Old 08-26-2021, 03:10 PM #46
Sp00ner's Avatar
Sp00ner Sp00ner is offline
Sp00ner will become famous soon enough Sp00ner will become famous soon enough
Sp00ner's Avatar
Originally Posted by downshift View Post
Timing is controlled by a map in the ECU. There's a max advance for any given place on the map. That max can be decreased if pinging is detected. If you are at max advance on 87 octane, meaning the engine is not pinging, then increasing the octane won't get you any more timing advance.
Basically this.
The ECU is generally always trying to get to max desired spark advance. Without access to the maps, we can all guess how it works, but generally speaking it's always trying to get to a certain advance at a certain load. Though there's usually several tables that further modify that, intake air temps, coolant temps, open loop vs closed loop, etc.
The ONLY place I'm curious if it can gain a degree or so of advance, is because it can handle some Ethanol. For those that have never run E85 and had access to a tune, you can dial in a lot more advance on E85 (generally speaking). Of course, the difference would be almost impossible to notice, but I am curious if running E0 91/93 would get you the same advance as running say 87 E10.
Tossed some pics from HP Tuners from my old LSJ for the OEM Stage 2 tune, my 100 Octane tune and the IAT modifier table. It can get really interwoven depending on the OEM's approach.
So what exactly happens if you run Premium in a 4Runner?-100octanetiming-jpg  So what exactly happens if you run Premium in a 4Runner?-stagetiming-jpg  So what exactly happens if you run Premium in a 4Runner?-iattimingmodifier-jpg
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
Sp00ner is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 03:19 PM #47
vondy21's Avatar
vondy21 vondy21 is offline
vondy21 is on a distinguished road
vondy21's Avatar
I just commented on another thread about this.
A few years ago I posted about how my truck bogged down drastically when city driving in 90+ degree temps. I could almost put the peddle to the floor and it seemed to take several seconds to get any type of response.
Someone here suggested running a higher octane. I've been doing it ever since when temps get high.
The 4runner scoots around like it should, no bogging. When the temps cool off I go back to regular.
The explanation was the timing adjusted with the increased octane. I don't know if this is true but my problem was solved.
It's a pretty immediate effect. It's very noticeable to me too, I certainly would not be spending the extra money if not.
2017 TRD Off-Road Premium
Magnetic Gray - KDSS
Stock suspension, Michelin Defenders LTX MS
vondy21 is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 03:23 PM #48
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Originally Posted by BorotHex View Post
You’d think it would have been settled long ago with a dyno, but I’ve asked several times and nobody has anything.
If I didn't have full time 4WD (Limited), I'd volunteer as tribute.
Until then, it's really just lots of testimonies, supposed to's, and I read somewhere about something. Oh well, still fun to discuss.
And btw, I mainly run 91 in mine too lol.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 03:27 PM #49
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Originally Posted by TEujunga View Post
This makes no sense to me. Knock is load-dependent, and there is no load at idle. I've never heard an engine knock at idle, and that includes old-school carbureted engines with no timing controls and plenty of advance. In fact, the only reason advance mechanisms were necessary before computers was to prevent kicking back during start-up. Once running, the engine could tolerate tons of advance without knocking as long as it was not under load.
The most challenging situation for managing knock is low RPM, high load (i.e., "lugging"). Low RPM, low load with the throttle closed shouldn't be a problem for any engine.
I think - just guessing - that it needs to run very lean at idle to meet emissions targets. Running lean at idle is hard to manage is my guess. Also that engine is 11.8:1 compression ratio - to it's a good bit higher than the 1GR. But... the 2GR FKS has variable compression via the extended valve timing. So it may run at 8:1 or something during idle.
Old 08-26-2021, 04:11 PM #50
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
Maybe useless info, but do you live in an area affected by different seasonal blends?
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 04:23 PM #51
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
i kinda feel that way too.. i leave the house in the early morning and my 4runner definitely has more pep? As mid day comes along and temps rise to triple digits it drags like a slug. A/C on or off, sometimes i just drive windows down in 100+ weather for fun... AC kicks on when my kids are with me..
could be the same idea with cold air intakes and the colder air in the morning yadi yadi la bla bla
1jzgte is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 04:42 PM #52
vondy21's Avatar
vondy21's Avatar
Not sure what the numbers mean on that map but being in Dallas I'm in either the pink or brown area.
it's pretty consistent, the closer we get to 100 degrees, the more heat soaked the engine gets and she bogs down. Put in 93 and she bogs no more.
I will note this is for big city driving, lots of stop and go in the sweltering Texas heat. Highway or small town driving probably isn't as noticeable.
Old 08-26-2021, 04:46 PM #53
vondy21's Avatar
vondy21's Avatar
I'd be curious to see if you find a change putting in the higher octane.
