Old 08-25-2021, 04:20 PM #1
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
So what exactly happens if you run Premium in a 4Runner?
After so many tanks, will the vehicle “attempt” to advance timing a little further?
Curious if there is any benefit to doing this or zero reason to try it.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:28 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I use premium exclusively, 91 pure gas. I believe the Dual VVT does adjust the timing. To protect the engine it takes about 1000 miles of consistent premium gas for the ECM to make the full adjustment. If you use one tank of of 87 octane the ECM adjusts back (retards) the timing immediately and you'd need another 1000 miles of premium to regain the ecm timing adjustment. Im not sure this is 100% accurate but it is what I've pieced together. My truck is fast! I'm getting 18.9 MPGs all summer.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:30 PM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Your wallet is a little lighter.
thennen is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:46 PM #4
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
I’ve heard semi-credible sources say 15 hp gain on 91-93, but Toyota would likely disclose that. But in the back of my mind I can’t help but wonder if Toyota doesn’t say anything due to CAFE requirements, or if the 4Runner image is being portrayed as a vehicle that is tough and runs on regular. In theory, it should make more.
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:47 PM #5
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
did you actually read somewhere that it takes 1000 miles? I tend to run my tank pretty low before i fill up and i notice a difference after a couple tanks. I can definitely feel a difference but its a very small minute difference that most folks will NOT notice.
1jzgte is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:52 PM #6
gijonny1ea gijonny1ea is offline
gijonny1ea is on a distinguished road
I use a card. Mass not effected.
#science
gijonny1ea is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:57 PM #7
downshift's Avatar
downshift downshift is offline
downshift is on a distinguished road
downshift's Avatar
Timing is controlled by a map in the ECU. There's a max advance for any given place on the map. That max can be decreased if pinging is detected. If you are at max advance on 87 octane, meaning the engine is not pinging, then increasing the octane won't get you any more timing advance.
Current: 2017 TRD Off Road with KDSS
Previous: 2003 Sport Edition AWD
Before That: 1993 Pickup, SR5 V6 5MT Extended Cab 4WD
downshift is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:59 PM #8
Whippersnapper02's Avatar
It's like a liquid supercharger. I'm able to put bus lengths on Tesladerps.
Old 08-25-2021, 05:06 PM #9
trey99ek trey99ek is offline
trey99ek will become famous soon enough
I get 18+mpg on 87. I'll save my money.
Sent from my SM-G981U using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 05:06 PM #10
thennen's Avatar
thennen's Avatar
#science
The number in your bank account gets smaller or bigger, depending on whether you used a credit or debit account.
Old 08-25-2021, 05:08 PM #11
thennen's Avatar
thennen's Avatar
Agreed. I'm averaging 21.5, mostly rural driving, very little city.
Old 08-25-2021, 05:18 PM #12
#science
There are some stations that thought the “next step” was to begin accepting cash at the pump.
#Spinx
Old 08-25-2021, 05:25 PM #13
That's what I was thinking as well.
Old 08-25-2021, 05:36 PM #14
I run 91, stock tires at 35 psig instead of 32, and get 22+ mixed driving. I do not sit around idling ever though.
I deleted photos of my dash showing 23+ over the entire tank, but it’s true. I do not drive slow, but for whatever reason I always get better than everyone else. I was a hypermiler when I was a teenager so maybe it stuck with me.
Old 08-25-2021, 05:42 PM #15
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Lol. I would love to see the source of this info.
Our truck does not have an inline octane sensor like some GM vehicles have. As already mentioned, it has knock sensors that will back off timing if pinging occurs. But it does not have the opposite, the ability to increase timing because it "senses" higher octane.
08TxRunner is offline   Reply With QuoteReply With Quote
benefit , curious , iphone , reason , timing
Anyone made a SR5 Premium 4Runner look like a Trail Edition or TRD Off Road 4Runner? arouth 5th gen T4Rs 5 06-30-2020 10:05 PM
WTB: 5th Gen Off Road Premium or Trail Premium with KDSS PavementPrince$$ Want to Buy/Trade 0 05-22-2019 07:13 PM
Premium side mirrors work on non-Premium? DeepSea 5th gen T4Rs 5 05-07-2018 08:11 PM
GX 460 (Premium and Ultra Premium) Test Drive Review/Result Lolrax 5th gen T4Rs 36 10-04-2013 09:15 PM
