Old 08-23-2021, 03:03 PM #1
FiReBReTHa FiReBReTHa is offline
FiReBReTHa will become famous soon enough
Idea for testing a bad sway bar link to find a clunk
Swapped out bad 6112s for 5100s and oem springs, got new 285s and new wheels. Got alignment done. New pads rotors and slide pins.
Yesterday noticed a light pop/clunk only at slow speeds during braking and brake release. Noise does not occur over bumps nor during turns from what I've attempted.
Noise "feels" like it's coming from drivers side.
Because it's not during bumps I was skeptical on lca
Volume of clunk is like a 1-3 out of 10 and a busted bushing/slamming lca hitting during a curb rise would be a 8 out of ten for comparison.
Was thinking to disconnect sway bar link from the sway bar and zip tie it to sway to test it out.
But, now thinking about it concerned of course when unbolting it, may not be able to tighten it up etc if it doesn't have flats to grab onto.
Didn't want to play the random swap out game
Check out my Build here
2014 Trail Premium - 285Dura - 5100/5160 2.5"F/2"R
FiReBReTHa is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 03:21 PM #2
MikesDuneRunnerSLS MikesDuneRunnerSLS is offline
MikesDuneRunnerSLS is on a distinguished road
Bilstein doesn't do a good job of advertising it but 6112's are rebuildable.
Grab yourself a hammer. For this I like my larger ball peen. Touch the hammer handle to the bottom of the stabilizer link then wrap on the head with your hand and listen. Get a second set of hands and do the same thing with someone pulling down and putting a load on the sway bar with their hands and their body weight. If the noise significantly changes you've probably found your problem. You can also try the wiggle test but you can't always get noise with that. Another option is to see if a friend has a 4-channel chassis-ear you can borrow.
Good luck!
2011 SR5 Non-KDSS 4x4
Hyperco-650#/6112-BCV | B12 SS+1.5 Coils/8100-SB/R, PerryParts Bump Stops, NitroGear UCAs, 2G Rear SBLs, MCP Frame Gussets, CSF#7085, SprintBooster v3, MBRP 304SS Exhaust, MCP Drone Dampers, SAIS Exorcism, Odyssey AGM, ARB Skids, MCP Front Skid Anchors, MCP Filler-Flipper, Rival Fuel Skid, Spidertrax, Falken AT3W
Ask me about my HORRIBLE experience with DuroBumps
MikesDuneRunnerSLS is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 03:47 PM #3
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
I honestly know nothing of 4Runner brakes, but I had that issue with a dip **** mechanic who screwed up the springs that take up the gap where the pad can slide in the caliper on a VW many years ago.
Horrible grammar, but you get what I’m saying. If there’s something to stop the pad from rotating in the caliper, I’d check there first.
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 03:48 PM #4
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
Maybe something with the pins? Seems to be a recurring issue with my rig anyway but only after they've been in for a while. I've got a bit of a noise on brake release at the moment, probably at least 30k miles on em though. Pads are still good so I'm not in a hurry to fix it.
Skykomish is offline   Reply With QuoteReply With Quote
bar , clunk , lca , link , sway
Sway bar end link NEED HELP bzettler83 4th Gen T4Rs 4 11-15-2014 08:08 PM
wish I could find link. dadigab 4th Gen T4Rs 3 05-01-2014 08:09 PM
sway bar link help sethish17 Maintenance/Detailing 9 12-17-2010 03:54 PM
Sway Bar End Link price311usn 3rd gen T4Rs 6 03-07-2010 12:14 AM
Sway Bar Link? 4RUNR88 3rd gen T4Rs 9 11-29-2006 02:50 PM
