Old 08-21-2021, 07:49 PM #1
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
Is this normal with SCS Ray10 -38 offset
Just mounted my new Tires on ray 10 wheels 17x9 -38 offset and that’s how they look. It’s really bothering me since the tires don’t seat flash with the rim. Any body have the same issue. I attached a different picture for comparison.
Thanks
Is this normal with  SCS Ray10 -38 offset-f9b03bd3-8a43-4646-8002-5d242c3e9e57-jpg  Is this normal with  SCS Ray10 -38 offset-992865d1-3da9-46c5-9590-710b9f7994f7-jpg  Is this normal with  SCS Ray10 -38 offset-aa8cc782-4d0e-42e7-b537-a4ac6712c975-jpg
Bonniem is offline   Reply With QuoteReply With Quote
Old 08-21-2021, 08:07 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Guess you should have gone with the Coopers?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 08-21-2021, 08:12 PM #3
Bonniem's Avatar
Bonniem's Avatar
Seems like BF Goodrich KO2s have that issue comparing to other tire brands.
Old 08-21-2021, 08:30 PM #4
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Mine does not look like that. I'm no expert but you might want to get that checked out at another tire shop.
Old 08-24-2021, 08:45 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I worked in a tire store for many years while in college and I would say, no not normal. The tire bead should be stretch all the way to the edge of the inside of the wheel. There’s nothing special with the rays 10’s why the tire bead would not sit flush.
I have 295/70/17’s on the same scs ray10’s 17x9 -38mm and don’t have that issue.
I suspect, the installer didn’t lube the inside of the tire enough while adding the initial air. The air suppose to pop/push the bead to the edge of the wheel if installed properly.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 08:50 PM #6
What size are your tires ? Perhaps is not wide enough for 9” wheel ?
Old 08-25-2021, 04:01 AM #7
6uam671_T4R 6uam671_T4R is offline
6uam671_T4R is on a distinguished road
If you’re running KO2s, that might be your issues. Same issue with my 1st set of Ray10s with KO2 tires.
For reference: SCS Ray 10 tire sidewall not fully flush... | Tacoma World
6uam671_T4R is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 04:03 AM #8
Originally Posted by 6uam671_T4R View Post
If you’re running KO2s, it’s common. Same issue with my 1st of Ray10s with KO2 tires.
So this is a KO2 issue ? Crazy
Old 08-25-2021, 04:07 AM #9
Appears to be. I’ve seen several Ray10s with KO2s and they all look similar.
Old 09-12-2021, 02:34 AM #10
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
I’m running ko2 in the 285/70/17c flavor. It’s the tire themselves. Ridge grapplers “seat” better for some reason - which leads me to believe they’re overall larger.
I’ve got BR6’s with the -38mm offset which means mine are also 17x9
perf0rmance is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 09:35 AM #11
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Another reason not to run K02s like every other brolander cruising Wall Mart. They don’t balance worth a crap, and now apparently don’t sit flush on Ray 10s.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 12:08 PM #12
montijo505's Avatar
montijo505's Avatar
KO2’s have no wheel protector. Some tires have more aggressive ones, like these Duratracs.Is this normal with  SCS Ray10 -38 offset-img_2625-jpg
Old 09-13-2021, 02:16 PM #13
I agree. I believe the inner diameter of the k02’s contact area on the wheel is smaller the other tires.
Also perhaps the diameter of the -38mm scs wheels have a larger diameter especially around the contact area where the tires seats.
for now, just avoid ko2’s w/ scs -38mm wheels. I don’t believe this is an issue with -10mm scs wheels.
Old 09-13-2021, 04:34 PM #14
NeverSummer303 NeverSummer303 is offline
NeverSummer303 is on a distinguished road
I have the same issue with my k02s and ray 10s
NeverSummer303 is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 09:01 PM #15
-38mm or -10mm ?
don’t , flash , offset , seat , tires
SCS Ray10 -38 offset Bonniem 5th gen T4Rs 32 08-04-2021 06:36 AM
Oh Em GEE - Another SCS Ray10 + KO2! seatownhokie 5th gen T4Rs 9 07-31-2021 07:21 PM
SCS ray10 with -38 offset Bonniem 5th gen T4Rs 46 01-29-2021 05:51 PM
17x9 -12 offset wheels...or similar offset to SCS f5...what are my options? chrissurfr 5th gen T4Rs 3 09-20-2018 06:47 PM
