Old 08-14-2021, 06:11 PM #1
Barcelona4R's Avatar
Barcelona4R Barcelona4R is offline
Barcelona4R will become famous soon enough
Can someone please help me with wiring my light bar and pods?
So I have no idea why the lights won't turn on. I did power to power and black to ground. For whatever reason, the lights just aren't flicking on. What am I doing wrong?
Any Help would be great..
Barcelona4R is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 06:17 PM #2
Ripper238's Avatar
Ripper238's Avatar
Not much to go on. You wired the lights to a relay first? Brand lights? Its not as simple as black to black and power to power.
Old 08-14-2021, 06:41 PM #3
Extreme LED lights all around.
The controller is called AuxBeam. I basically cut off the switch that came on the wiring harness. Since the AuxBeam has 8 ports to connect things. I assumed its basically a switch.
Auxbeam 8 Switch Dimmable Universal LED Switch Panel Kit (Blue Backlight) - 4x4TruckLEDs.com
I didn't buy it from that link but just posting it so you can see what I'm using.
Old 08-14-2021, 06:42 PM #4
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Did you test the lights first before mounting. Touch the bare wires to battery terminal. I always test things like this prior to installation. There could be a defect.
Second...did you check if there was power at the switch terminal where you have the lights wired to? Assuming you have a multimeter.
I have the same auxbeam switch and it works great.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 07:09 PM #5
i think you got lucky. the alternative is you burn the truck to the ground. let a shop take care of this, or watch a few youtube videos.
Old 08-14-2021, 07:26 PM #6
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
If you have a multimeter or light probe you just need to start checking for power. Check all fuses and go from there. If you have a wiring diagram post that maybe some of us can guide you though this.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 08:10 PM #7
I wish I did. I emailed Extreme LED for help. AuxBeam didn't have much info. With that said, I did switch out the red wire with the white wire on port 3 and did get one of the bars to work.
Old 08-14-2021, 08:11 PM #8
I did, all the lights worked before I put them on.
Question, when you ran your wires to your auxbeam, did you leave the relay that the harness came with? I was reading that the box has a relay in it.
Old 08-14-2021, 08:28 PM #9
lewdog998's Avatar
lewdog998's Avatar
Mine is same, but slightly different, wiring should be same
Can someone please help me with wiring my light bar and pods?-20210814_192539-jpg  Can someone please help me with wiring my light bar and pods?-20210814_192556-jpg  Can someone please help me with wiring my light bar and pods?-20210814_192609-jpg
Old 08-14-2021, 08:33 PM #10
lewdog998's Avatar
lewdog998's Avatar
On your pics, I don't see where the main switch that goes in the vehicle is plugged in.....is it plugged in?
Old 08-14-2021, 08:37 PM #11
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
Deleted previous reply to your post.
The Auxbeam control box is a solid-state relay. Like you said, it has relays built into it - you don't need to add relays on top of relays.
If you are using a wiring harness with a built-in relay and switch, the wired relay won't engage and allow current flow unless the switch is flipped. If you cut off the switch, the only way that relay will engage is if you apply 12V across the leads.
My suggestion would be to cut the relay off of your wiring harnesses and run wires directly from the lights to the Auxbeam terminals. There should only be two wires running to and from your lights to the + and - terminals on the Auxbeam control box.
IIRC, blue and white wires are generally used for switches... are you trying to connect your switch leads, that you had cut, to the Auxbeam? It almost looks like you are possibly running the leads from the lights to your battery and wiring the cut-off switch wires to the Auxbeam.
Wiring Harness Diagrams
More photos might help.
choochoo is offline   Reply With QuoteReply With Quote
Old 05-24-2022, 10:36 PM #12
catchx46 catchx46 is offline
catchx46 is on a distinguished road
Is it possible to rewire the auxbeam switch panel to separate rocker switches? I have the 8 gang auxbeam one but i dont want to use the bulky panel. There is a 4 pin connector with red/black/green/blue wires
catchx46 is offline   Reply With QuoteReply With Quote
black , ground , lights , power , reason
Issue Wiring Rigid Pods to Aftermarket Switch Riv_IV 5th gen T4Rs 3 11-27-2020 07:32 PM
To Get Diffused Flood Light Pods Or Normal Flood pods Terbston 5th gen T4Rs 1 09-20-2017 03:11 AM
CBI Ditch Light Brackets and 40w LED Light Pods - $130 - AZ absalom For Sale: T4R Items 12 06-07-2015 05:18 PM
LED Light Bars & Pods treklights Engines / Suspension / Wheels / Tires / Audio / Accessories 81 02-12-2013 10:11 AM
