Old 09-04-2021, 01:02 AM #16
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
I swapped my plastic housing for metal one about 65k miles ago 2.5 years and no leaks. Will check tomorrow though.
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 06:48 AM #17
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Originally Posted by 08TxRunner View Post
Ignore most of what this guy says.
You’re just upset because you know I’m right.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 06:58 AM #18
Originally Posted by MichBadger View Post
I did my first oil change about a month ago. I had bought the cheapest housing removal tool with decent ratings. The plastic housing was on so tight, I actually broke the tool. I then ordered the motive X removal tool and put the 27mm socket on the impact wrench to take it off. I didn't realize it during the process, but I had cracked the plastic housing and had a major leak. I needed the vehicle back in service so went and bought the Dorman version. Of course, as the reviews state, I've had a very slow leak over the last couple of weeks. I ordered the OEM metal housing and it literally was delivered earlier today. Now I read this thread...
This is the best tool for the job imho. Buying $5 Chinese crap will only lead to sadness, additional expense and being that much closer to China taking over the world.
Assenmacher Tool of Boulder, Colorado Toyota Filter Wrench
Sunroof
Old 09-04-2021, 12:33 PM #19
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Carefully inspect the o-ring for a small nick, micro crack, abrasion, flashing, or any other defect. Check both the filter housing and mating engine part for any scratch on a surface where the o-ring seals or passes over. Do not reuse 0-rings. Oil o-ring before installation. Post a photo showing installation of o-ring in the proper groove.
DougR is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 04:27 PM #20
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
We get it bro, you hate China
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 05:22 PM #21
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Originally Posted by KB180 View Post
Just changed mine last week with OEM filter and o-ring (2019). Never the slightest hint of any oil leakage around the metal housing. Attachment 386743
Sent from my SM-N960U using Tapatalk
Are those homemade wooden ramps? I want those.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 06:31 PM #22
MikesDuneRunnerSLS MikesDuneRunnerSLS is offline
MikesDuneRunnerSLS is on a distinguished road
Going off my experiences with the plastic oil filter "cap". Leakage is most common when if over torqued on install. Leakage is also common when the filter cap is installed and there is a lack of fresh oil applied to the outer o-ring prior to install. Leakage will be even more significant when both mistakes are made at the same time. In theory one issue with the metal filter cap could be different heat expansion rates between the truck-side housing versus the filter-side creating a gap for oil to leak past. My filter cap is fairly new doesn't leaking a drop. I ordered the OEM plastic one from McGeorge Toyota Parts online.
2011 SR5 Non-KDSS 4x4
Hyperco-650#/6112-BCV | B12 SS+1.5 Coils/8100-SB/R, Energy | DuroBumps<-Waste of $$$, NitroGear UCAs, 2Gen Rear SBLs, MCP Frame Gussets, CSF#7085, SprintBooster v3@R1, MBRP 304SS-CBE, MCP Drone Dampers, SAIS Exorcism, Odyssey AGM, ARB Skids, Rival Fuel Skid, Spidertrax, Falken AT3W
2016 GX LuxSpt KDSS
KDMax, Northstar AGM, SuperBumps | Timbrens, Hankook AT2/Xtreme
MikesDuneRunnerSLS is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 06:32 PM #23
DougR's Avatar
DougR's Avatar
That's an excellent ramp design for tires wider than stock. My handmade ramps are narrower for a stock tire size. Make yourself a pair. You'll find they are solid and stable. Mine have a ramp run-to-rise ratio of 16 to 5.5 inches which is easy to drive onto in 4Lo. The overall length of my ramp is 25 inches (flat) + 16 inches (ramp). The flat portion ends up being 21.5 inches long with a 3.5 x 3.5 stop block installed. His ramps appear to be a little higher than mine. 5.5 inches is the minimum height one needs to be able to remove a stock skid plate if the outer 1/4 inch of the J hooks are bent back from 90 to 45 degrees.
Old 09-05-2021, 12:37 AM #24
Real Name: Jo
Real Name: Jo
Thanks for the specs
Old 09-05-2021, 12:59 AM #25
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I’ve been thinking about making some for too long.
I want four of them.
1000MPH is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 10:45 AM #26
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
China has flooded the world with counterfeit parts, inferior parts, and generally they tend to lie all the way to the highest levels about basically everything.
You don’t have to hate China to not trust them and not want their junk. It’s common sense. And China did this to themselves, so I have no pity when people turn up their noses and say screw China and they’re junk.
BorotHex is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 04:05 PM #27
????? ????? is offline
????? will become famous soon enough
OP did you make sure to swap out the center cylinder with the one that was in the factory plastic cap?
For what it's worth I swapped to the aluminum housing almost 3 years ago and have done at least 8 oil changes since then with no issues whatsoever.
When I torque it to 20 ft lbs it always tightens down to the "just right" feeling.
????? is offline   Reply With QuoteReply With Quote
Old 09-05-2021, 06:50 PM #28
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
I've been doing oil changes for over 50 years. Yes, the metal housing is OE Toyota. Yes, I replaced BOTH o-rings having lubed them first. Yes, when I did my 1st oil change using the metal housing I swapped the internal perforated tube and have since swapped it back to the plastic housing. Yes, I torqued the metal housing to 18 ft-lbs.
I had no issues during the 1st oil change (about 1 year) with the metal housing as well as 3 months on the 2nd oil change. Yes, I'm baffled.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 09:11 AM #29
orcking orcking is offline
orcking is on a distinguished road
You did everything to specs.
I suspect the metal housing has something wrong with it.
you can always try to buy a new OE Toyota metal housing and try again. They are not that expensive.
orcking is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 10:08 AM #30
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
i did a oil change over the weekend. previously had a jowett filter. But i also did a lower pivot mount kit from jdfabrications. Ended up going back to the original problem free plastic filter.
My Jowett Housing needed a 2.5" deep socket hex french to clear. no space for that. Back to the trusty oem housing for me.
Amazon.com: Motivx Tools MX2320-US 64.3mm 14 Flute Precision CNC Machined Aluminum Oil Filter Wrench Compatible with all Toyota and Lexus Cartridge Style Oil Filter Caps and Select Spin-On Filters : Automotive cheap wrench made in the usa if you are looking
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
change , housing , installed , metal , oil
Replaced plastic filter housing with metal - question fir those that already did Nuke 5th gen T4Rs 36 02-02-2021 12:42 AM
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Broken plastic housing on remote key ALTAHLC 4th Gen T4Rs 9 08-04-2017 08:57 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
Plastic rear heater housing grey Hogan Classifieds - buy & sell (no commercial ads please) 0 11-30-2003 09:18 PM
