Old 08-25-2021, 10:22 AM #16
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Originally Posted by Hammer0313 View Post
Anyone know if those have crush washers?
Yes, it has two actually, one on either side of the oil pipe. I've checked mine a bunch of times and never replaced the washer and had no leaks. I always make sure to torque it back.
another piece of cheap insurance is to check or just replace the PCV valve every once in a while. They are like $5.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 11:23 AM #17
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
Anyone know the quoted torque for this part?
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 11:36 AM #18
Jivewalker's Avatar
Jivewalker's Avatar
48Ftlb
I am fragile.
Not like a flower.
But like a bomb.
Old 08-25-2021, 11:51 AM #19
Originally Posted by Jivewalker View Post
48Ftlb
Thanks. Wasn’t sure if it was the 48 and in ft-lbs.
Old 08-25-2021, 12:55 PM #20
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
You have the part number for the PCV?
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 08-25-2021, 01:44 PM #21
Jivewalker's Avatar
Jivewalker's Avatar
Put your VIN# in this site below and you can look up specific part numbers. yours may be different than mine. This is a great site that I've been using for a while to find part#'s.
Please Wait... | Cloudflare
I am fragile.
Not like a flower.
But like a bomb.
Old 08-25-2021, 02:08 PM #22
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
That site is awesome, thank you!
Old 08-25-2021, 02:14 PM #23
I agree. I have asked countless questions, some actually stupid or right in front of me, and not one member has been an ass or anything less than nice. It’s a great forum. Forums typically reflect a lot about the product, too. Says something!
Old 08-26-2021, 03:31 PM #24
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
good info. thank you. i never thought this filter exists.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 01:17 AM #25
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
If you’re changing your oil on time there should be no reason for those filters to have any build up.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 03:54 PM #26
Teocalli Teocalli is offline
Teocalli is on a distinguished road
P0012 + P0022 hopefully gone !
Thanks for the info guys, I have been struggling with these codes for a while now.
In my case the VVT sensors were the culprit, covered in sludge.
My OCV solenoids looked fine and the filters were a bit dirty, shook them in a bottle of Isopropyl Alcohol.
Just added some Sea Foam so will do another oil change in a couple hundred miles.
wish me luck,
Dave
Teocalli is offline   Reply With QuoteReply With Quote
Old 10-14-2021, 09:36 AM #27
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
wish me luck,
Dave
Do you have any photos of the VVT sensors covered in sludge? Do you know what caused the sludge buildup? I'm always curious about anything maintenance related. Keep up posted on the sea foam please. Good Luck!
Old 10-16-2021, 08:02 AM #28
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a glorious beacon of light <<<< is a glorious beacon of light <<<< is a glorious beacon of light <<<< is a glorious beacon of light <<<< is a glorious beacon of light
<<<<'s Avatar
Totally unnecessary unless you like to take things apart and have copious amount of time. I just replaced PCV on my 2004 sludge prone 4.0 V6 and it looked and sounded perfect just as it was new. Save your effort for more useful stuff, better yet ,if I may recommend, get an oil catch can to keep oil residue from entering intake valves and combustion chamber.
<<<< is offline   Reply With QuoteReply With Quote
Old 02-21-2025, 08:21 PM #29
Urbn_Overland Urbn_Overland is offline
Urbn_Overland is on a distinguished road
So yesterday my CEL and Trac Off came on but the 4 runner was riding fine. 2017 155k SR5 Premium. I was close to autozone so I stopped in and had them check the code. P0022 Camshaft position -timing over retarted Bank 2. I took it to Toyota this morning and they said $12k to fix. I'm like WTF and just paid the diagnose fee and drove home. They said timing chain replacement, and all 4 cams. I drove home and car starts as normal and idles as normal, drives as normal. I did hear a little rattle very faint twice on the ride home which was 20 miles.
Could it be the timing chain? Oil changed all the time and the truck was running perfectly.
Urbn_Overland is offline   Reply With QuoteReply With Quote
control , maintenance , oil , valves , vvt
4.0L V6 VVT Oil Control Valves scootermcrad 4th Gen T4Rs 35 04-27-2021 01:52 PM
Oil Control Valves, OEM or other? JackDuggan 4th Gen T4Rs 0 01-23-2020 06:16 PM
K & N replacement filter Shanesteeze For Sale: T4R Items 0 07-06-2011 08:27 AM
Replacement Air Filter Cutupsum 3rd gen T4Rs 39 11-20-2005 09:43 PM
TRD Replacement Air Filter Koz Engines / Suspension / Wheels / Tires / Audio / Accessories 18 04-29-2005 03:47 PM
