Old 09-02-2021, 03:51 PM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
My shocks are leaking. Need some advice
Hi everyone,
My front shocks are leaking. I have a 2016 limited with Xreas. Should I replace all four with bilstein 5100? do I need the springs too? Can I get a link to purchase a set? A mechanic told me I can just replace a leaking one with 48510-80499 from Toyota! I have heard that if one leaks, all four has to be replaced. Need clarification on this
Thank you
amir_gh is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 04:03 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by amir_gh View Post
Hi everyone,
Thank you
Good mechanic just replace the one that is leaking with oem if you like the ride. If you want to upgrade or lift then it's a matzo ball. you can get a set of 5100 pretty cheap from a bunch of vendors on line.
Bilstein 5100 Complete Set | 5th Gen 4Runner | FJ.
edit if you have the rear sag then get new rear springs. if you have the nose dive when braking get new fronts.
Old 09-02-2021, 06:13 PM #3
Forgetful Forgetful is offline
Forgetful will become famous soon enough Forgetful will become famous soon enough
I have take offs with 3k miles if you're interested and in az
Forgetful is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 06:59 PM #4
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Hi everyone,
Thank you
My limited understanding of x-reas is that shocks must be replaced with their diagonally connected pair.
As such I would recommend removing all four and replace them with whatever you like.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 07:15 PM #5
t6pilot t6pilot is offline
t6pilot is on a distinguished road
Just ordered a set from dobinson’s $399 delivered
t6pilot is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 07:16 PM #6
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
I’m looking at trading my 17 Offroad for a 22 limited. The first thing I’m going to do is change the shocks, wheels and tires. I wish xreas was an option like kdss that you don’t have to get.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:41 AM #7
orcking orcking is offline
orcking is on a distinguished road
I thought once one shock goes in the system, all system has to be replaced? no?
orcking is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 11:00 AM #8
spartacus's Avatar
spartacus's Avatar
If it was due to milage or age depending on use only then I would assume that. If you hit a pot hole or bump hard with one tire and caused a leak in that one then shock just replace that one. For better piece of mind you can replace them in pairs e.g front two or rear two. I have blown one shock before and have replaced just that shock without any issues.
Old 09-03-2021, 11:12 AM #9
A quick video showing how they are linked together (front left to rear right is separate from front right to rear left).
How the X-REAS Suspension System Works Off Road & On Road | Toyota - YouTube
or the care care nuts more detailed overview "you have to replace one diagonal" if one piece of that diagonal is bad, which is front corner, rear opposite corner, center shock, and the lines to/from those pieces:
Should you buy a Toyota 4runner? Is the suspension good? - YouTube
Old 09-03-2021, 11:12 AM #10
spartacus's Avatar
spartacus's Avatar
edit: in your case a pair, will be diagnal pairs front left and rear right , front right and rear left
Old 09-03-2021, 04:17 PM #11
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
You can replace a single XREAS shock one time. The P.O. of my limited has a single XREAS shock replacement early in the service record. The idea is the XREAS system can be opened one time, if done properly. If you replace one shock fine or replace all four. Either way, you get one shot at opening the XREAS hydraulics. AFter that the "valves" on the frame need to replaced as well. That is when people see the $4000 estimate for replacement. The question is..do just one now and hope for no more leaks...
I'm looking at Dobinson twin tubes as a replacement for my XREAS. I think they will be durable. Until XREAS leaks however, I like it, and hope to get many more miles before a leak, Im at 80,000 miles now.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
48510-80499 , leaking , replace , shocks , toyota
Rear main seal leaking, advice? oceanstate88 3rd gen T4Rs 21 01-17-2022 10:17 PM
Advice on 4runner v8 Head Gasket leaking Whytey Maintenance/Detailing 10 12-10-2019 09:56 PM
Who else has two leaking TRDP rear shocks? Dog Runner 5th gen T4Rs 23 04-25-2017 01:13 AM
Are my shocks leaking? KCcarguy 5th gen T4Rs 3 02-09-2013 12:55 AM
Shocks leaking on 2004 SE model wcarrington 4th Gen T4Rs 5 08-11-2008 11:49 AM
