Old 09-06-2021, 11:56 AM #31
HighLighter HighLighter is offline
HighLighter is on a distinguished road
Originally Posted by RichinRidgewood View Post
Replacing the plastic housing with a metal one is fixing a problem where there isn’t one.
Just say’n
I agree.
HighLighter is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 12:32 PM #32
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Just say’n
My thoughts too. I'm not saying the plastic housing can't have problems but they have been problem free for me. 145k miles on my previous FJ and 38k miles on my current 4Runner, no leaks or cracks with me changing the oil every 5k miles using the correct tools.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 01:27 PM #33
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Just say’n
Until you take your beloved T4R in for an oil change or you change it yourself, it slips out of the tech’s (or your) hands and hits the concrete. (yes this happens)
You pick it up, look at it, don’t see any damage. (Not even that hairline crack)
Put everything back together.
Success!!!!!
Until you are on the interstate one day cruising at 75, distracted or some backroad and your oil light comes on and you can’t get pulled over or stop until your engine has locked up.
I know now some of you are saying what’s the chances of that happening, right?
Well, it happens according to Toyota.
And if it happens to you, that’s one too many times.
IMHO, Toyota should have included these on these engines a long time ago.
Just sayin’
Best Regards,
Saker
Old 09-06-2021, 02:02 PM #34
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
This image shows proper location for the o-ring
Had to go back to using the plastic oil filter housing-20200102_200033-jpg
DougR is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 03:51 PM #35
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
I replaced the plastic one at my first oil change with a Dorman and at the time also bought a filter wrench at Advance Auto. I'm sure it was a China cheapie.
So far 25k miles and 3 filter changes with not a drop in leaks.
Get my filters at the dealer.
There has to be a defect in one of the mating surfaces like a scratch, or a defect in the orings or possibly porosity in the aluminum of either.
Funny story,
Guy I know has a Ram Sprinter type service van, changed his own oil.
Next day after probably 100+ miles of driving finds oil dripping on the ground. Non on dipstick.
He discovers the filter setup is leaking.
the setup is almost identical to ours but all plastic.
Tries fixing it 3 more times and still leaks.
Had me look at it and found he was not putting the oring in the groove but had it against the flange.
The irony here is that he makes big money repairing restaurant equipment.
seatia is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 12:34 PM #36
MikesDuneRunnerSLS MikesDuneRunnerSLS is offline
MikesDuneRunnerSLS is on a distinguished road
Originally Posted by Nuke View Post
I've been doing oil changes for over 50 years. Yes, the metal housing is OE Toyota. Yes, I replaced BOTH o-rings having lubed them first. Yes, when I did my 1st oil change using the metal housing I swapped the internal perforated tube and have since swapped it back to the plastic housing. Yes, I torqued the metal housing to 18 ft-lbs.
I had no issues during the 1st oil change (about 1 year) with the metal housing as well as 3 months on the 2nd oil change. Yes, I'm baffled.
We know you did it right 👍I hope you don't think there was any implication of you being a hack. The problem is likely as simple as a production flaw. Defective parts are made every day.
2011 SR5 Non-KDSS 4x4
Hyperco-650#/6112-BCV | B12 SS+1.5 Coils/8100-SB/R, Energy | DuroBumps<-Waste of $$$, NitroGear UCAs, 2Gen Rear SBLs, MCP Frame Gussets, CSF#7085, SprintBooster v3@R1, MBRP 304SS-CBE, MCP Drone Dampers, SAIS Exorcism, Odyssey AGM, ARB Skids, Rival Fuel Skid, Spidertrax, Falken AT3W
2016 GX LuxSpt KDSS
KDMax, Northstar AGM, SuperBumps | Timbrens, Hankook AT2/Xtreme
MikesDuneRunnerSLS is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 02:31 PM #37
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
I had the same issue with the OEM aluminum housing, had a small weep. I keep it in my tool box as a spare in case of an emergency. In all honesty the plastic has a very tiny Tiny weep right after an oil change, but once i get it on the interstate the higher oil pressure seems to seat the o-ring gasket. I think its most likely the mount off the front of the engine rather than the housing.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 07:15 PM #38
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
I'm sticking with my plastic housing. Never had an issue with it breaking or leaking.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 09:29 PM #39
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
…never mind
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 09:43 PM #40
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
I appreciate all the responses. I've cleaned the metal housing, inspected it under magnification and will reinstall it next oil change which likely won't be until next June since that T4R isn't seeing a lot of mileage at this time. My stock of filters with the packaged o-rings are all OE so I'm still scratching my head on this one. I'll just be sure to leave the skid plate plate off for a bit after that next oil change.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
change , housing , installed , metal , oil
Replaced plastic filter housing with metal - question fir those that already did Nuke 5th gen T4Rs 36 02-02-2021 12:42 AM
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Broken plastic housing on remote key ALTAHLC 4th Gen T4Rs 9 08-04-2017 08:57 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
Plastic rear heater housing grey Hogan Classifieds - buy & sell (no commercial ads please) 0 11-30-2003 09:18 PM
