Old 09-03-2021, 10:45 AM #16
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
It should run about 100 bucks. Also, I work on my truck all the time without a torque wrench. Once I get the wheels back on I just stop by Les Schwab in the next day or so and have them put a torque wrench on it. Takes like 5 minutes and I've never had to wait.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 11:30 PM #17
Bruski's Avatar
Bruski Bruski is offline
Bruski is on a distinguished road
Bruski's Avatar
Originally Posted by Pedro367 View Post
That is a high lift jack, and no not that. Useless unless you have jack points on the vehicle. Your 4R came with a bottle jack that you use while on the road, so no need to carry a floor jack unless you really feel like it. Saves you the time waiting for AAA, that's for sure. I do recommend getting a floor jack and jack stands for home use. You'll use them more than you think. If you are going to spend money on anything to keep in the 4R I'd recommend getting an electric impact gun and an 80lb torque stick. Even with your factory bottle jack you can have a tire changed out in 2.5 minutes.
Call a shop and ask what they'd charge. Make sure they use the provided loctite and torque properly. I doubt it would cost much.
Ok thank you. But does the stock bottle jack lift my car high enough since it’s lifted now? I assumed it was for stock height 4runner (obviously never had to use it).
2016 White Trail | Black TRD Pro wheels | Victory Off Road Full rack | Ironman 4x4 Nitro lift kit with UCA | BFG AT 285/70/17 33
2001 Silver SR5 Sport | R.I.P. 244k miles
Bruski is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 04:34 AM #18
5thGenHunter 5thGenHunter is offline
5thGenHunter is on a distinguished road
If you do spacers, won't you need longer wheel studs?
5thGenHunter is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 10:13 AM #19
Bruski's Avatar
Bruski's Avatar
The spacers come with its own wheel studs where you attached the wheel to.
Old 09-04-2021, 10:32 AM #20
Bruski's Avatar
Bruski's Avatar
Powerbuilt 620470 Unijack - 4000 lb. Capacity Amazon.com: Powerbuilt 620470 Unijack - 4000 lb. Capacity : Automotive
I think I’m going with this. Is 4000lb enough or do I need to get the 6000lb?
Old 09-05-2021, 01:10 PM #21
Crossfit4runner Crossfit4runner is offline
Crossfit4runner is on a distinguished road
I wouldn’t mess with spacers in the first place. I’ve had them and tried everything to get my tires not to run. Only option was go back to stock size tires or a BMC. I took them off after month.
Crossfit4runner is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 06:26 PM #22
DingleTower DingleTower is offline
DingleTower is on a distinguished road
Not that you lift the whole truck at once but a 4Runner weighs more than 4000lbs. The 6000lb jack also lifts three inches more than the 4000lb which you may need.
I went with the 6000lb myself.
DingleTower is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 05:25 PM #23
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Originally Posted by Bruski View Post
Hey guys - I know it's easy to install wheel spacers but I do not own a jack for a lifted 4runner or a torque wrench. It might be worth buying them and doing it myself but does anyone know the cost for a shop to do it? I'm thinking a 20 minute job right?
Originally Posted by Space King View Post
The typical hourly shop rate in California is around $100 per hour.
Yes, it could (and probably will) take as little as 20 minutes, however it would take longer to do the job properly.
Personally not a fan of spacers, but you didn't ask.
You need better friends with tools
seatia is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 11:43 AM #24
AggieOE's Avatar
AggieOE AggieOE is offline
AggieOE will become famous soon enough
AggieOE's Avatar
Correct me if I'm wrong but I think the standard bottle jack will work well, even with larger tires. You'll want to place it under the axles which aren't affected by your lift.
So on trails, MAYBE you need a large Jack base for your stock jack. At home though, a nice jack and jack stands from Ace, HD, or Lowes will be plenty useful.
Don't get a Hi-Lift jack. You do not need it.
Also. get a friend or family member with stuff and know-how and see what they're using.
2015 4Runner SR5 4x4, Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
AggieOE is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 12:54 PM #25
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
For jacks, I've used my low profile jack on the 4R, from when I always played with lowered cars. For the rear, I jacked it up from the middle of the axle. Gets up more than high enough. For the front, I used the little circle indentation, this barely gets the front up high enough.
In the near future, I do plan to order the Pro Eagle 2 or 3. Or maybe have my friend fabricate a plate extension for current jack.
I see you're in socal, if you need some help, or want to use my equipment, hit me up
MasterFoo is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 01:40 PM #26
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
I put this on my low profile jack: Off Road Jack Extension 8" OR 15" - Pro Eagle
with this adapter: Lift pad EXTBM - Pro Eagle
I just needed to file the center hole a little larger on the adapter to get it to fit on my low profile jack.
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 07:08 PM #27
OH SNAP! I didn't realize they made those to work with other brand floor jacks. I used my brother in laws Pro Eagle and thought it was what I needed. Then I saw the price... and just put it on the back burner list of things I want to buy.
Was going to get a friend who does a little fabrication to make me a spacer to sit on top of the jack.
But this will do exactly that. awesome stuff! thanks for the info.
Old 09-10-2021, 07:46 PM #28
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP will become famous soon enough SilverTEP will become famous soon enough
SilverTEP's Avatar
Real Name: Luke
The few times I read about wheel spacers failing was when the user had a shop install them. Agreed with everyone on here, do it yourself, do it right, and make sure to continue checking. If that's a pain for you, just get a big negative offset wheel, safer in the long run.
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
SilverTEP is offline   Reply With QuoteReply With Quote
cost , labor , shop , spacers , wheel
Estimated labor cost for engine & tranny replacement NEKExplorer 3rd gen T4Rs 9 10-09-2019 11:00 PM
Labor cost on lift? Shadow 4th Gen T4Rs 17 05-05-2016 06:53 PM
Lift Cost: Bilstein 5100 4 shocks and 1 inch rear spacers SamT 5th gen T4Rs 13 08-13-2014 12:35 AM
90 USD Labor Cost for F/R Differential Oil Change hyperthread Maintenance/Detailing 5 12-22-2011 11:31 AM
Dealer Labor Cost on Replacement Seat Covers Hatrick 4th Gen T4Rs 4 05-07-2010 11:34 AM
