Old 08-24-2021, 04:10 PM #16
L1011's Avatar
L1011 L1011 is offline
L1011 is on a distinguished road
L1011's Avatar
Originally Posted by dezertbomber View Post
Does the "complete" kit come with UCA's? If not then I assume you're getting your own, which they should come with ball joints preinstalled already. Also, UCA's aren't affected by XREAS delete, just whatever your new setup would be and if it calls for UCA's to help prevent ball joint bind on droop.
I'm a bit of an ignoramus here as I don't know what UCA's are. This is the URL to the kit I'm looking at:
Dobinsons 1" to 3.5" Lift Kit Toyota 4Runner 2010-2021 (Non KDSS) – Dobinsons Direct
I was thinking of buying the C59-238 (0.75-1" lift) front springs, the GS59-574 Front Shocks, the C59-323 stock height rear coils, and the GS59-705 rear shocks. It's the extra stuff mentioned below those selections I chose that I'm not sure about
L1011 is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 05:09 PM #17
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
For a 2" lift (1" spring + the shock you chose says it gives an additional 1" of lift) in the front you won't need Upper Control Arms (UCA's) as they only need to be replaced when you start lifting upward of 3" and getting longer travel shocks that would make the ball joints bind from letting the tires droop or fall away from the vehicle when in the air.
Get the new strut caps and have them assemble so it's a plug and play install instead of having to deal with spring compressors to remove the XREAS struts' top hats and then compress the new springs to install them onto the new strut/shock.
Here's what your cart should look like to keep things straightforward. Some owners are bothered by the slight lean some 4Runners can have after lifting, so if you want to, you could also get the 1/4" spacer they offer to install on top of the driver side strut between the top hat and the coil bucket.
Helping out a buddy..2015 w/X-REAS..delete?-dobinsons-cart-jpg
dezertbomber is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 10:30 PM #18
L1011's Avatar
L1011's Avatar
I really appreciate the guidance. Thank you!!
Old 08-24-2021, 10:33 PM #19
L1011's Avatar
L1011's Avatar
Seems like multiple sources, including a verbal quote from my Toyota dealer, indicates replacing XREAS with OEM XREAS-capable parts costs around $4,000. But when I look up the cost of the XREAS front struts/rear shocks, the parts cost around $800. So where's the rest of the cost?
48510-80499 (Front Right Shock)
48520-80232 (Front Left Shock)
48530-80557 (Right Rear Shock)
48540-39865 (Left Rear Shock)
Fronts are about $619, rears about $135 roughly.
Old 08-25-2021, 11:07 AM #20
The $4K include them performing the replacement? Also, does that include all hard and soft lines, and the pumps?
Also, if you do swap for the Dobinsons, you would need to get non-XREAS sway bars. Since XREAS helps reduce body roll with the suspension, the sway bars aren't as thick which means they're softer. Once you go to regular shocks/struts they aren't helping in that area nearly as much, so you need to get the sway bars that are for a 4R that does not have XREAS.
Old 08-25-2021, 11:19 AM #21
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Agree
Need to replace sways with trd* or Sr5 4w. The Sr5 2wd sway us same as Limited.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 02:15 PM #22
L1011's Avatar
L1011's Avatar
Truthfully, I don't know. It was back in December of 2020 when I got the quote and it was verbal. I presume it involves replacing a lot of the XREAS components and other stuff.
Do both the front and rear sway bars need to be replaced? I presume I should replace the sway bar links too...?
I tried looking on YT for replacing sway bars on 4Runners, but only found a real short video that lacked a lot of detail. Is this something a novice could do? I'm not afraid of wrenching on my vehicles (I do my own brakes, oil changes, etc.,) but suspensions are a skillset I've not developed (yet!).
Stick with stock non-XREAS sway bars or perhaps go aftermarket? TIA!
Old 08-25-2021, 04:02 PM #23
L1011's Avatar
L1011's Avatar
It appears there are two different part numbers for sway bars (stabilizer bars) for the 2015 4R's: 48811-60390 and 48811-60340
The various online Toyota parts vendors don't go into specifics for the difference between the two part numbers, but they list "Limited, SR5, TRD Pro, Trail" in the fitment section for both part numbers.
Both part numbers list "with dynamic suspension" in their descriptions too. The xxx90 part number is $266 and the xxx40 part number is $224.
I can't tell which one is the thicker version installed in the SR5 and which on is the smaller version installed only in the Limited. I'll have to call the parts dept at my dealer to see which part I need.
Old 08-25-2021, 06:28 PM #24
4Person 4Person is offline
4Person is on a distinguished road
Subscribed. I’ve removed the XREAS and replaced it with Bilsteins, but haven’t messed with the sway bars yet (it wasn’t on my radar). I replaced the rear links with aftermarket stock size because one broke in the process of adding lift springs.
The 4Runner seems to drive ok without the upgrade, but makes sense to replace with the beefier versions to be safe. I guess that’s the thing I’ll be researching now.
Mine - 2015 Black 4Runner LE
Hers - 2017 Black Highlander XLE
4Person is offline   Reply With QuoteReply With Quote
buddy , delete , helping , system , x-reas
Replace X-REAS suspension without removing X-REAS Fareastplaza Maintenance/Detailing 18 07-31-2023 05:07 PM
Rear Wiper - To delete or not delete? SpidermanGeek 3rd gen T4Rs 3 01-29-2015 09:53 PM
Helping a buddy. Can you help? ASUMTNEER 3rd gen T4Rs 5 10-14-2014 05:19 PM
Need a shop in FL to Install Icon, delete X-REAS? UFG8R Runner 5th gen T4Rs 12 07-11-2012 09:04 PM
R.i.p. Little Buddy! K_Labs Classic T4Rs 6 03-20-2008 02:39 PM
