Old 08-29-2021, 01:58 PM #1
Jeffrey_VB's Avatar
Jeffrey_VB Jeffrey_VB is offline
Jeffrey_VB is on a distinguished road
Jeffrey_VB's Avatar
Radiator Cover Clips
Popped the radiator cover off today to install a grill badge. Cover came off ok, but when I reinstalled the cover, none of the 13 plastic clips that hold that cover in place are grabbing, the cover is loose and the clips just pop right out. I was installing by pulling the center out, pushing the clip in, then popping the center pin back in place. The pin clicks in place, but just not grabbing. Are these clips single use only?
2021 TRD Off Road Premium in Midnight Black
Not Much Yet...But More to Come!!!
Jeffrey_VB is offline   Reply With QuoteReply With Quote
Old 08-29-2021, 02:06 PM #2
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
No. To remove the cover you press the center in till it clicks. Pull them pin out. To put it back on you pull the center up above the pin. Put them pin in and press the center until it’s flush with the pin
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 08-29-2021, 02:14 PM #3
Jeffrey_VB's Avatar
Jeffrey_VB's Avatar
Yep, did those steps, they still won't grab when I pop them back in. Even if I pop them in, without the cover in place, they they pull right back out.
Old 08-29-2021, 02:16 PM #4
When you pop them in do they expand on the bottom?
Old 08-29-2021, 02:19 PM #5
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I replaced my clips with some from Car Quest or someplace like that. The old clips did not work right for me either. The new clip have slots so that a clip removal tool can be used to reuse them over and over with easy removal.
I do not remember what size I used but if I recall I had to ream the holes out slightly for the new clips.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 08-29-2021, 02:52 PM #6
Jeffrey_VB's Avatar
Jeffrey_VB's Avatar
Slightly
Old 08-29-2021, 02:53 PM #7
Jeffrey_VB's Avatar
Jeffrey_VB's Avatar
I've already ordered some from Amazon. ;)
Old 08-31-2021, 12:07 AM #8
trdgmn's Avatar
trdgmn trdgmn is offline
trdgmn is on a distinguished road
trdgmn's Avatar
This has happened on a couple of the fasteners when I reinstalled them, but it was because I accidentally pushed the center pin of the fasteners down when I reinstalled causing them to release.
trdgmn is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 06:27 PM #9
Mass 4runner's Avatar
Mass 4runner Mass 4runner is offline
Mass 4runner will become famous soon enough
Old post I know, but do you know what the part # for these clips was?
2023 4runner TRD Off Road
2013 Camaro SS
Mass 4runner is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 08:36 PM #10
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
They selll them cheap on Amazon.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 09:12 PM #11
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I prefer these clips but the aren’t “push to release”, you need a flat blade or the supplied tool. They’re a little wider than stock.
Amazon.com
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 10:56 PM #12
Amazon.com
Do these work on the radiator cover?
2013 Camaro SS
Old 08-19-2023, 12:30 PM #13
1000MPH's Avatar
1000MPH's Avatar
The Toyota Part Number for the upper radiator clip is 90467-07201.
Iirc there are 12 of them.
These work to replace the Toyota clips.
Amazon.com
Or you can buy OEM for $2.27 list.
Clip | Part #9046707201 | Toyota Auto Parts
This is what the Amazon ones look like in use. They’ve got a bigger head and hold more firmly.
Radiator Cover Clips-img_1355-jpg
Old 08-20-2023, 01:46 AM #14
Amazon.com
Awesome. Thanks dude.
2013 Camaro SS
Old 10-16-2023, 12:45 PM #15
Golfpilot Golfpilot is offline
Golfpilot will become famous soon enough
Had also annoyed me about the loose pins on the radiator cover.
Thanks to the detailed instructions I have learned about this push-to-release-pins. I had simply pushed them in too far at first. Push them "flat" an now the original clips hold correctly again.
Golfpilot is offline   Reply With QuoteReply With Quote
clips , cover , pin , place , radiator
Need Help w/ Tiny Part for 2000 4R (Rear Seat Back Cover Clips) T4R3G 3rd gen T4Rs 11 05-30-2023 08:33 AM
WTB: 4th gen push pins for front bumper & radiator cover firebirdguy Want to Buy/Trade 0 06-23-2019 12:38 PM
Grille clips for 96-02 4Runner, those with broken clips.... Jason B 3rd gen T4Rs 13 08-09-2018 04:24 PM
Cargo Cover Clips? Snesley Wipes 4th Gen T4Rs 9 01-21-2015 10:59 PM
Radiator cover plugs ? VBdiver 5th gen T4Rs 4 04-27-2012 06:38 AM
