Old 08-29-2021, 04:03 PM #1
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Dobinsons 238 front spring
Anybody have the 238 front spring? Did you get an inch of lift, has it settled any? Thinking about dropping the front of mine from the 1.6 and removing the rear spring. Ive realized I’m never going to try to squeeze 285s in and I’d like a softer ride.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 06:38 AM #2
DeezyFBeezy883 DeezyFBeezy883 is offline
DeezyFBeezy883 is on a distinguished road
I have a set of front and rear Dobinson's stock height springs if you're int.
Brand NIB
part #'s
c59-238
c59-323
2015 4Runner SR5 Magnetic Grey Metallic -
Dobinsons MRA - C59-314 springs Front - C59-327 Springs Rear - BFG ko2 285/70/17 - Pro Comp 05 17x8 - 1.5in WheelMate Spacers - Cali Raised Dual Function Light Bar - Rough Country Ditch Lights - Prisnu Full Length Rack -
DeezyFBeezy883 is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 04:22 PM #3
How much and what color are they? I guess you didn’t install them so you don’t have any performance feed back.
Old 09-01-2021, 04:43 PM #4
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I installed 238's 6 months ago. They have settled a bit. Measuring from center of hub to fender lower outer edge, I have 20.75 on LF and 20.5 on RF. I have KDSS. It was 19.25 and 19 when I replaced the original springs at 114,000 miles. If lift stays at or above 20.25 to 20 over the next 85,000 miles, I'll be happy
DougR is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 06:49 PM #5
That’s what puzzles me about Dobinsons. I was told 3/4 to 1” max. Even with settling you’re above that. My Eibach hasn’t settled at all but I think twin tubes shocks might give me a better ride on the road.
Old 09-01-2021, 07:41 PM #6
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
So I have a set of Dobinsons GS59-700 Front Struts and C59-350 730lbs springs. These are what were recommended based on what I have and what I wanted, supposed to be heavy load 2"+ inch lift (my truck is on the bottom end of their heavy rating). My CV's are almost level, so more like 1" lift, my center cap to fender is 20.75". To top it off one of the top hat bolts spun before it torqued (he sent along a replacement asap, so that was nice, still a fn PITA to pull the shock compress and replace), the pan bolt threads sheared had to cut it off. For the price I paid, they get a generous "meh" 3-of-5 star rating from me.
I guess main objective of my point is I got less than ~half the expected lift from the springs I received.
C59-238 - 1.0″ – Toyota 4Runner 2003 to 2020 Light Load V6 Engine
C59-350 - 2″-2.5″ – Toyota 4Runner 2009-21 Heavy Load 160-240LBS (varies by accessory weight and shocks used)
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 08:37 PM #7
DougR's Avatar
DougR's Avatar
I don't think I'm above 1 inch as inferred by your reply.
I'm assuming nominal front suspension height is 20 inches as often reported by others. Before installing the Dobinson springs, I also measured height from ground to frame, which indicated the original springs had sagged almost one inch after 114,000 miles, resulting in 19.25 left and 19 right as I quoted above.
As I see it, the 238s have lifted the suspension back to original height plus 0.75 lift on the left and 0.50 on the right.
I have KDSS, which means I generally see a 0.25 inch lower measurement on the RF after a trip. If I stand on the drivers side running board near the rear tire and jostle the vehicle, the front suspension levels out to 20.75 inches. Consequently, I am very pleased to have the minimum lift of 0.75 inches after 6 months.
Old 09-02-2021, 06:47 AM #8
I see what you’re saying now. I know every truck is different and I’m ok with 1/4” either way. I just don’t want to expect 1” and get 2” of have it settle a ton. I’d just keep my Eibach if they didn’t feel so stiff at low speeds. Maybe the twin tubes are the same.
Old 09-02-2021, 08:38 PM #9
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
I posted in The "Dobinson Many choices" thread in 12/9/2018 Page 84 #1255
All the before and after .
I Just measured it today Front Left still holding at 21" left rear 22 1/4"
I'm happy with that the ride is alot better than stock
So over all 1 1/4" on both
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 12:43 PM #10
jwscott79's Avatar
jwscott79 jwscott79 is offline
Real Name: Jason
jwscott79 will become famous soon enough
jwscott79's Avatar
Real Name: Jason
I've had them on for 3 years close to 40k...19 3/4 both sides stock springs - 21 3/4 both sides w/Dobinson 238. Measured today and both still holding 21 1/2 - 21 3/4.
I've been debating going to 285, I think they will fit but don't really want to take the chance of a rub. Think I will stick with stock LTs for another couple of years.
Pic is me and fam in Moab last summer
Dobinsons 238 front spring-moab4-jpg
jwscott79 is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 06:15 PM #11
Did you replace the rear spring as well? Dobinsons has a 323 zero lift rear spring with a little higher rate.
Old 09-03-2021, 07:09 PM #12
Are you trying to level the truck?
What shocks do you intend to use for the front?
As far as the rear I used the C59-599 Springs with GS59-705 shocks
This kept the rake and rides real nice
Old 09-04-2021, 08:19 AM #13
I was looking at the 700 shock in the front. As far as lift,I wanted either 1” and 0” or 2” and 1”. Not level but half the factory rake. I have that with the Eibach but I’m looking for something more comfortable on the highway.
Old 09-05-2021, 08:52 AM #14
jwscott79's Avatar
Real Name: Jason
jwscott79's Avatar
Real Name: Jason
I went with 599 rear coils and GS59-701 Rear Shocks. As others have mentioned, I still have a slight rake with this setup.
Old 09-08-2021, 12:31 PM #15
doc1303 doc1303 is offline
doc1303 is on a distinguished road
This is perfect. Thank you for posting this. I think you're the first person I've found in my extensive search for someone with 238 coils front, and 599 coils rear. Have any more pics with this setup? Great looking tire size too! What size are they? (you should probably add details in your signature so people like me don't keep annoying you!
doc1303 is offline   Reply With QuoteReply With Quote
dobinsons , front , realized , rear , spring
FS: Dobinsons 1" F/R Spring Lift for TRD Pro - $375 Baltimore, MD kaikaikai For Sale: Suspension/Wheels/Tires 1 07-15-2020 02:19 PM
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 Want to Buy/Trade 1 09-10-2019 08:21 PM
Dobinsons C59-505 rear with TRD Pro up front rasber3140 5th gen T4Rs 0 08-10-2017 08:49 AM
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 For Sale: Suspension/Wheels/Tires 3 11-05-2014 11:43 AM
