazing longevity, I usually get less than a year and just change them proactively whenever I have the front end apart for any reason.
They are COM10T bearings, you can buy them anywhere besides Icon for much cheaper. I usually get them from Summit for $15
Old 08-14-2021, 11:03 PM #4
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
I just have a few thousand miles on my 2021 and when I hit bumps the passenger front makes a noise almost like a slight tire squeal. Super annoying and of course the dealer couldn’t replicate so now I’ll have to demonstrate 10 feet out the door for them, like we’re all idiots. Frustrating.
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 01:49 AM #5
Sully888 Sully888 is offline
Sully888 is on a distinguished road
check the rubber hood stoppers. just go out and extend them (turn them a few times) and see if it goes away.
Sully888 is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 04:17 PM #6
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Lately, the front end developed a squeak and I hear it at varying noise levels -- going over speed bumps. Slowly backing out of the driveway. Slowly turning the wheel backing out of the drive way. I can even induce a squeak just by lightly toughing the brakes as the vehicle moves slowly forward, or backward. Even the most minor move can force a squeak.
Seems odd at 4 years old -- but are there any other bushings I need to consider replacing?
Time to look at the bushings on the LCA
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 06:42 PM #7
Mr.Franko Mr.Franko is offline
Mr.Franko is on a distinguished road
Sub'd
2017 PRO (ICON-NFAB-GOBI-SCS-FALKEN-HWMS-WARN-SPOD-RAGO-BD-ARB-NORTHSTAR-BANDI-VIAIR-FACTOR 55)
Mr.Franko is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 12:09 PM #8
The lithium spray was certainly an inexpensive option at $7 to try first. Unfortunately, it has not worked -- yet -- I'll give it a day or so maybe the lube needs time to work itself in there.
Old 08-16-2021, 12:13 PM #9
I think I was unclear in my post. The vehicle is 4 years old. The shock upgrade only 1 year. I'll definitely consider replacement if/when I decide to replace the LCA bushings.
Originally Posted by Jeremy556 View Post
This.
Old 08-16-2021, 12:16 PM #10
Certainly worth a shot... unfortunately the noise most certainly comes from inside the wheel well.
Old 08-16-2021, 12:25 PM #11
Well I seem to be exhausting all options, but this one.
With KDSS I'm not sure I want to try this replacement on my own. Any idea what I should expect for cost on labor? I've read that Siberian Bushings are made of Poly and are relatively cheap:
Amazon.com: Siberian Bushing Polyurethane Front Suspension Lower Arm Front Compatible with Toyota Cruiser 2006-On Land Cruiser Prado 2009-On Land Cruiser Prado 2009-On KDSS Lexus GX460 2009-On 4 Runner 2009-On : Automotive
Old 09-16-2021, 09:10 AM #12
Welp... for those following this post, I tried the lithium grease and gave it some time to soak in, but it's safe to say that didn't work, except it did quiet down for a short period but I'm fairly certain that was due to a shift in weather/humidity. Time to change out the LCAs. Does anyone here have experience with that and recommendations for replacement 3rd party bushings? I recently asked if these were any good as they seemed relatively inexpensive:
Old 09-16-2021, 09:55 AM #13
I bet its your shocks or UCA"s and not the stock LCA's.
Race truck parts make race truck noises. Spherical bearings make a racket when theyre bad, sometimes grease helps, but if theyre shot, theyre gonna make noise. unbolt the coilover from the truck, and feel how loose the bearing is. it should be almost impossible to move by hand without added leverage.
backing , front , points , slowly , squeak
new suspension squeaking digphisher 4th Gen T4Rs 1 03-15-2024 10:55 PM
Squeaking Front End gookies 4th Gen T4Rs 2 04-08-2018 07:16 PM
Front end squeaking 4flyer 3rd gen T4Rs 2 02-22-2017 12:45 AM
Squeaking Front Suspension T4RNightHawk 4th Gen T4Rs 20 01-11-2016 09:52 PM
squeaking suspension 2k54RUNNIN 4th Gen T4Rs 2 06-20-2012 07:13 AM
