Old 08-20-2021, 03:21 PM #1
JustATallDude JustATallDude is offline
Real Name: Alex
JustATallDude will become famous soon enough
Real Name: Alex
Need help finding a noise..
I've been dealing with a clank in my 19 Pro ever since I installed the Eibach pro lifting springs. It usually happens when I'm full lock reversing or if I brake hard. Every bolt is tight and everything looks the way it should. I ended up getting an old GoPro and stuck it under to see if there was anything visible. I can't see anything wrong but there is definitely some noise. I'm trying to get this resolved before I install the supercharger. Any ideas?
Any ideas on the noise? - Album on Imgur
2019 TRD Pro Voodoo Blue - aFe Power CAI - Gibson Single Exit Exhaust - Magnuson Supercharger - 2021 Head Unit - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 with 0 offset - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Old Red's Turn Signal Mod, AMD Mod, and Footwell Light Mod - R4T Blackout Turn Signals - 4Runner Lifestyle Carbon Mirror Caps - BlackVue DR590 Dashcam and more to come...
JustATallDude is offline   Reply With QuoteReply With Quote
Old 08-20-2021, 04:02 PM #2
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Nice video! Yeah, just like mine noise and clank after I installed the Kings. In my case it was LCA bushings, both sides on rear. I suggest to check those first, won’t cost you anything, any mechanic should know how troubleshoot those , takes about two minutes. Try that first. Good luck!
ax2021 is offline   Reply With QuoteReply With Quote
Old 08-20-2021, 04:06 PM #3
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
That would be annoying as hell..From the look of the video it sounds like it happens when the UCA cycles up..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 08-20-2021, 04:58 PM #4
CarlsbadWyatt's Avatar
CarlsbadWyatt CarlsbadWyatt is offline
CarlsbadWyatt is on a distinguished road
Can you get the clunking from rocking the vehicle? Maybe have a second person and try to pinpoint the location while rocking it. Did you install your lift or have a shop do it? The long bolt thru the UCA needs to be torqued when off the jack and has the weight of the vehicle on the suspension. It’s hard to tell if the sound is from the UCA but that’s where I would start.
2019 ORP w/ KDSS
King shocks, Dirt King UCAs, Dobinson Springs, Demello Sliders, Rago Front Bumper w/ Baja Design 30” S8, Rago MSP w/ attic, Toyo AT3, Durabumps, OEM Audio+, Diode Dynamics Lighting
CarlsbadWyatt is offline   Reply With QuoteReply With Quote
Old 08-20-2021, 05:06 PM #5
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
rubbing on UCA or body mount?? Hard to tell from video..but it sounds like you are rubbing...
Old 08-20-2021, 05:14 PM #6
Real Name: Alex
Real Name: Alex
Thanks for the ideas!
I did install the lift myself with my dad's help. I did try the rocking method before and did loosen the UCA bolt to try to fix it that way. I think it did help so maybe I need to try again?
I will have someone take a look at the LCA bushings I did not try that.
I'm also very sure it's not a rubbing problem. I'm well away from the Body mount and UCA.
I showed one of the techs at work and he thinks the skid plate could be too tight. I'm going to try to take that off and see if the issue continues as well.
To be continued...
Old 09-01-2021, 12:59 AM #7
chef744's Avatar
chef744 chef744 is offline
Real Name: Gino
chef744 is on a distinguished road
chef744's Avatar
Real Name: Gino
To be continued...
Did you get these suspension noises figured out?
I’m chasing after some clunking/ clicking/ creaking noises after my eibach pro lift install too. (nothing to do with the lift kit really, just an aging truck I guess) LCA cam bolts are torqued to spec, sway bar links and bushings were changed out too. Noise seems to be popping up under hard braking or acceleration when load shifts front to back or vise versa.
chef744 is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 01:02 PM #8
Real Name: Alex
Real Name: Alex
So I tried a few things. I did loosen the UCA bolt again and did a more aggressive test but that didn't help and it wasn't the skid plate. I haven't had a chance to see the LCA bolts so that'll be my next day off.
Old 09-07-2021, 01:34 PM #9
Real Name: Alex
Real Name: Alex
I have found the issue! It was the LCA bolts. They weren't torqued tight enough. Set it to 130 ft-lbs and so far so good!
Old 09-14-2021, 01:35 AM #10
chef744's Avatar
Real Name: Gino
chef744's Avatar
Real Name: Gino
Nice! Glad you got your noises figured out. I’m gonna try one more time before I bring mine to a shop. Just to confirm and pardon my ignorance (first time to tackle this myself) did you have to torque all 4 nuts and all 4 bolts?
Old 09-14-2021, 08:17 AM #11
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Chasing the same noise. Found the rubber shock bushings are failing, but not convinced the upper strut mounts(top hats) dont need replacing. Should have some new bushings in a few days, if that doesn't work... pulling the struts for a good inspection.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 08:24 AM #12
Charlievee's Avatar
Charlievee's Avatar
This is the worst one out of the 4 shocks. Pulled it and replaced it with one from the "help section". The one i removed felt almost like hard plastic. Loosened the other side thinking they are over torqued and now have the noise on that side also. Stock and poly bushings are in the mail.
Need help finding a noise..-20210911_160409-jpg
Old 09-15-2021, 03:59 PM #13
Real Name: Alex
Real Name: Alex
I torqued them all, yes. I had my torque wrench set to 130lbs I don't think it needed to be that much but it's better to be safe than sorry
Old 09-15-2021, 05:11 PM #14
Charlievee's Avatar
Charlievee's Avatar
Fyi, spec for LCA is 129 ft lbs.
Old 09-16-2021, 10:08 PM #15
chef744's Avatar
Real Name: Gino
chef744's Avatar
Real Name: Gino
Thanks man! Ended up just taking the truck back to my mechanic. Issues now solved!
ended , gopro , noise , pro , stuck
Need help finding a new 3rd gen! Project_toothless 3rd gen T4Rs 0 06-18-2015 09:15 PM
Need help finding a pic MikeDUBS 5th gen T4Rs 10 03-05-2014 03:46 PM
Help finding a new T4R pbcolt 3rd gen T4Rs 2 12-06-2009 10:40 PM
Need Some Help Finding This bat8049 4th Gen T4Rs 3 07-13-2008 02:10 PM
need help finding weird noise pflfw Problems & Warranty Issues 1 10-16-2004 06:18 PM