Not sure if humidity makes a difference though, looks like you are in Nevada. Here it's 97 degrees with 80% humidity sometimes.
Old 08-26-2021, 05:29 PM #54
downshift's Avatar
downshift downshift is offline
downshift is on a distinguished road
downshift's Avatar
What's likely here is that your engine was pinging when the temp got hot. You won't hear it, the ECU will detect it long before it's audible to your ears. The ECU detected pinging and retarded the timing. When you put higher octane in, the ECU could return the timing to the proper advance.
Current: 2017 TRD Off Road with KDSS
Previous: 2003 Sport Edition AWD
Before That: 1993 Pickup, SR5 V6 5MT Extended Cab 4WD
downshift is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 05:33 PM #55
downshift's Avatar
downshift's Avatar
Originally Posted by Sp00ner View Post
Basically this.
The stock ECU maps are typically pretty conservative. It's one of the main ways tuners extract more power with "chips" (Chips are no longer used, the ECU can be reprogrammed through the diagnostic port. But people still use the word chips or chipped.).
The new maps will have more advance at any given spot on the map. This will get you more power, but at the risk of pinging. Increasing octane can reduce the pinging.
Old 08-26-2021, 06:58 PM #56
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Wikipedia used to say it makes 278 hp and 290ft lbs with premium fuel but that part has since been removed.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 07:06 PM #57
Wow, that is deadly stuff right there. In the east/northeast when that happens people die. It’s not talked about a lot, and it seems to be better than it used to be, but when it gets that hot in big northeastern cities the elderly actually die from the heat. Others, too, from working outside, getting stranded, etc. Dangerous stuff.
Old 08-26-2021, 09:36 PM #58
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
We call it a typical summer day in South Louisiana. It was 95F in the shade, 110F everywhere else, with 85% humidity and a dew point of 77 yesterday. You MUST hydrate and adapt to it. I went to Navy boot camp in Florida in the summer (forever ago), the guys from up North were having trouble...I thought it was nice to not have such thick humid air and it was cooler there than my hometown.
2019 MGM TRD ORP
Dobinsons IMS lift, FN f(x) Pros, 285/75 Nitto Recon Grapplers, and a really long list of other stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 11:39 PM #59
MikesDuneRunnerSLS MikesDuneRunnerSLS is offline
MikesDuneRunnerSLS is on a distinguished road
Engine management will adapt and advance timing based on ambient conditions and new sensor data from the change in octane. Adaptation will happen faster when driven in a more aggressive manner. Especially WOT events.
On daily drives I run Nuvu's 88 Octane Regular. On days when I run the Silver Lake Sand Dunes I dump in a can of Royal Purple MaxBoost once I'm at a half full tank then I fuel up with 93 octane. On Dune days when I can fuel up from a quarter tank I fill up with 93 and I skip the booster. Quick numbers puts those mixes just under 92 octane. I live roughly 90 miles from Silver Lake. I can usually feel difference in acceleration halfway through the trip there. When I stop before the entrance to put my flag on I can feel and hear the difference in the engine idle. On rare Dune days when I fuel up with the low-fuel light on, I fill up with 90 octane Rec Gas. Call me crazy, the butt-dyno says the Rec Gas is the best performance of all.
2011 5G4R SR5 Non-KDSS 4x4
Fox 2.5 FRS w/DSC, Dobinson Rear Coils, MCP Cam-Tab Reinforcement, Poly Performance UCAs, PerryParts Bumps, MCP Bump Plates, DrKDSS BOTCK Shorty, HFW Spindle Gussets, MCP Bolt-On Frame Stiffeners, 2G Rear SBLs, CSF Radiator, AFE M/GT CAI, SprintBooster, Ripp Catch-Can, MBRP 2-1/2" 304SS CBE, MCP Drone Reduction Sys, Odyssey AGM, ARB Skids, MCP Front Skid Cross-Member Weldment, MCP Front Skid Anchors, MCP Filler Grip-Bar, Rival Fuel Skid, Spidertrax, Falken AT3W 275s, MCP Whip, Mounts & Forged Rec-Bar, +Extras...
MikesDuneRunnerSLS is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 12:59 AM #60
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
So everyone is getting tunes now??
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
benefit , curious , iphone , reason , timing
Anyone made a SR5 Premium 4Runner look like a Trail Edition or TRD Off Road 4Runner? arouth 5th gen T4Rs 5 06-30-2020 10:05 PM
WTB: 5th Gen Off Road Premium or Trail Premium with KDSS PavementPrince$$ Want to Buy/Trade 0 05-22-2019 07:13 PM
Premium side mirrors work on non-Premium? DeepSea 5th gen T4Rs 5 05-07-2018 08:11 PM
GX 460 (Premium and Ultra Premium) Test Drive Review/Result Lolrax 5th gen T4Rs 36 10-04-2013 09:15 PM
