Old 08-16-2021, 10:31 AM #1
hallcs hallcs is offline
Banned
hallcs will become famous soon enough
Banned
Rear spring and shock install with KDSS over weekend
I ordered Dobinson IMS for front and rear, the rears came first so I installed this weekend. Was not hard, sounds hard but once you do it. It does help to have two floor jacks, stands and two people. The passenger side is all the work, drivers side is 20 minute job with KDSS. I spent many hours reading and watching youtube videos and was scared but it wasn't that difficult as made out by some people.
Rear spring and shock install with KDSS:
Start with the hard side (passenger)
Lift the truck by the frame until wheel is off the ground (passenger side only) and secure with jack stand.
Remove wheel, place under truck for safety.
Remove the shock totally
Remove bolt from clip that secures emergency brake cable to the lateral rod (the retainer clip will stay on the brake cable and probably slide down behind the brake rotor, I spent 2 hours looking for that clip during reinstall).
Remove bolt from clip that holds the rubber brake lines on the under side of the truck, do not remove any from the axle. Just the one the holds the lines to the body of the truck so you have extra slack in those rubber lines.
Put a jack under the axle close to the passenger side rotor and put a little tension on it.
Loosen both bolts for the upper control arm, then remove the bolt farthest from the axle and let it hang.
Put another jack under the sway bar close to the fixed KDSS bracket and apply a little upward pressure.
Slowly and evenly remove the two bolts at the bottom of that bracket. You want to make sure you have enough pressure on that sway bar, I loosened the bolts until I had a gap then squeezed the bracket with channel locks to see how much pressure was there. You just dont want it to pop when you reach the final part of the threads.
Once the bolts are out of the bottom of the bracket you can begin lowering the axle. start with the one under the axle then the sway bar. When the one on the axle becomes loose pull it out an keep lowering the sway bar until you have enough room to pull the spring out. It drops pretty low, I just pulled out by hand and I had a spacer on top of my spring.
Then just reinstall in reverse order and torque to spec. Be sure to leave the final tightening of the upper control arm until you have the weight of the truck on the ground. You can reassemble while in the air but torque only when the truck has the full weight on the ground.
Ok now the easy side....
Lift the truck by the frame until wheel is off the ground (Drivers side only) and secure with jack stand.
You will NOT have to remove brake clips or bolts from the control arms from this side. Very simple side
Place jack under axle on that side close to rotor and apply slight tension then Remove shock totally.
Lower jack slowly, the KDSS piston should decompress and drop the axle low enough to remove the spring (I used a pry bar just a little at the bottom of the spring to get it over the hump) but you will see the drivers side so much easier.
Reassemble and torque to spec.
I had no trouble with the KDSS after and drives like a dream.
hallcs is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 02:19 PM #2
mlnhtrang's Avatar
mlnhtrang mlnhtrang is offline
mlnhtrang is on a distinguished road
mlnhtrang's Avatar
cool
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
mlnhtrang is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 12:52 PM #3
ASUMTNEER ASUMTNEER is offline
ASUMTNEER has a spectacular aura about ASUMTNEER has a spectacular aura about
Can you remove the shocks only without fussing with any of the extra bits due to KDSS? I've got an eibach pro lift kit, but think I'm just going to go with the 1.6 setting in the front and leave the rear springs factory.
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 07:21 PM #4
yepppp...if the straps arent in the way, leave them on the shocks and install. otherwise use a floor jack and a block, jack up the hitch to get the suspension to droop to help you install the new shocks. they can be a pain to compress.
axle , jack , remove , side , truck
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 Want to Buy/Trade 1 09-10-2019 08:21 PM
Rear shock/spring recommendations please! Party Boy 3rd gen T4Rs 10 04-12-2016 03:49 PM
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 For Sale: Suspension/Wheels/Tires 3 11-05-2014 11:43 AM
Spring/Shock Install Safety Question Paisano 4th Gen T4Rs 9 06-27-2013 03:08 PM
