Old 09-03-2021, 04:15 PM #1
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
Had to go back to using the plastic oil filter housing
Back in 2020 when I did my first oil change on my '19, I installed a Toyota metal housing. Despite not being thrilled with how it seated with that "feel" that it was " tight enough", it was fine and didn't leak. This past June I did another oil change, buttoned everything up and again no leaks. Until yesterday when I found a small puddle of oil. The oil was coming from the housing-to-base seat. I checked that it was still tight to spec, then dropped the housing, checked and cleaned up the threads, installed a new filter and all o-rings, torqued to spec and it began to weep as soon as I fired her up. Befuddled, I dropped the metal housing, installed the OE factory plastic housing, made a short drive and she's dry as a bone.
Anyone else have issues with the metal housing? The metal housing held up fine for one year through that 1st oil change as well as nearly 3 months after the 2nd. Strange...
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 04:23 PM #2
choochoo choochoo is offline
Real Name: Sheldon
choochoo will become famous soon enough choochoo will become famous soon enough
Real Name: Sheldon
That's strange. I've had the metal housing for a little over a year now and haven't had a problem. Have changed oil 2-3 times now and no leaks.
Build Blog
Always doing something...
choochoo is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 04:54 PM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough
<<<<'s Avatar
Other than recommending use original o-ring in proper groove I can't add anything to your solution options.
TRD 17x8.5 Wheels / Nitto RG 285/70/17 / Shrockworks Sliders / CBI Front/Mid and Artec Fuel Tank Skids / B&I CF Dash / TRD Stealth Shift / LED Floor Ambient Light / Prado Al Pedals / Ellis Precision Al Battery Holddown / X2 AGM Battery/LED interior / ARB on-board Air / LC custom Engine Cover / CF GC Shelf / Fire Ext & MagLite
<<<< is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 07:05 PM #4
Saker's Avatar
Saker Saker is offline
Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of Saker has much to be proud of
Saker's Avatar
Make sure you have an OEM Toyota metal filter and if you do, make sure the gasket is installed properly and in the correct location.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 09-03-2021, 09:12 PM #5
Nuke's Avatar
Nuke's Avatar
The metal housing is OE Toyota as are the filters and o-rings. The odd thing is that this one began leaking about 3 months after a second oil change using it as well as after putting a fresh, lightly oiled o-ring in (properly) and ensuring everything was clean.
Rick
Old 09-03-2021, 09:18 PM #6
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Replacing the plastic housing with a metal one is fixing a problem where there isnít one.
Just sayín
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 09:20 PM #7
Use that money to buy more and better beer
Sunroof
Old 09-03-2021, 09:34 PM #8
Saker's Avatar
Saker's Avatar
Ok, reason for me posting this is because this has been discussed in previous post and almost all if not all were non OEM parts from a dealership and bought online without Toyota markings or o rings in the wrong place.
I would inspect it carefully.
Best Regards,
Saker
Old 09-03-2021, 09:48 PM #9
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Just sayín
For me the ďproblemĒ was how expensive the plastic one was compared to the metal one after the dealer refused to own up to their mistake.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 09:49 PM #10
KB180 KB180 is offline
KB180 has a spectacular aura about KB180 has a spectacular aura about
Just changed mine last week with OEM filter and o-ring (2019). Never the slightest hint of any oil leakage around the metal housing. Had to go back to using the plastic oil filter housing-20210903_184747-jpg
Sent from my SM-N960U using Tapatalk
KB180 is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:03 PM #11
MichBadger MichBadger is offline
MichBadger is on a distinguished road
I did my first oil change about a month ago. I had bought the cheapest housing removal tool with decent ratings. The plastic housing was on so tight, I actually broke the tool. I then ordered the motive X removal tool and put the 27mm socket on the impact wrench to take it off. I didn't realize it during the process, but I had cracked the plastic housing and had a major leak. I needed the vehicle back in service so went and bought the Dorman version. Of course, as the reviews state, I've had a very slow leak over the last couple of weeks. I ordered the OEM metal housing and it literally was delivered earlier today. Now I read this thread...
MichBadger is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:09 PM #12
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Just sayín
Ignore most of what this guy says.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:27 PM #13
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
Hasnít been a problem on mine either. I only give it a snug once it is all the way on and stops. Seems very odd that it weeps past the gasket and threads like that constantly. Try another one or back to the plastic I guess.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:50 PM #14
dride's Avatar
dride dride is offline
dride is on a distinguished road
dride's Avatar
No issues with mine, as of 3 months. I cracked my plastic, wasnít going to pay $170 for the plastic.
dride is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 11:13 PM #15
Saker's Avatar
Saker's Avatar
Here is a copy from my 2014 build. It was on my T4R for 4 years until it was totaled and it never leaked.
Have one on my 21, doesn’t leak.
Sept 26, 2016
Aluminum Oil Filter Cap
Toyota Part # 15620-31060
Best Regards,
Saker
change , housing , installed , metal , oil
Replaced plastic filter housing with metal - question fir those that already did Nuke 5th gen T4Rs 36 02-02-2021 12:42 AM
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Broken plastic housing on remote key ALTAHLC 4th Gen T4Rs 9 08-04-2017 08:57 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
Plastic rear heater housing grey Hogan Classifieds - buy & sell (no commercial ads please) 0 11-30-2003 09:18 PM
